| A weird result [message #93110] |
Thu, 23 October 2008 02:56  |
Originally posted by: behnaz.cwi.nl
Hi everyone,
I have an strang problem with ATL. Can't figure out why two completely
similar rules (well just different in from part) end up with different
result task2FIFO and sequenceEdge2primitive:
module bpmn2reo;
create OUT : reo from IN : bpmn;
helper context bpmn!Activity def : TaskWithInOutEdges(inEdgeNo :
Integer, outEdgeNo : Integer) : Boolean =
self.incomingEdges->asSequence()->size() = inEdgeNo and
self.outgoingEdges->asSequence()->size() = outEdgeNo;
helper context bpmn!SequenceEdge def : ConnectedToFIFO : Boolean =
self.source.TaskWithInOutEdges(1, 1) or
self.target.TaskWithInOutEdges(1, 1);
rule diagram2module
from
bd : bpmn!BpmnDiagram
to
m : reo!Module(name <- bd.name, connectors <- bd.pools)
rule pool2connetor
from
p :bpmn!Pool-------------(p.refImmediateComposite().pools->includes(p))
to
c : reo!Connector(name<-p.name, nodes<-p.vertices, primitives <-
p.sequenceEdges)
rule task2FIFO
from
a : bpmn!Activity(a.TaskWithInOutEdges(1, 1))
to
n : reo!FIFO(sourceEnds <- c, sinkEnds <- k),
c : reo!SourceEnd(node <- a.incomingEdges.at(1).source),
k : reo!SinkEnd(node <- a.outgoingEdges.at(1).target)
rule sequenceEdge2primitive
from
q : bpmn!SequenceEdge(not q.ConnectedToFIFO)
to
y : reo!Sync(sourceEnds <- c, sinkEnds <- k),
c : reo!SourceEnd(node <- q.source),
k : reo!SinkEnd(node <- q.target)
rule task2node
from
a : bpmn!Activity(not a.TaskWithInOutEdges(1, 1))
to
n : reo!Node(name <- a.name + ' rule: task2node')
| Re: A weird result [message #93307 is a reply to message #93145] |
Mon, 27 October 2008 04:03  |
Dear Freddy,
Thanks for your help. It is resolved now.
Behnaz
Freddy Allilaire wrote:
> Hi Benhnaz,
> Could you give more details concerning your problem?
> Freddy.
> Behnaz a écrit :
>> Hi everyone,
>> module bpmn2reo;
>> rule diagram2module
>> from
>> to
>> rule pool2connetor
>> from
>> p
>> to
>> p.sequenceEdges)
>> rule task2FIFO
>> from
>> to
>> from
>> to
>> k : reo!SinkEnd(node <- q.target) }
>> rule task2node
>> from
>> to
FUDForum. Page generated in 0.03842 seconds
