Home » Language IDEs » Java Development Tools (JDT) » Problems with Java runtime
Problems with Java runtime [message #8401] Tue, 29 April 2003 07:27 Go to next message
Originally posted by: kanele.gmx.de
I cannot start my eclipse environment on Windows 2000 because :-?
Anyway, the error message is as follows:
Pressing the eclipse button brings up
"JVM terminated. Exit code=2
C:\winnt\system32\javaw.exe
-cp C:\Apps\eclipse\startup.jar.org.eclipse.org.launcher.Main
-os win32
-ws win32
-arch x86
-showsplash C:\Apps\eclipse\eclipse.exe -showsplash 600"
Does somebody can tell me what it means or what is wrong?
Does javaw use the rt.jar? I ask because I do several of it (1.4.1, 1.3)
on the machine.
For any hint thankyou!
Re: Problems with Java runtime [message #8464 is a reply to message #8401] Tue, 29 April 2003 08:53 Go to previous message
From the Eclipse FAQ
(http://www.eclipse.org/eclipse/faq/eclipse-faq.html#users_3)
Once you have installed a Java developer kit, you can use the -vm command
line argument to launch eclipse. For example, if you have installed a Java
developer kit in c:\jdk1.3, you can launch eclipse with the following
command line:
eclipse.exe -vm c:\jdk1.3\bin\javaw.exe
HTH
Darins
"christian kanele" <kanele@gmx.de> wrote in message
news:b8lnil$p5h$1@rogue.oti.com...
> -os win32
> -ws win32
> -arch x86
> on the machine.
Previous Topic:CVS: All files are out of sync from time to time
Next Topic:2.2 and JDT AST
Current Time: Sat Aug 30 21:27:41 EDT 2025
Powered by FUDForum. Page generated in 0.03378 seconds
