Home » Language IDEs » C / C++ IDE (CDT) » post build steps?
post build steps? [message #93426] Wed, 04 February 2004 22:54
Hi all,
I have 2 projects, a java project that depends on (references) a c/c++
project. The building works fine, my c/c++ project gets built first, and
then the java project is built automatically.
However to run the application, the library created by the c/c++ project
has to be in the bin directory of the java project.
1. Is it possible to copy the library automatically after the build?
It's a Managed Make C/C++ project, so I can't edit the makefile, can I?
2. Can I specify to the Java project to somehow add the Release
directory of the C/C++ project to it's java.library.path system property?
Maybe I can make a pre-run ant task to copy the library if it's newer. I
only want to do it this way if it's impossible any other way...
Matthijs.
Previous Topic:Searching for declarations
Next Topic:c / c++
Current Time: Mon Nov 03 12:02:41 EST 2025
Powered by FUDForum. Page generated in 0.03489 seconds
