Home » Eclipse Projects » GEF » Logic and Flow editors design
| Logic and Flow editors design [message #93370] |
Wed, 10 September 2003 10:39  |
Originally posted by: vgusev.graphlogic.com
I am studying the Logic and Flow editor designs and try to reconcile them
with the Chapter 13, Editors, of "The Java Developer's Guide To Eclipse"
book. In particular, I am interested in the editor - model interaction. The
book suggest to use the content provider class as a facilitator and
decoupler in this interaction. The content provider also is used to listen
for the model change events and force the editor update.
I was looking for this kind of set-up in the Logic and Flow editor examples,
and found only LogicContextMenuProvider or FlowContextMenuProvider which
are used only for context menues.
So my question is why there is no ContentProviders in the Logic and Flow
editors?
Thanks.
Vladimir
| Re: Logic and Flow editors design [message #93442 is a reply to message #93370] |
Wed, 10 September 2003 13:32   |
ContentProvider's aren't very applicable to graphical editors. They're
great if you are writing a java source ourline, or a view of a file
directory. ContentProvider's are used by JFace Viewers. JFace Viewers and
Workbench Editors are completely separate concepts, which can be used
together. The book is probably referring to editors whose primary function
is to display a list, tree, or table.
In GEF, an EditPart is the equivalent of a mini-contentProvider. There are
many editparts, not just one. It is the bridge between model and view, and
it listens to the model. Please read the GEF tutorial. See
http://www.eclipse.org/gef
"Vladimir" <vgusev@graphlogic.com> wrote in message
news:bjnd02$nt2$1@eclipse.org...
> Hello,
The
examples,
> editors?
> Thanks.
> Vladimir
| Re: Logic and Flow editors design [message #93628 is a reply to message #93442] |
Wed, 10 September 2003 22:09   |
In your tutorial, you write about two models, View Model and Business Model.
I have a case of two models - the business model is persisted in the
database. How do you think the business model updates by the Graphic Editor
should be handled? In the EditParts? You write (in the EditPart Life-cycle
section) that an EditPart is created by the factory for every domain object.
Then the EditParts are thrown away as soon as the user removes the
corresponding viewer's object. Since the latter is the case, the EditParts
will not be able to handle the deletion of the objects in the Business Model
(as there is no destructors in java where I could put the destruction of the
object in the Business Model;-). It seems that I need something else, some
other type of controller to fully handle the Business Domain. Is this
correct?
Thanks.
Vladimir
"Randy Hudson" <none@us.ibm.com> wrote in message
news:bjnn5r$4k1$1@eclipse.org...
function
are
and
> > Hello,
them
> The
listen
> examples,
which
> > editors?
> > Thanks.
> > Vladimir
| Re: Logic and Flow editors design [message #93731 is a reply to message #93628] |
Thu, 11 September 2003 10:11   |
news:bjole1$1po$1@eclipse.org...
Model.
Editor
object.
You're looking at it backwards. The Business Model is deleted, which
notifies the parent of the editpart, which then refreshes its children,
which then "deletes" the editpart corresponding to the model object deleted.
That same EditPart (the one that is going to disappear) is responsible for
providing the command which deletes the model object, and eventually itself.
Model
the
> correct?
> Thanks.
> Vladimir
and
> function
> are
> and
> > > Hello,
> them
Eclipse"
interaction.
> > The
> listen
> > examples,
> which
Flow
> > > editors?
> > > Thanks.
> > > Vladimir
| Re: Logic and Flow editors design [message #93746 is a reply to message #93731] |
Thu, 11 September 2003 10:19   |
No, I was describing an opposite use case:
1) the end user deletes a graphical representation of the business domain
object;
2) the corresponding EditPart gets deleted
3) the domain business object is not deleted, because the only reference to
it was in the EditPart that does not exist anymore.
Vladimir
news:bjpvov$8ng$1@eclipse.org...
> Model.
> Editor
Life-cycle
> object.
EditParts
deleted.
itself.
> Model
> the
some
> > correct?
> > Thanks.
> > Vladimir
They're
> and
> > function
There
> > are
view,
> > and
> > > > Hello,
> > them
> Eclipse"
> interaction.
> > > The
> > listen
> > > examples,
> > which
> Flow
> > > > editors?
> > > > Thanks.
> > > > Vladimir
| Re: Logic and Flow editors design [message #93795 is a reply to message #93746] |
Thu, 11 September 2003 11:32   |
I stepped through the Flow example code and see two possibilities to handle
the deletion of the Business Object.
1) In the parent "contents" EditPart - however, how do I delete the parent
Business Object that will be contained in the parent EditPart?
2) In the commands (for example in the DeleteCommand.execute() I could
delete a Business Object, which is represented by a view model object
(Transition, for example). However, this seem to create a pretty tight mix
of the View Model and the Business Model.
What do you think?
Vladimir
news:bjq088$9c6$1@eclipse.org...
> object;
to
> Vladimir
> > Model.
> > Editor
> Life-cycle
> > object.
