Home » Newcomers » Newcomers » Resizing problem driving a newb nuts !
Resizing problem driving a newb nuts ! [message #93359] |
Mon, 08 August 2005 16:28 |
Originally posted by: sebastien.nault.loto-quebec.com
I've bin stuck with the following resizing problem for weeks and I
can't
seem to find a solution nor the reason. I have an SWT/JFace
ApplicationWindow containing a ScrolledComposite that holds a Composite
having a StackLayout. The goal is to be able to stack within a
ScrolledComposite.
A Goto... Menu Actions adds composites to the StackLayout, but right
now, only my search Composite is giving me an headache. The search
Composite has a search Button that dynamically displays the results
(equipments) within Tabs. After insertion of a new Tab, I do a
getShell().pack(true); but for some reason, only the outer
ApplicationWindow resizes correctly and not what is within the
StackLayout.
To better understand, I've added to this post a stripped version of my
search
application with three classes: the ApplicationWindow (v_navigator), the
search Composite (v_search) and the search results Composite (v_equipment).
The code is really simple.
If anyone can free me from my desperation I would truly appreciate.
Sebastien
P.S. Three classes follow
Navigator
package navigator;
import org.eclipse.jface.action.Action;
import org.eclipse.jface.action.MenuManager;
import org.eclipse.jface.action.StatusLineManager;
import org.eclipse.jface.action.ToolBarManager;
import org.eclipse.jface.window.ApplicationWindow;
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.ScrolledComposite;
import org.eclipse.swt.custom.StackLayout;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Shell;
public class V_NavigatorCIP extends ApplicationWindow {
private Action actEquipment;
private ScrolledComposite scrolledContainerAppl;
private Composite containerAppl;
public V_NavigatorCIP() {
super(null);
createActions();
addToolBar(SWT.FLAT | SWT.WRAP);
addMenuBar();
addStatusLine();
protected Control createContents(Composite parent) {
// Le scrolled composite ne peut pas contenir de layout car c'est le
// layout
// listner qui s'en occupe pour les redimensionnements.
scrolledContainerAppl = new ScrolledComposite(parent, SWT.V_SCROLL
| SWT.BORDER | SWT.H_SCROLL);
scrolledContainerAppl.setAlwaysShowScrollBars(true);
scrolledContainerAppl.setExpandHorizontal(true);
scrolledContainerAppl.setExpandVertical(false);
containerAppl = new Composite(scrolledContainerAppl, SWT.NONE);
final StackLayout stackLayout = new StackLayout();
containerAppl.setLayout(stackLayout);
containerAppl.setSize(containerAppl.computeSize(SWT.DEFAULT,
SWT.DEFAULT));
scrolledContainerAppl.setContent(containerAppl);
return scrolledContainerAppl;
private void createActions() {
actEquipment = new Action("Equipment") { //$NON-NLS-1$
public void run() {
showEquipment(containerAppl);
actEquipment.setAccelerator(SWT.CTRL | 'E');
actEquipment.setToolTipText("Goto ..."); //$NON-NLS-1$
protected MenuManager createMenuManager() {
MenuManager menuPrincipal = new MenuManager("menu"); //$NON-NLS-1$
final MenuManager menuAllerA = new MenuManager("Goto ...");
menuAllerA.add(actEquipment);
menuPrincipal.add(menuAllerA);
return menuPrincipal;
protected ToolBarManager createToolBarManager(int style) {
ToolBarManager toolBarManager = new ToolBarManager(style);
return toolBarManager;
protected StatusLineManager createStatusLineManager() {
StatusLineManager statusLineManager = new StatusLineManager();
statusLineManager.setMessage(null, "");
return statusLineManager;
public static void main(String args[]) {
try {
V_NavigatorCIP window = new V_NavigatorCIP();
window.setBlockOnOpen(true);
window.open();
Display.getCurrent().dispose();
} catch (Exception e) {
e.printStackTrace();
protected void configureShell(Shell newShell) {
super.configureShell(newShell);
newShell.setText("New Application");
protected Point getInitialSize() {
return new Point(500, 375);
private void showEquipment(Composite container){
V_Search searchComposite = new V_Search(container, SWT.NONE);
StackLayout sl = (StackLayout) containerAppl.getLayout();
sl.topControl = searchComposite;
// C'est le conteneur qui doit exécuter la méthode du layout car c'est
// son contenu qui change.
