| [ATL]How to get an attribute which is defined in another file [message #93322] |
Mon, 27 October 2008 09:20  |
I met such a problem:
I want to select a "propertyDefinition" from the "propertyAssociation",
the propertyDefinition is referenced to another file, see the XML file
below.
I write a helper, but it seems there is some problem, I cannot get the
identified "propertyDefinition", it always returns empty .
Is there anything I made wrong?
Or how could I get such an attribute which is automatically defined in
another file?
helper context core!ThreadImpl def: ThreadPeriodIsDefined(): Boolean =
if self.properties.propertyAssociation.oclIsUndefined()
then false
else self.properties.propertyAssociation-> collect(a|
a.propertyDefinition) -> select(b|b.name = 'Period') ->
flatten()->notEmpty()
endif;
<threadImpl name="client_thread.impl" compType="#//@threadType.0">
<properties>
<propertyAssociation noMode="false"
propertyDefinition=" ../../../plugin/edu.cmu.sei.osate.workspace/resources/proper ties/AADL_Properties.aaxl#//@propertySet.0/@propertyDefiniti on.48 "
constant="false" access="false" append="false" derived="false">
<propertyValue xsi:type="property:EnumValue"
enumLiteral=" ../../../plugin/edu.cmu.sei.osate.workspace/resources/proper ties/AADL_Project.aaxl#//@propertySet.0/@propertyType.3/@enu mLiteral.0 "/>
</propertyAssociation>
propertyDefinition=" ../../../plugin/edu.cmu.sei.osate.workspace/resources/proper ties/AADL_Properties.aaxl#//@propertySet.0/@propertyDefiniti on.65 "
<propertyValue xsi:type="property:IntegerValue"
unitLiteral=" ../../../plugin/edu.cmu.sei.osate.workspace/resources/proper ties/AADL_Project.aaxl#//@propertySet.0/@propertyType.9/@uni tLiteral.3 "
valueString="100" value="100" base="10"/>
</properties>
</threadImpl>
| Re: [ATL]How to get an attribute which is defined in another file [message #93437 is a reply to message #93422] |
Tue, 28 October 2008 11:04  |
I tried this explicitly load, but then an exception occurs:
The class 'PropertyType' is not a valid classifier
But I checked the model, all the validation is OK.
I don't know whether it's caused by the format of the aaxl file or some
internal error.
Does anyone have met a similar probloem? How to resolve it?
Thank you in advance.
regards
Yue
Freddy Allilaire a écrit :
> All your models should be loaded. In your case, I think
> AADL_Properties.aaxl should be added in the launch configuration.
> Freddy.
> yue a écrit :
>> "propertyAssociation", the propertyDefinition is referenced to another
>> file, see the XML file below.
>> another file?
>> then false
>> endif;
>> <properties>
>> </properties>
>> </threadImpl>
FUDForum. Page generated in 0.04797 seconds