> EditParts
> deleted.
for
> itself.
> > Model
of
> > the
> some
> > > correct?
> > > Thanks.
> > > Vladimir
> They're
Viewers
> > and
used
> > > function
> There
> > > are
> view,
> > > and
> > > > > Hello,
reconcile
> > > them
> > Eclipse"
> > interaction.
> > > > The
and
to
> > > listen
> > > > examples,
> > > which
and
> > Flow
> > > > > editors?
> > > > > Thanks.
> > > > > Vladimir
| Re: Logic and Flow editors design [message #93854 is a reply to message #93746] |
Thu, 11 September 2003 15:36   |
> object;
to
This is a surprise. How do you persist your busniess objects? When you
undo a delete, where would the object get re-added? Your model should be
stand-alone, meaning it exists by itself, and the editparts just reach into
it. Maybe the article wasn't clear on the term "graphical representation"
(view model) and business model. The graphical representation is not the
figures that are used to display the business model.
> Vladimir
> > Model.
> > Editor
> Life-cycle
> > object.
> EditParts
> deleted.
for
> itself.
> > Model
of
> > the
> some
> > > correct?
> > > Thanks.
> > > Vladimir
> They're
Viewers
> > and
used
> > > function
> There
> > > are
> view,
> > > and
> > > > > Hello,
reconcile
> > > them
> > Eclipse"
> > interaction.
> > > > The
and
to
> > > listen
> > > > examples,
> > > which
and
> > Flow
> > > > > editors?
> > > > > Thanks.
> > > > > Vladimir
| Re: Logic and Flow editors design [message #93870 is a reply to message #93854] |
Thu, 11 September 2003 15:47   |
Hm... You are repeating the question that I am asking. Again, everybody
agrees that "the business object should be standalone". My question is "how
to link it to the editparts, so that they "just reach into it?".
Vladimir
news:bjqiq6$u2p$1@eclipse.org...
domain
> > object;
> to
into
> > Vladimir
Business
> > > Model.
> > > Editor
> > Life-cycle
> > > object.
> > EditParts
children,
> > deleted.
> for
> > itself.
Business
> > > Model
destruction
> of
> > > the
else,
> > some
this
> > > > correct?
> > > > Thanks.
> > > > Vladimir
> > They're
file
> Viewers
> > > and
> used
> > > > function
> > There
> > > > are
> > view,
> > > > and
> > > > > > Hello,
> reconcile
> > > > them
> > > Eclipse"
> > > interaction.
> > > > > The
> and
> to
> > > > listen
editor
> > > > > examples,
> > > > which
> and
> > > Flow
> > > > > > editors?
> > > > > > Thanks.
> > > > > > Vladimir
| Re: Logic and Flow editors design [message #93899 is a reply to message #93870] |
Thu, 11 September 2003 16:10   |
Assuming we haven't mis-communicated, it's simple. The EditPart holds onto
both the business model, and the view model. While the default and common
case in GEF is that there is a single model object, there are many cases
where there are 2 or more model objects. When I say "holds onto", I mean it
has a field pointing to the objects. But, in the model, there is a
relationship somewhere between the "diagram" and the "view" for the view
model, and between the "namespace" and the "class" for the business model.
These relationships are the ones which get broken during delete, and these
relationships are how your classes and views get persisted when you save the
editor. The editparts are just there for editing :-)
news:bjqjdp$ulq$1@eclipse.org...
"how
> Vladimir
> domain
> > > object;
reference
> > to
be
> into
representation"
the
> > > Vladimir
> Business
> > > > Model.
the
Graphic
> > > > Editor
> > > Life-cycle
domain
> > > > object.
> > > EditParts
which
> children,
> > > deleted.
responsible
> > for
> > > itself.
> Business
> > > > Model
> destruction
> > of
> > > > the
> else,
> > > some
> this
> > > > > correct?
> > > > > Thanks.
> > > > > Vladimir
> > > They're
> file
> > Viewers
> > > > and
> > used
primary
> > > > > function
> > > There
> > > > > are
and
> > > view,
> > > > > and
> > > > > > > Hello,
> > reconcile
> > > > > them
To
> > > > Eclipse"
> > > > interaction.
> > > > > > The
facilitator
> > and
used
> > to
> > > > > listen
> editor
> > > > > > examples,
> > > > > which
Logic
> > and
> > > > Flow
> > > > > > > editors?
> > > > > > > Thanks.
> > > > > > > Vladimir
| Re: Logic and Flow editors design [message #93928 is a reply to message #93899] |
Thu, 11 September 2003 16:58   |
Thanks, this helps.
Vladimir
news:bjqkoo$db$1@eclipse.org...
onto
it
the
> "how
> > Thanks,
> > Vladimir
> > domain
> > > > object;
> reference
> > > to
you
> be
> > into
> representation"
> the
> > > > Vladimir
> > Business
> > > > > Model.
> the
> Graphic
> > > > > Editor
> > > > Life-cycle
> domain
> > > > > object.
the
> > > > EditParts
> which
> > children,
object
> > > > deleted.