containerAppl.layout();
// Utiliser la taille recommandée de la vue pour dimensionner le
// conteneur
containerAppl.setSize(searchComposite.computeSize(SWT.DEFAUL T,
SWT.DEFAULT));
this.getShell().pack(true);
Search Composite
package navigator;
import org.eclipse.swt.custom.CTabFolder;
import org.eclipse.swt.custom.CTabItem;
import org.eclipse.swt.events.DisposeEvent;
import org.eclipse.swt.events.DisposeListener;
import org.eclipse.swt.events.KeyEvent;
import org.eclipse.swt.events.KeyListener;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.SelectionListener;
import org.eclipse.swt.graphics.Cursor;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Group;
import org.eclipse.swt.widgets.Text;
public class V_Search extends Composite implements
SelectionListener, KeyListener, DisposeListener {
private Button btnSearch;
private Text txtEquipmentSearch;
private CTabFolder tabFolder;
private Group equipmentGroup;
Cursor cursorWait = new Cursor(this.getDisplay(), SWT.CURSOR_WAIT);
public V_Search(Composite parent, int style) {
super(parent, style);
final GridLayout gridLayout_1 = new GridLayout();
gridLayout_1.verticalSpacing = 3;
gridLayout_1.marginHeight = 3;
setLayout(gridLayout_1);
final Group grpSearch = new Group(this, SWT.NONE);
grpSearch.setLayoutData(new GridData(
GridData.HORIZONTAL_ALIGN_FILL));
final GridLayout gridLayout = new GridLayout();
gridLayout.verticalSpacing = 3;
gridLayout.marginHeight = 3;
gridLayout.numColumns = 5;
grpSearch.setLayout(gridLayout);
grpSearch.setText("Search");
txtEquipmentSearch = new Text(grpSearch, SWT.BORDER);
final GridData gridData_1 = new GridData(GridData.GRAB_HORIZONTAL |
GridData.HORIZONTAL_ALIGN_END);
gridData_1.widthHint = 80;
txtEquipmentSearch.setLayoutData(gridData_1);
txtEquipmentSearch.addKeyListener(this);
txtEquipmentSearch.setTopIndex(1);
txtEquipmentSearch.setFocus();
btnSearch = new Button(grpSearch, SWT.NONE);
btnSearch.setSelection(true);
btnSearch.addSelectionListener(this);
final GridData gridData_4 = new GridData(
gridData_4.widthHint = 83;
btnSearch.setLayoutData(gridData_4);
btnSearch.setText("Search");
equipmentGroup = new Group(this, SWT.NONE);
equipmentGroup.setLayout(new FillLayout());
equipmentGroup.setText("Equipment");
final GridData gridData_7 = new GridData(GridData.FILL_BOTH);
//gridData_7.heightHint = 500;
//gridData_7.widthHint = 890;
equipmentGroup.setLayoutData(gridData_7);
tabFolder = new CTabFolder(equipmentGroup, SWT.CLOSE | SWT.FLAT);
tabFolder.addSelectionListener(this);
tabFolder.setUnselectedCloseVisible(false);
tabFolder.setSimple(false);
//tabFolder.setSize(550, 975);
public void addCustomTab(Composite vue, String titre) {
CTabItem tabItem = new CTabItem(tabFolder, SWT.NONE);
tabItem.addDisposeListener(this);
vue.setLayout(new GridLayout());
tabItem.setControl(vue);
tabItem.setText(titre);
tabFolder.setSelection(tabItem);
txtEquipmentSearch.selectAll();
public Composite getContainer() {
return tabFolder;
public void dispose() {
cursorWait.dispose();
super.dispose();
public void widgetDefaultSelected(SelectionEvent e) {
public void widgetSelected(SelectionEvent e) {
if (e.getSource() == getContainer())
do_tabFolder_widgetSelected(e);
if (e.getSource() == btnSearch)
do_btnRechercher_widgetSelected(e);
