Home » Language IDEs » ServerTools (WTP) » JBoss 3.2.6 problem
JBoss 3.2.6 problem [message #93079] Tue, 19 April 2005 07:38 Go to next message
Hi all; i'm tring to create a generic server definition for JBoss 3.2.6; i
have created these files:
jboss326.server:
<tns:ServerRuntime
xmlns:tns="http://eclipse.org/jst/server/generic/ServerTypeDefinition"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://eclipse.org/jst/server/generic/ServerTypeDef
inition ServerTypeDefinitionSchema.xsd "
name="JBOSS 3.2.6" version="v3.2.6">
<property id="serverRootDirectory"
label="Application Server Directory:"
type="directory"
context="runtime"
default="/your_server_root/appservers/jboss-3.2.6" />
<property id="serverAddress"
label="Address:"
type="string"
context="server"
default="127.0.0.1" />
<property id="port"
label="Port:"
type="string"
context="server"
default="8080" />
<property id="serverConfig"
label="Server Configuration (minimal/default/all):"
type="string"
context="server"
default="default" />
<property id="classPath"
label="Classpath Variable:"
type="directory"
context="runtime"
<port>
<no>${port}</no>
<name>Http</name>
<protocol>http</protocol>
</port>
<module>
<type>j2ee.web</type>
<publishDir>${serverRootDirectory}/server/
${serverConfig}/deploy</publishDir>
<publisherReference>org.eclipse.jst.server.generic.antpublisher </publis
herReference>
</module>
<module>
<type>j2ee.ejb</type>
herReference>
</module>
<project>
<classpathReference>jboss.project</classpathReference>
</project>
<start>
<class>org.jboss.Main</class>
<workingDirectory>${serverRootDirectory}/bin</workingDirectory >
<programArguments>-c ${serverConfig}</programArguments>
<vmParameters></vmParameters>
<classpathReference>jboss</classpathReference>
</start>
<stop>
<class>org.jboss.Shutdown</class>
<programArguments>-S</programArguments>
</stop>
<publisher id="org.eclipse.jst.server.generic.antpublisher">
<publisherdata>
<dataname>build.file</dataname>
<datavalue>/buildfiles/jboss326.xml</datavalue>
</publisherdata>
<publisherdata>
<dataname>target.publish.j2ee.web</dataname>
<datavalue>deploy.j2ee.web</datavalue>
</publisherdata>
<publisherdata>
<dataname>target.publish.j2ee.ejb</dataname>
<datavalue>deploy.j2ee.ejb</datavalue>
</publisherdata>
<publisherdata>
<dataname>target.unpublish.j2ee.web</dataname>
<datavalue>undeploy.j2ee.web</datavalue>
</publisherdata>
<publisherdata>
<dataname>target.unpublish.j2ee.ejb</dataname>
<datavalue>undeploy.j2ee.ejb</datavalue>
</publisherdata> </publisher>
<classpath id="jboss" isLibrary="true">
<archive path="${classPath}/bin/run.jar" />
<archive path="${classPath}/bin/shutdown.jar" />
<archive path="${classPath}/client/jboss-j2ee.jar" />
<archive path="${classPath}/server/
${serverConfig}/deploy/jbossweb-tomcat50.sar/servlet-api.jar " />
<archive path="${classPath}/lib/jboss-system.jar" />
<archive path="${classPath}/lib/concurrent.jar" />
${serverConfig}/lib/jboss.jar" />
${serverConfig}/lib/jnpserver.jar" />
<archive path="${classPath}/server/${serverConfig}/lib/jpl-
pattern.jar" />
util.jar" />
<archive path="${classPath}/server/${serverConfig}/lib/jboss-
transaction.jar" />
${serverConfig}/lib/bcel.jar" />
<archive path="${classPath}/lib/dom4j.jar" />
<archive path="${classPath}/lib/xercesImpl.jar" />
<archive path="${classPath}/lib/xml-apis.jar" />
<archive path="${classPath}/lib/gnu-regexp.jar" />
<archive path="${classPath}/lib/getopt.jar" />
</classpath>
<classpath id="jboss.project" isLibrary="false">
</classpath>
</tns:ServerRuntime>
jboss326.xml:
<project name="deployextension" default="deploy.j2ee.web" basedir=".">
<target name="deploy.j2ee.web">
<jar destfile="${module.name}.war">
<zipfileset dir="${module.dir}">
<include name="**/*.*"/>
<exclude name="**/*.war"/>
</zipfileset>
</jar>
<move file="${module.name}.war" todir="${server.publish.dir}"/>
</target>
<target name="deploy.j2ee.ejb">
<jar destfile="${module.name}.jar">