> responsible
> > > for
eventually
> > > > itself.
> > Business
> > > > > Model
> > destruction
> > > of
> > > > > the
> > else,
> > > > some
> > this
> > > > > > correct?
> > > > > > Thanks.
> > > > > > Vladimir
> > > > They're
> > file
> > > Viewers
> > > > > and
be
> > > used
> primary
> > > > > > function
> > > > There
> > > > > > are
> and
> > > > view,
> > > > > > and
> > > > > > > > Hello,
> > > reconcile
> > > > > > them
> To
> > > > > Eclipse"
> > > > > interaction.
> > > > > > > The
> facilitator
> > > and
> used
> > > to
> > > > > > listen
> > editor
> > > > > > > examples,
> > > > > > which
> Logic
> > > and
> > > > > Flow
> > > > > > > > editors?
> > > > > > > > Thanks.
> > > > > > > > Vladimir
| Re: Logic and Flow editors design [message #95648 is a reply to message #93899] |
Sat, 27 September 2003 07:05   |
Originally posted by: ThisisFake.Fakeness.xyz
Where is final delete done? AS in, I only want to delete when undo becomes
impossible. And of course I do not want to use a finalizer.
And to Vladimir, I have a nice caching class I have been using to cache my
database objects in the VM domain. I could provide if you like. very
small threaded class which is the backbone of all my DB classes. Havent
used in Eclipse yet. Used in JHotDraw.
CL
> "how
>> Thanks,
>> Vladimir
>> domain
>> > > object;
> reference
>> > to
> be
>> into
> representation"
> the
>> > > Vladimir
>> Business
>> > > > Model.
> the
> Graphic
>> > > > Editor
>> > > Life-cycle
> domain
>> > > > object.
>> > > EditParts
> which
>> children,
>> > > deleted.
> responsible
>> > for
>> > > itself.
>> Business
>> > > > Model
>> destruction
>> > of
>> > > > the
>> else,
>> > > some
>> this
>> > > > > correct?
>> > > > > Thanks.
>> > > > > Vladimir
>> > > They're
>> file
>> > Viewers
>> > > > and
>> > used
> primary
>> > > > > function
>> > > There
>> > > > > are
> and
>> > > view,
>> > > > > and
>> > > > > > > Hello,
>> > reconcile
>> > > > > them
> To
>> > > > Eclipse"
>> > > > interaction.
>> > > > > > The
> facilitator
>> > and
> used
>> > to
>> > > > > listen
>> editor
>> > > > > > examples,
>> > > > > which
> Logic
>> > and
>> > > > Flow
>> > > > > > > editors?
>> > > > > > > Thanks.
>> > > > > > > Vladimir
| Re: Logic and Flow editors design [message #96135 is a reply to message #95648] |
Tue, 30 September 2003 10:10  |
There is no final delete in the object itself, so I am using the parent
object, in terms of the flow example, it's StructuredActivity.removeChild -
were one can do the deletion in the domain model, corresponding to a
deletion of the child in the GEF's model.
Thanks for offering your code - I think I figured out how to do it using
jdo.
Vladimir
"CL [dnoyeB] Gilbert" <ThisisFake@Fakeness.xyz> wrote in message
news:pan.2003.09.27.11.05.42.204283@Fakeness.xyz...
becomes
> CL
onto
common
mean it
model.
these
the
> > "how
> >> Thanks,
> >> Vladimir
> >> domain
> >> > > object;
> > reference
> >> > to
you
should
> > be
reach
> >> into
> > representation"
> > the
> >> > > Vladimir
> >> Business
> >> > > > Model.
in
> > the
> > Graphic
> >> > > > Editor
> >> > > Life-cycle
> > domain
> >> > > > object.
the
the
> >> > > EditParts
> > which
> >> children,
object
> >> > > deleted.
> > responsible
> >> > for
eventually
> >> > > itself.
> >> Business
> >> > > > Model
> >> destruction
> >> > of
> >> > > > the
> >> else,
> >> > > some
Is
> >> this
> >> > > > > correct?
> >> > > > > Thanks.
> >> > > > > Vladimir
editors.
> >> > > They're
a
> >> file
JFace
> >> > Viewers
> >> > > > and
be
> >> > used
> > primary
> >> > > > > function
> >> > > There
> >> > > > > are
> > and
> >> > > view,
> >> > > > > and
> >> > > > > > > Hello,
> >> > reconcile
> >> > > > > them
Guide
> > To
> >> > > > Eclipse"
> >> > > > interaction.
> >> > > > > > The
> > facilitator
> >> > and
> > used
> >> > to
> >> > > > > listen
> >> editor
> >> > > > > > examples,
> >> > > > > which
> > Logic
> >> > and
> >> > > > Flow
> >> > > > > > > editors?
> >> > > > > > > Thanks.
> >> > > > > > > Vladimir
Current Time: Sun Nov 30 18:46:10 EST 2025
Powered by FUDForum. Page generated in 0.07975 seconds