public void keyPressed(KeyEvent e) {
if (e.getSource() == txtEquipmentSearch)
do_txtEquipementRecherche_keyPressed(e);
public void keyReleased(KeyEvent e) {
protected void do_txtEquipementRecherche_keyPressed(KeyEvent e) {
if (e.keyCode == SWT.KEYPAD_CR || e.keyCode == SWT.CR) {
searchEquipment();
protected void do_btnRechercher_widgetSelected(SelectionEvent e) {
searchEquipment();
private void searchEquipment() {
this.setCursor(cursorWait);
V_Equipment equip = new V_Equipment(getContainer(),SWT.NONE);
addCustomTab(equip, "99999");
this.setCursor(null);
public void widgetDisposed(DisposeEvent e) {
if (e.getSource() instanceof CTabItem)
do_tabItem_widgetDisposed(e);
protected void do_tabItem_widgetDisposed(DisposeEvent e) {
protected void do_comboRecherche_widgetSelected(SelectionEvent e) {
protected void do_tabFolder_widgetSelected(SelectionEvent e) {
Result / Equipment Composite
package navigator;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
import com.swtdesigner.SWTResourceManager;
public class V_Equipment extends Composite implements SelectionListener,
KeyListener {
private Button btnRefresh;
static V_Equipment EquipmentCourant;
private Button btnAccess;
private Button btnComplet;
private Button btnOpen;
private Button btnModifyId;
private Button btnModifyModel;
private Button btnPassword;
private Button btnRestart;
private Button btnNoAccess;
private Group grpEquipment;
private Group grpStatistics;
String[] modeles;
private Table tblProfilTemporaire;
private Text txtAccesSysteme;
private Text txtCity;
private Text txtAigEtat;
private Text txtDernMessageRecu;
private Text txtDernMsgEnvoye;
private Text txtDetaillant;
private Text txtDistAdresseIP;
private Text txtDistErreurCode;
private Text txtDistErreurDesc;
private Text txtDistErreurTimestamp;
private Text txtDistEtat;
private Text txtDistId;
private Text txtDistNbErreurs;
private Text txtDistPort;
private Text txtDistTimestamp;
private Text txtFinOperation;
private Text txtIdAig;
private Text txtIdElectronic;
private Text txtIntersection;
private Text txtModel;
private Text txtNbMsgsEnvoyes;
private Text txtNbMsgsRecus;
private Text txtNoDetaillant;
private Text txtNoEquipment;
private Text txtProfilBase;
private Text txtResponsable;
private Text txtStatus;
private Text txtPhone;
private Text txtTransactionEnCours;
private Text txtUtilisation;
private Text txtCity2;
public V_Equipment(Composite parent, int style) {
EquipmentCourant = this;
gridLayout_1.verticalSpacing = 0;
gridLayout_1.marginWidth = 0;
gridLayout_1.marginHeight = 0;
gridLayout_1.horizontalSpacing = 0;
gridLayout.verticalSpacing = 0;
gridLayout.numColumns = 2;
grpEquipment = new Group(this, SWT.NONE);
grpEquipment.setLayout(gridLayout);
grpEquipment.setText("Équipment");
grpEquipment.setLayoutData(new GridData(GridData.FILL_HORIZONTAL
| GridData.VERTICAL_ALIGN_BEGINNING));
final Composite compositeInfoEquipment = new Composite(grpEquipment,
SWT.NONE);
compositeInfoEquipment.setLayoutData(new
GridData(GridData.FILL_HORIZONTAL));
final GridLayout gridLayout_8 = new GridLayout();
gridLayout_8.verticalSpacing = 0;
gridLayout_8.marginWidth = 0;
gridLayout_8.marginHeight = 0;
gridLayout_8.makeColumnsEqualWidth = true;
gridLayout_8.numColumns = 2;
compositeInfoEquipment.setLayout(gridLayout_8);