<exclude name="**/*.java"/>
<exclude name="**/*.jar"/>
</zipfileset>
</jar>
<move file="${module.name}.jar" todir="${server.publish.dir}"/>
</target>
<target name="undeploy.j2ee.web">
<delete file="${server.publish.dir}/${module.name}.war">
</delete>
</target>
<target name="undeploy.j2ee.ejb">
<delete file="${server.publish.dir}/${module.name}.jar">
</delete>
</target></project>
Then i have updated my plugin.xml:
<?eclipse version="3.0"?>
<plugin
id="org.eclipse.jst.server.generic.serverdefinitions"
name="Serverdefinitions Plug-in"
version="1.0.0"
provider-name="Eclipse.org"
class=" org.eclipse.jst.server.generic.serverdefinitions.Serverdefin itionsPlugin
<runtime>
<library name="serverdefinitions.jar">
<export name="*"/>
</library>
</runtime>
<requires>
<import plugin="org.eclipse.core.runtime"/>
<import plugin="org.eclipse.jst.server.generic.core"/>
</requires>
<extension point="org.eclipse.jst.server.generic.core.serverdefinition ">
<serverdefinition id="Weblogic8.1"
definitionfile="/servers/weblogic81.server">
</serverdefinition>
<serverdefinition id="JBoss 3.2.3"
definitionfile="/servers/jboss323.server">
</serverdefinition>
<serverdefinition id="Jonas 4.1.4"
definitionfile="/servers/jonas.server">
</serverdefinition>
<serverdefinition id="JBoss 3.2.6"
definitionfile="/servers/jboss326.server">
</serverdefinition> </extension>
</plugin>
I haved inserted these file into these directory:
in
$ECLIPSE_HOME/plugins/org.eclipse.jst.server.generic.serverd efinitions_1.0.0
i have inserted plugin.xml
In
$ECLIPSE_HOME/plugins/org.eclipse.jst.server.generic.serverd efinitions_1.0.0/se
rvers i have inserted jboss326.server
in
$ECLIPSE_HOME/plugins/org.eclipse.jst.server.generic.serverd efinitions_1.0.0/bu
ildfiles i have inserted jboss326.xml
After these operation i have started eclipse and by selecting:
Window -> Preferences -> Server -> Installed Runtime -> add -> all ->
Generic
Server Runtime -> next in the server types combo box i'm not able to see the
JBoss 3.2.6 definition... i can see only Weblogic 8.1, JBoss 3.2.3 and JonAS
4.1.4. This is my environment:
Windows XP Home edition SP2, wtp-eclipse-prereqs-sdk-1.0M3-win32 (downloaded
form web tools home site), Java SDK1.4.2._07.
Am i wrong or is not this operation supported?
Re: JBoss 3.2.6 problem [message #93248 is a reply to message #93079] Tue, 19 April 2005 17:34 Go to previous messageGo to next message
Originally posted by: gercan.REMOVEME.acm.org
Hi Angelo,
Everything seems in order, I am changing the mechanism for defining a
new server definition quite a bit for M4. May I suggest that you try
your server definition in M4.
Gorkem Ercan
> jboss326.server:
> <tns:ServerRuntime
> type="directory"
> context="runtime"
> label="Address:"
> type="string"
> context="server"
> <property id="port"
> label="Port:"
> type="string"
> context="server"
> default="8080" />
> type="string"
> context="server"
> type="directory"
> context="runtime"
> <port>
> <no>${port}</no>
> <name>Http</name>
> </port>
> <module>
> herReference>
> </module>
> <module>
> herReference>
> </module>
> <project>
> </project>
> <start>
> </start>
> <stop>
> </stop>
> <publisherdata>
> </publisherdata>
> <publisherdata>
> </publisherdata>
> <publisherdata>
> </publisherdata>
> <publisherdata>
> </publisherdata>
> <publisherdata>
> pattern.jar" />
> util.jar" />
> transaction.jar" />
> </classpath>
> </classpath>
> jboss326.xml:
> </zipfileset>
> </jar>
> </target>
> </zipfileset>
> </jar>
> </target>
> </delete>
> </target>
> </delete>
> </target></project>
> <plugin
> version="1.0.0"
> <runtime>
> <export name="*"/>
> </library>
> </runtime>
> <requires>
> </requires>
> </serverdefinition>
> </serverdefinition>
> </serverdefinition>
> </plugin>
> in
> In
> in
> Generic
> Thanks
Re: JBoss 3.2.6 problem [message #93381 is a reply to message #93248] Wed, 20 April 2005 12:23 Go to previous messageGo to next message
Hi Gorkem.
