Home » Eclipse Projects » Commercial » Problem edit Custom Composit in SWT-Designer 4.3.0.
Problem edit Custom Composit in SWT-Designer 4.3.0. [message #8506] Mon, 20 March 2006 01:47 Go to next message
If I select the "Method name for new statements:" by initialize(just to
compatable with VE) option in the "Code Generation" page.
After this I create a custom composite, and add a button on the composite,
then the code code not be compiled.
Another problem is:
If I create a BasisComposite with a tabFolder, and add FeeRegionComposite
onto the tabItem, then swt-Designer cannot parse it, eclipse can run it.
public class BasisComposite extends Composite {
* Create the composite
* @param parent
* @param style
public BasisComposite(Composite parent, int style) {
super(parent, style);
setLayout(new FillLayout());
FormToolkit toolkit = new FormToolkit(Display.getCurrent());
toolkit.adapt(this);
toolkit.paintBordersFor(this);
TabFolder tabFolder;
tabFolder = new TabFolder(this, SWT.NONE);
toolkit.adapt(tabFolder, true, true);
final TabItem tabItem_FeeRegion = new TabItem(tabFolder, SWT.NONE);
tabItem_FeeRegion.setText("
Re: Problem edit Custom Composit in SWT-Designer 4.3.0. [message #9262 is a reply to message #8506] Wed, 29 March 2006 23:11 Go to previous message
"xy" <nhsoft.xy@gmail.com> wrote in message
news:dvlj6b$28u$1@utils.eclipse.org...
I tried that and it worked fine. Do you have an example?
> Another problem is:
I tried your example and they worked fine in Designer. The parsed and
displayed correctly.
Based on that, my guess is that you are running into some sort of
installation or configuration problem. The Designer FAQ offers several
suggestions for case slike that.
-Eric Clayberg
Sr. Vice President of Product Development
Instantiations, Inc.
http://www.instantiations.com
http://www.windowbuilderpro.com/
Author: "Eclipse: Building Commercial Quality Plug-ins"
http://www.awprofessional.com/title/0321228472
Re: Problem edit Custom Composit in SWT-Designer 4.3.0. [message #561852 is a reply to message #8506] Wed, 29 March 2006 23:11 Go to previous message
> Another problem is:
-Eric Clayberg
Previous Topic:RCP Developer - new product from Instantiations
Next Topic:New Exceptional JXTA plugin from javadojo.com
Current Time: Tue Nov 04 03:57:48 EST 2025
Powered by FUDForum. Page generated in 0.03176 seconds