final Composite compositeDetailEquipment = new
Composite(compositeInfoEquipment, SWT.NONE);
compositeDetailEquipment.setLayoutData(new
final GridLayout gridLayout_6 = new GridLayout();
gridLayout_6.numColumns = 2;
compositeDetailEquipment.setLayout(gridLayout_6);
final Label lblNoEquipment = new Label(compositeDetailEquipment,
SWT.NONE);
lblNoEquipment.setText("No equipment");
txtNoEquipment = new Text(compositeDetailEquipment, SWT.READ_ONLY
| SWT.BORDER);
final GridData gridData = new GridData();
gridData.widthHint = 45;
txtNoEquipment.setLayoutData(gridData);
txtNoEquipment.setBackground(SWTResourceManager.getColor(
218, 218, 218));
final Label lblIdElectronic = new Label(compositeDetailEquipment,
SWT.RIGHT);
lblIdElectronic.setText("Id. electronic");
txtIdElectronic = new Text(compositeDetailEquipment, SWT.READ_ONLY
| SWT.BORDER);
gridData.widthHint = 50;
txtIdElectronic.setLayoutData(gridData);
txtIdElectronic.setBackground(SWTResourceManager
.getColor(218, 218, 218));
final Label modelLabel = new Label(compositeDetailEquipment,
SWT.NONE);
modelLabel.setText("Model");
txtModel = new Text(compositeDetailEquipment, SWT.READ_ONLY
| SWT.BORDER);
txtModel.setLayoutData(gridData);
txtModel.setBackground(SWTResourceManager.getColor(218,
218, 218));
final Label lblUtilisation = new Label(compositeDetailEquipment,
SWT.SHADOW_NONE);
lblUtilisation.setText("Utilisation");
txtUtilisation = new Text(compositeDetailEquipment, SWT.READ_ONLY
| SWT.BORDER);
gridData.widthHint = 90;
txtUtilisation.setLayoutData(gridData);
txtUtilisation.setBackground(SWTResourceManager.getColor(
218, 218, 218));
final Label lblStatus = new Label(compositeDetailEquipment, SWT.NONE);
lblStatus.setText("Status");
txtStatus = new Text(compositeDetailEquipment, SWT.READ_ONLY
| SWT.BORDER);
gridData.widthHint = 30;
txtStatus.setLayoutData(gridData);
txtStatus.setBackground(SWTResourceManager.getColor(218,
218, 218));
final Label lblEndOperation = new Label(compositeDetailEquipment,
SWT.NONE);
lblEndOperation.setText("End operation");
txtFinOperation = new Text(compositeDetailEquipment, SWT.READ_ONLY
| SWT.BORDER);
txtFinOperation.setLayoutData(gridData);
txtFinOperation.setBackground(SWTResourceManager.getColor(
218, 218, 218));
final Label lblProfilBase = new Label(compositeDetailEquipment,
SWT.NONE);
lblProfilBase.setText("Profil ");
txtProfilBase = new Text(compositeDetailEquipment, SWT.READ_ONLY
| SWT.BORDER);
gridData.widthHint = 150;
txtProfilBase.setLayoutData(gridData);
txtProfilBase.setBackground(SWTResourceManager.getColor(
218, 218, 218));
final Composite compositeDetail = new Composite(compositeInfoEquipment,
SWT.NONE);
compositeDetail.setLayoutData(new GridData(GridData.FILL_HORIZONTAL));
final GridLayout gridLayout_7 = new GridLayout();
gridLayout_7.marginRight = 10;
gridLayout_7.numColumns = 2;
compositeDetail.setLayout(gridLayout_7);
final Label lblNoDetail = new Label(compositeDetail,
SWT.RIGHT);
lblNoDetail.setText("No");
txtNoDetaillant = new Text(compositeDetail, SWT.READ_ONLY
| SWT.BORDER);
gridData.widthHint = 70;
txtNoDetaillant.setLayoutData(gridData);
txtNoDetaillant.setBackground(SWTResourceManager.getColor(
218, 218, 218));
final Label lblName = new Label(compositeDetail,
SWT.RIGHT);
lblName.setText("Name");
