Home » Eclipse Projects » Remote Application Platform (RAP) » Image disappear in table item
Image disappear in table item [message #93682] Mon, 16 June 2008 08:59 Go to next message
--------------030103050107060501000105
Hi all,
I want to show an image only in the selected item of a Table.
Attached there are two code snippets.
In RapTest1, when I select the first item the image shows correctly. But
when I select other item that the first, no image shows.
In RapTest2, if I select the second or the third item the image shows
correctly. When I select the first item and then the second item, the
image disappear.
It seems that images are only displayed if the first item of the Table
has the image.
Is this a bug of RWT Table control?
Enrico
Content-Type: application/octet-stream;
name="src.zip"
Content-Disposition: attachment;
filename="src.zip"
UEsDBBQAAAAIAINuezYltIMGOAEAAD0BAAAIAAAAaWNvbi5naWaNj98vAgEc wL9tRrPQFKWk
3cRuOsNZQ83EKWk55ceQYWG0edDirXpojSxLMlM3O9ftVgujrT8B06x5Mf4A m/kDvHk67j/o
8/Z5+3wmJq2DQx4pSOEDBHiez6Fd2hAgIdAGYJ2z6iMi03HDKmP0Zq2GaA2R aGJLMUtCsX87
7UohC2k0Xz4NFuZvysm713MP3bPB9G2z/TvcwG522N8NPgz29BBoh0fqqESf lOjES+Ys3AJR
OeRG8LgE4nXAdmryRvzeThRnp1JiUVoipuUyRtGcUas4BPlPgspAfqtEADhg gghPUO02Uz4b
popT3E+jq96gLH999j4fUrWWNycWK1xIH8w6SYSFb/e144kIK2UHZubda0OL pA7tUC+Sba3j
DrtmzDkzR+JLyytr9s0tb5LwXwavyFEw/QFQSwMEFAAAAAgAd3bQOIOF6Bn5 AgAA8gkAAA0A
AABSYXBUZXN0MS5qYXZhvVZta9swEP5e6H9Q/UkenUgyGIMyWJs6rSFLR+Ou H4drXRJR2TKS
nLRs/e+TbCd+i9tsg5mQWHfP3fPc6S0sToXUSMglgYizVAGRG02WMkxXLFLk qnw5Oz7qgXK2
gOg54kB8L9Hy+Ztgid4PVwY+vw/6nVGmtIjJu34ErCHRqhdRSX8Vw8NnkWky YZxP89d+6IbR
JfQzZowshIzVDjcxo0AI/shs0uOjNHvgLEIRD5VCt2EagNJDZDJxiG0pqNY1 9NNGIPN8uVmD
lIxCMSyTWEgkIdRw52PXolH5LFgScnTJVGpKQxR9RglstmPsnlXI+Qo4R6pA FCNMT5GZFjK/
9qbTH8Gt/7UeoIgCfSGyhCo8OEXm82lgvj4OBh1U0UtsE1etxW4dV73VGoUW +rEQVLdiug2s
KgzCBw5IG7AJIUUvchtWZQ3+7GrqoV/5YHJn6pl7U28c+DezejZt5V5DSEF+ Z4rZBFpmsFdp
QToWPIsTFA0LoXUj1gX31JsEtQwGa1kCeNLYGQ+druueUb3Co10nu2yjP2Ab 1dhGTsdVsb1S
pa8hRqyssTJtOWc3M68ezWoVnjs9nuEpci6cN0lHB5PWC3U6nor08m3SDweT fqhIPafjqUgn
DWd7/fpxuATEIpEY4qvtSWUOjtyBHeshS7ZwTpExju2hgV3rvwUlMhnBuZpr s+rjGrRnf2kS
UjoHDpFmIpkypSEBmW/OjnV7mFRPc5RKtjY7LT+AjCZdJsireD88OyR0LRhF asN0tNpFY5tP
bUd+QuGpIWTX4gVu0Z5YXuQ2obvKbcPyyWwEuURt+4zzHxclGedV96qnY2lX 3VJ9UApTRSvs
X8uwS6At/+X4qDK0r5Lyqa6UYlqKu+sSFmHGSyKgeMfo2TsXwb6p6cxoLnre qBK7HY3N4V/q
/b9CX/bvMlX+l8DNy1CkkDRMmxUzdww6UYQpey0LZYS7KJfaXiQnlJgtTs8T apGhkW2R3ZIo
URwgLXi6iiXoTCZoYLy7hWG+fgNQSwMEFAAAAAgAenbQOA+QWXv+AgAADgoA AA0AAABSYXBU
ZXN0Mi5qYXZhvVZtb9owEP5eqf/BzSdnYhFQaZpUTVpLQxuJ0amk68cpjQ+w 6sSR7UCrrf99
dhJwXqBlm1QLQXz33D33nB0bmmRcKMTFwoOY0UyCJ9bKW4goW9JYelfVw9nx 0R4oo3OIn2MG
XuCnSjx/5zRVu+FSw2f34X5nnEvFE+/DfgSsIFVyL8KW/iqGRc88V96YMjYp HvdD15QsYD9j
Tr05F4nc4sZ6FnLOHqlJenyU5Q+MxihmkZToNspCkGqIdCYGiZGCal1Dv0wE 0uPrzQqEoATK
aZXEQGIBkYK7ALsGjaoxp2nE0CWVmZaGCPqCUlhv5tg9s8jZEhhDskSUM0x6 SC+LN7v2J5Of
4W3wrR4gPQnqgucpkbjfQ/rzua+/PvX7HVTZS2wS29Zit46zT7VGobl6LAuq WzHZBFqFYfTA
ACkN1iFe2YvChmWlIZheTXz0u5iM77SemT/xR2FwM61nU6bca4gIiB9UUpNA iRx2VlqSjjjL
kxTFg7LQuhGrknvij8NaBo01LCE8KeyMBk7XdU+JWuLhtpNdtuFfsA1rbEOn 47Jsr6gMFCSI
VhqtacM5vZn69WhaU3ju7PEMesi5cN4kHR5MWhfqdDyW9PJt0tODSU8tqe90 PJZ03HC292+Q
RAtANOapJr7anFT64Cgc2DEeb0HnTg9p48gcGtg1/luQPBcxnMuZ0rs+qUHd dt832Qyi7qtv