txtDetaillant = new Text(compositeDetail, SWT.READ_ONLY
| SWT.BORDER);
final GridData gridData = new GridData(GridData.FILL_HORIZONTAL);
txtDetaillant.setLayoutData(gridData);
txtDetaillant.setBackground(SWTResourceManager.getColor(
218, 218, 218));
final Label lblResponsible = new Label(compositeDetail,
SWT.NONE);
lblResponsible.setText("Responsable");
txtResponsable = new Text(compositeDetail, SWT.READ_ONLY
| SWT.BORDER);
txtResponsable.setLayoutData(new GridData(GridData.FILL_HORIZONTAL));
txtResponsable.setBackground(SWTResourceManager.getColor(
218, 218, 218));
final Label lblAddress = new Label(compositeDetail, SWT.RIGHT);
lblAddress.setText("Address");
txtCity = new Text(compositeDetail, SWT.READ_ONLY
| SWT.BORDER);
txtCity.setLayoutData(new GridData(GridData.FILL_HORIZONTAL));
txtCity.setBackground(SWTResourceManager.getColor(218,
218, 218));
final Label lblPadding = new Label(compositeDetail,
SWT.NONE);
txtCity2 = new Text(compositeDetail, SWT.READ_ONLY
| SWT.BORDER);
txtCity2.setLayoutData(new GridData(GridData.FILL_HORIZONTAL |
txtCity2.setBackground(SWTResourceManager.getColor(218,
218, 218));
final Label lblIntersecton = new Label(compositeDetail,
SWT.RIGHT);
lblIntersecton.setText("Intersection");
txtIntersection = new Text(compositeDetail, SWT.READ_ONLY
| SWT.BORDER);
txtIntersection.setLayoutData(new GridData(GridData.FILL_HORIZONTAL));
txtIntersection.setBackground(SWTResourceManager.getColor(
218, 218, 218));
final Label lblPhone = new Label(compositeDetail,
SWT.NONE);
lblPhone.setText("Phone");
txtPhone = new Text(compositeDetail, SWT.READ_ONLY
| SWT.BORDER);
gridData.widthHint = 144;
txtPhone.setLayoutData(gridData);
txtPhone.setBackground(SWTResourceManager.getColor(218,
218, 218));
final Group grpBoutonModification = new Group(grpEquipment,
SWT.NONE);
grpBoutonModification.setText("Modification");
GridData.HORIZONTAL_ALIGN_END | GridData.VERTICAL_ALIGN_FILL);
gridData_4.widthHint = 115;
grpBoutonModification.setLayoutData(gridData_4);
final GridLayout gridLayout_3 = new GridLayout();
gridLayout_3.marginHeight = 3;
gridLayout_3.verticalSpacing = 15;
grpBoutonModification.setLayout(gridLayout_3);
btnModifyModel = new Button(grpBoutonModification,
SWT.NONE);
btnModifyModel.setLayoutData(new GridData(
btnModifyModel.addSelectionListener(this);
btnModifyModel.setText("Model");
btnModifyId = new Button(grpBoutonModification,
SWT.NONE);
btnModifyId.setLayoutData(new GridData(
btnModifyId.addSelectionListener(this);
btnModifyId.setText("Id");
btnPassword = new Button(grpBoutonModification, SWT.NONE);
GridData.HORIZONTAL_ALIGN_FILL);
btnPassword.setLayoutData(gridData);
btnPassword.addSelectionListener(this);
btnPassword.setText("Password");
btnComplet = new Button(
grpBoutonModification, SWT.WRAP);
btnComplet.setLayoutData(gridData);
btnComplet.addSelectionListener(this);
btnComplet.setText("Complet");
grpStatistics = new Group(this, SWT.NONE);
grpStatistics.setText("Statistics");
gridLayout_3.marginWidth = 3;
gridLayout_3.verticalSpacing = 0;
gridLayout_3.numColumns = 2;
grpStatistics.setLayout(gridLayout_3);
grpStatistics.setLayoutData(new GridData(GridData.FILL_HORIZONTAL |
GridData.GRAB_VERTICAL | GridData.VERTICAL_ALIGN_BEGINNING));
final Group grpDistributor = new Group(grpStatistics,
SWT.NONE);
grpDistributor.setText("Distributor");
| GridData.VERTICAL_ALIGN_BEGINNING);
gridData.verticalSpan = 2;
grpDistributor.setLayoutData(gridData);
final GridLayout gridLayout_2 = new GridLayout();
gridLayout_2.verticalSpacing = 3;
gridLayout_2.marginHeight = 3;
gridLayout_2.numColumns = 6;
grpDistributor.setLayout(gridLayout_2);
final Label lblDistState = new Label(grpDistributor,
SWT.SHADOW_NONE);
final GridData gridData_1 = new GridData(GridData.GRAB_VERTICAL);
gridData_1.widthHint = 30;
lblDistState.setLayoutData(gridData_1);
lblDistState.setText("State");
txtDistEtat = new Text(grpDistributor, SWT.READ_ONLY
| SWT.BORDER);
txtDistEtat.setBackground(SWTResourceManager.getColor(
218, 218, 218));
gridData_1.widthHint = 90;
txtDistEtat.setLayoutData(gridData_1);
final Label lblDistId = new Label(grpDistributor,
SWT.NONE);
lblDistId.setLayoutData(new GridData(GridData.GRAB_VERTICAL));
lblDistId.setText("Id. Dist.");
txtDistId = new Text(grpDistributor, SWT.READ_ONLY
| SWT.BORDER);
txtDistId.setBackground(SWTResourceManager.getColor(
218, 218, 218));
gridData_1.widthHint = 20;
txtDistId.setLayoutData(gridData_1);
final Group grpIdSocket = new Group(grpDistributor,
SWT.NONE);
grpIdSocket.setText("Id. Socket");
GridData.GRAB_HORIZONTAL | GridData.HORIZONTAL_ALIGN_END);
gridData_1.verticalSpan = 2;
gridData_1.horizontalSpan = 2;
gridData_1.heightHint = 35;
grpIdSocket.setLayoutData(gridData_1);
final GridLayout gridLayout_4 = new GridLayout();
gridLayout_4.marginHeight = 3;
gridLayout_4.verticalSpacing = 3;
gridLayout_4.numColumns = 6;
grpIdSocket.setLayout(gridLayout_4);
final Label lblDistTimestamp = new Label(
grpIdSocket, SWT.NONE);
final GridData gridData_2 = new GridData(
lblDistTimestamp.setLayoutData(gridData_2);
lblDistTimestamp.setText("Timestamp");
txtDistTimestamp = new Text(grpIdSocket,
SWT.READ_ONLY | SWT.BORDER);
txtDistTimestamp.setBackground(SWTResourceManager
gridData_2.widthHint = 185;
txtDistTimestamp.setLayoutData(gridData_2);
final Label lblDistAddressIP = new Label(
lblDistAddressIP.setLayoutData(gridData_2);
lblDistAddressIP.setText("Address IP");
txtDistAdresseIP = new Text(grpIdSocket,
txtDistAdresseIP.setBackground(SWTResourceManager
gridData_2.widthHint = 115;
txtDistAdresseIP.setLayoutData(gridData_2);
final Label lblDistPort = new Label(grpIdSocket,
SWT.NONE);
lblDistPort.setLayoutData(gridData_2);
lblDistPort.setText("Port");
txtDistPort = new Text(grpIdSocket, SWT.READ_ONLY
| SWT.BORDER);
txtDistPort.setBackground(SWTResourceManager
gridData_2.widthHint = 50;
txtDistPort.setLayoutData(gridData_2);
final Group grpError = new Group(grpDistributor, SWT.NONE);
grpError.setText("Error");
final GridData gridData_5 = new GridData(
gridData_5.horizontalSpan = 5;
grpError.setLayoutData(gridData_5);
grpError.setLayout(gridLayout_4);
final Label lblDistErreurTimestamp = new Label(
grpError, SWT.NONE);
lblDistErreurTimestamp.setText("Timestamp");
txtDistErreurTimestamp = new Text(grpError,
txtDistErreurTimestamp.setBackground(SWTResourceManager
gridData_1.widthHint = 185;
txtDistErreurTimestamp.setLayoutData(gridData_1);
final Label lblDistErreurCode = new Label(grpError,
SWT.NONE);
lblDistErreurCode.setText("Code");
txtDistErreurCode = new Text(grpError, SWT.READ_ONLY