/4iQGTCIFeXphEoFKYjixe1YNweNHc1ZJuhKv4XF4aTrVVWCQuHHwdkhoStO CZJrquLlNhqb
fHIzC1ICT41CtoLnuEV7YniR24RulZtmFgvdCHJt13Dx46I0Z8x2z46Opa26 VfVBKbSKVtj/
yrCLb8fL8ZE1tK+ZatjrplyW8l67hHmUs4oICN4y+uY+RrBraTorWhQ9a6jE bqfG5vQf633f
Ql92v2Wy+p+BmxclzyBtmNZLqu8fdCI9Ks2VzaUu3EVFqe1NckI8/fqT85QY ZKTLNsiuJOJJ
BpCVPN2KBahcpKivvduNob/+AFBLAQIUABQAAAAIAINuezYltIMGOAEAAD0B AAAIAAAAAAAA
AAAAIAAAAAAAAABpY29uLmdpZlBLAQIUABQAAAAIAHd20DiDhegZ+QIAAPIJ AAANAAAAAAAA
AAAAIAAAAF4BAABSYXBUZXN0MS5qYXZhUEsBAhQAFAAAAAgAenbQOA+QWXv+ AgAADgoAAA0A
AAAAAAAAAAAgAAAAggQAAFJhcFRlc3QyLmphdmFQSwUGAAAAAAMAAwCsAAAA qwcAAAAA
--------------030103050107060501000105--
Re: Image disappear in table item [message #93726 is a reply to message #93682] Tue, 17 June 2008 05:04 Go to previous messageGo to next message
Originally posted by: ifurnadjiev.innoopract.com
Hi Enrico,
I've reproduced it with the RAP Control Demo - Table. If there is no
image set to the first item, the image is not set to the rest. This
appear to be a bug. As a workaround you can set an transparent empty
image (16x16) instead of null when there is no image.
Best,
Ivan
Enrico Zanaga wrote:
> Hi all,
> But when I select other item that the first, no image shows.
> image disappear.
> has the image.
> Enrico
Re: Image disappear in table item [message #93814 is a reply to message #93726] Tue, 17 June 2008 06:46 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
This is rather a 'feature' than a bug, since SWT on Windows shows
this behavior.
From a sensible point of view, I also would consider this to be a bug.
But, as RWT implements a subset of SWT, not only in terms of API but
also semantically, it also adheres to its limitations.
Rüdiger
Ivan Furnadjiev wrote:
> Hi Enrico,
> Best,
> Ivan
>> Hi all,
>> image disappear.
>> has the image.
>> Thanks,
>> Enrico
Re: Image disappear in table item [message #93859 is a reply to message #93814] Tue, 17 June 2008 09:22 Go to previous messageGo to next message
Hi Rüdiger,
I'm not sure it's a 'feature' in SWT.
Running code snippet in SWT 3.3 and 3.4 on Windows, the Table initially
shows no icons. The first time I click on an item the icon appears and
remains, even clicking second and third item.
This is the behavior I expect that, even in RAP.
Enrico
Rüdiger Herrmann ha scritto:
> This is rather a 'feature' than a bug, since SWT on Windows shows this
> behavior.
> Cheers,
> Rüdiger
>> Hi Enrico,
>> Best,
>> Ivan
>>> Hi all,
>>> image disappear.
>>> Table has the image.
>>> Thanks,
>>> Enrico
Re: Image disappear in table item [message #93950 is a reply to message #93859] Thu, 19 June 2008 02:51 Go to previous message
Enrico,
you are right, this should work. It was a misunderstanding on my
side. I file this bug:
237740: [Table] Changing image with selection does not work
https://bugs.eclipse.org/bugs/show_bug.cgi?id=237740
Rüdiger
> Hi Rüdiger,
> Enrico
>> behavior.
>> Cheers,
>> Rüdiger
>>> Hi Enrico,
>>> Best,
>>> Ivan
>>>> Hi all,
>>>> shows correctly. When I select the first item and then the second
>>>> item, the image disappear.
>>>> Thanks,
>>>> Enrico
Previous Topic:Missing ControlDecoration
Next Topic:Theming >1.1M4
Current Time: Fri Nov 14 00:57:14 EST 2025
Powered by FUDForum. Page generated in 0.03509 seconds