| SWT.BORDER);
txtDistErreurCode.setBackground(SWTResourceManager
final GridData gridData_3 = new GridData(
gridData_3.widthHint = 42;
txtDistErreurCode.setLayoutData(gridData_3);
final Label lblDistErreurDesc = new Label(grpError,
SWT.NONE);
lblDistErreurDesc.setText("Desc.");
txtDistErreurDesc = new Text(grpError, SWT.READ_ONLY
| SWT.BORDER);
txtDistErreurDesc.setBackground(SWTResourceManager
gridData_4.widthHint = 125;
txtDistErreurDesc.setLayoutData(gridData_4);
final Composite composite = new Composite(grpDistributor, SWT.NONE);
composite.setLayoutData(new GridData(GridData.HORIZONTAL_ALIGN_END));
final GridLayout gridLayout_5 = new GridLayout();
gridLayout_5.marginWidth = 8;
gridLayout_5.numColumns = 2;
composite.setLayout(gridLayout_5);
final Label lblDistNbErrors = new Label(
composite, SWT.NONE);
lblDistNbErrors.setText("Total errors");
txtDistNbErreurs = new Text(composite,
final GridData gridData_1 = new GridData();
gridData_1.widthHint = 50;
txtDistNbErreurs.setLayoutData(gridData_1);
txtDistNbErreurs.setBackground(SWTResourceManager
final Group grpControls = new Group(grpStatistics,
SWT.NONE);
grpControls.setText("Controls");
final GridData gridData_6 = new GridData(
GridData.HORIZONTAL_ALIGN_FILL | GridData.VERTICAL_ALIGN_FILL);
gridData_6.widthHint = 115;
gridData_6.verticalSpan = 3;
grpControls.setLayoutData(gridData_6);
gridLayout_5.marginHeight = 3;
gridLayout_5.verticalSpacing = 15;
grpControls.setLayout(gridLayout_5);
btnAccess = new Button(grpControls, SWT.NONE);
btnAccess.setLayoutData(new GridData(
btnAccess.addSelectionListener(this);
btnAccess.setText("Access");
btnNoAccess = new Button(grpControls, SWT.NONE);
btnNoAccess.addSelectionListener(this);
btnNoAccess.setLayoutData(new GridData(
btnNoAccess.setText("No access");
btnRestart = new Button(grpControls, SWT.NONE);
btnRestart.addSelectionListener(this);
btnRestart.setLayoutData(new GridData(
btnRestart.setText("Restart");
btnOpen = new Button(grpControls, SWT.NONE);
btnOpen.addSelectionListener(this);
btnOpen.setLayoutData(new GridData(
btnOpen.setText("Open");
final Group grpSwitch = new Group(grpStatistics,
SWT.NONE);
gridLayout_2.horizontalSpacing = 10;
gridLayout_2.numColumns = 7;
grpSwitch.setLayout(gridLayout_2);
final GridData gridData = new GridData(GridData.FILL_BOTH);
grpSwitch.setLayoutData(gridData);
grpSwitch.setText("Switch");
final Label lblState = new Label(grpSwitch, SWT.NONE);
final GridData gridData_4 = new GridData();
gridData_4.widthHint = 30;
lblState.setLayoutData(gridData_4);
lblState.setText("State");
txtAigEtat = new Text(grpSwitch, SWT.READ_ONLY
| SWT.BORDER);
txtAigEtat.setBackground(SWTResourceManager.getColor(
218, 218, 218));
gridData_1.widthHint = 75;
txtAigEtat.setLayoutData(gridData_1);
final Label lblIdAig = new Label(grpSwitch,
SWT.NONE);
lblIdAig.setText("Id. Aig.");
txtIdAig = new Text(grpSwitch, SWT.READ_ONLY
| SWT.BORDER);
txtIdAig.setBackground(SWTResourceManager.getColor(218,
218, 218));
gridData_1.widthHint = 25;
txtIdAig.setLayoutData(gridData_1);
final Label lblDernMessageRecu = new Label(
gridData_1.horizontalIndent = 110;
lblDernMessageRecu.setLayoutData(gridData_1);
lblDernMessageRecu.setText("Last msg");
txtDernMessageRecu = new Text(grpSwitch,
txtDernMessageRecu.setBackground(SWTResourceManager
gridData_1.widthHint = 135;
txtDernMessageRecu.setLayoutData(gridData_1);
final Composite composite = new Composite(grpSwitch, SWT.NONE);
final GridData gridData_2 = new GridData(GridData.GRAB_HORIZONTAL |
GridData.HORIZONTAL_ALIGN_END | GridData.VERTICAL_ALIGN_BEGINNING);
gridData_2.verticalSpan = 3;
composite.setLayoutData(gridData_2);
gridLayout_4.marginWidth = 0;
gridLayout_4.marginRight = 8;
gridLayout_4.marginHeight = 0;
gridLayout_4.numColumns = 2;
composite.setLayout(gridLayout_4);
final Label nbMsgsReceivedLabel = new Label(composite, SWT.NONE);
nbMsgsReceivedLabel.setText("Nb msgs received");
txtNbMsgsRecus = new Text(composite, SWT.READ_ONLY
| SWT.BORDER);
GridData(GridData.HORIZONTAL_ALIGN_END);
txtNbMsgsRecus.setLayoutData(gridData_1);
txtNbMsgsRecus.setBackground(SWTResourceManager
final Label nbMsgsSentLabel = new Label(composite, SWT.NONE);
nbMsgsSentLabel.setText("Nb msgs sent");
txtNbMsgsEnvoyes = new Text(composite,
txtNbMsgsEnvoyes.setData("nom", "txtNbMsgsEnvoyes");
txtNbMsgsEnvoyes.setLayoutData(gridData_1);
txtNbMsgsEnvoyes.setBackground(SWTResourceManager
final Label transLabel = new Label(composite, SWT.NONE);
transLabel.setText("Trans.");
txtTransactionEnCours = new Text(composite,
txtTransactionEnCours.setLayoutData(gridData_1);
txtTransactionEnCours.setBackground(SWTResourceManager
final Label accessLabel = new Label(grpSwitch, SWT.NONE);
accessLabel.setLayoutData(gridData_1);
accessLabel.setText("Access");
txtAccesSysteme = new Text(grpSwitch, SWT.READ_ONLY
| SWT.BORDER);
txtAccesSysteme.setBackground(SWTResourceManager
gridData_1.widthHint = 70;
txtAccesSysteme.setLayoutData(gridData_1);
final Label lastMsgSentLabel = new Label(grpSwitch, SWT.NONE);
lastMsgSentLabel.setLayoutData(gridData_1);
lastMsgSentLabel.setText("Last msg sent");
txtDernMsgEnvoye = new Text(grpSwitch,
txtDernMsgEnvoye.setBackground(SWTResourceManager
txtDernMsgEnvoye.setLayoutData(gridData_1);
final Label profilLabel = new Label(grpSwitch, SWT.NONE);
profilLabel.setLayoutData(gridData_1);
profilLabel.setText("Profil");
tblProfilTemporaire = new Table(grpSwitch,
SWT.FULL_SELECTION | SWT.BORDER);
tblProfilTemporaire.setBackground(SWTResourceManager
| GridData.FILL_VERTICAL);
gridData_3.widthHint = 396;
gridData_3.horizontalSpan = 4;
gridData_3.heightHint = 50;
tblProfilTemporaire.setLayoutData(gridData_3);
tblProfilTemporaire.setHeaderVisible(true);
final TableColumn colProfilNom = new TableColumn(
tblProfilTemporaire, SWT.NONE);
colProfilNom.setWidth(73);
colProfilNom.setText("Nom");
final TableColumn colProfilDescription = new TableColumn(
colProfilDescription.setWidth(166);
colProfilDescription.setText("Description");
final TableColumn colProfilAssignation = new TableColumn(
colProfilAssignation.setResizable(false);
colProfilAssignation.setWidth(174);
colProfilAssignation.setText("Assignation");
btnRefresh = new Button(grpStatistics, SWT.NONE);
btnRefresh.addSelectionListener(this);
GridData(GridData.HORIZONTAL_ALIGN_CENTER);
gridData.widthHint = 105;
btnRefresh.setLayoutData(gridData);
btnRefresh.setText("Refresh");
super.dispose();
SWTResourceManager.disposeColors();
Current Time: Sun Jul 27 02:06:02 EDT 2025
Powered by FUDForum. Page generated in 0.07125 seconds