First of all thanks for your answer. I wanted to know.... where can i
download the M4? I have seen the web tools project and it seems to me very
very interesting but i must use JBoss 3.2.6 (later also 4.0 but now
3.2.6)... i can't use tomcat 5.0 also because i need to write several EJB
and i don't want to use several eclipse plugin.
"Gorkem Ercan" <gercan@REMOVEME.acm.org> ha scritto nel messaggio
news:42657957.2080408@REMOVEME.acm.org...
> Hi Angelo,
> Everything seems in order, I am changing the mechanism for defining a new
> server definition quite a bit for M4. May I suggest that you try your
> Gorkem Ercan
>> i
>> jboss326.server:
>> <?xml version="1.0" encoding="UTF-8"?>
>> <tns:ServerRuntime
>> type="directory"
>> context="runtime"
>> label="Address:"
>> type="string"
>> context="server"
>> <property id="port"
>> label="Port:"
>> type="string"
>> context="server"
>> default="8080" />
>> type="string"
>> context="server"
>> type="directory"
>> context="runtime"
>> <port>
>> <no>${port}</no>
>> <name>Http</name>
>> </port>
>> <module>
>> herReference>
>> </module>
>> <module>
>> herReference>
>> </module>
>> <project>
>> </project>
>> <start>
>> </start>
>> <stop>
>> </stop>
>> <publisherdata>
>> </publisherdata>
>> <publisherdata>
>> </publisherdata>
>> <publisherdata>
>> </publisherdata>
>> <publisherdata>
>> </publisherdata>
>> <publisherdata>
>> pattern.jar" />
>> util.jar" />
>> transaction.jar" />
>> </classpath>
>> </classpath>
>> jboss326.xml:
>> </zipfileset>
>> </jar>
>> </target>
>> </zipfileset>
>> </jar>
>> </target>
>> </delete>
>> </target>
>> </delete>
>> </target></project>
>> <plugin
>> version="1.0.0"
>> <runtime>
>> <export name="*"/>
>> </library>
>> </runtime>
>> <requires>
>> </requires>
>> <extension
>> </serverdefinition>
>> </serverdefinition>
>> </serverdefinition>
>> </plugin>
>> in
>> In
>> in
>> Generic
>> the
>> JonAS
>> (downloaded
>> Thanks
Re: JBoss 3.2.6 problem [message #95568 is a reply to message #93248] Wed, 27 April 2005 14:43 Go to previous messageGo to next message
Originally posted by: dominic_mailhot.videotron.ca
Gorkem, Angelo,
I need to do the same for jBoss 4.0.2.. Where can I find the instructions
to do that before M4? Can you also tell me what will be part of M4 wrt
servers definition??
"Gorkem Ercan" <gercan@REMOVEME.acm.org> wrote in message
> Hi Angelo,
> Gorkem Ercan
>> i
>> jboss326.server:
>> <tns:ServerRuntime
>> type="directory"
>> context="runtime"
>> label="Address:"
>> type="string"
>> context="server"
>> <property id="port"
>> label="Port:"
>> type="string"
>> context="server"
>> default="8080" />
>> type="string"
>> context="server"
>> type="directory"
>> context="runtime"
>> <port>
>> <no>${port}</no>
>> <name>Http</name>
>> </port>
>> <module>
>> herReference>
>> </module>
>> <module>
>> herReference>
>> </module>
>> <project>
>> </project>
>> <start>
>> </start>
>> <stop>
>> </stop>
>> <publisherdata>
>> </publisherdata>
>> <publisherdata>
>> </publisherdata>
>> <publisherdata>
>> </publisherdata>
>> <publisherdata>
>> </publisherdata>
>> <publisherdata>
>> pattern.jar" />
>> util.jar" />
>> transaction.jar" />
>> </classpath>
>> </classpath>
>> jboss326.xml:
>> </zipfileset>
>> </jar>
>> </target>
>> </zipfileset>
>> </jar>
>> </target>
>> </delete>
>> </target>
>> </delete>
>> </target></project>
>> <plugin
>> version="1.0.0"
>> <runtime>
>> <export name="*"/>
>> </library>
>> </runtime>
>> <requires>
>> </requires>
>> <extension
>> </serverdefinition>
>> </serverdefinition>
>> </serverdefinition>
>> </plugin>
>> in
>> In
>> in
>> Generic
>> the
>> JonAS
>> (downloaded
>> Thanks
Re: JBoss 3.2.6 problem [message #100035 is a reply to message #95568] Fri, 06 May 2005 06:38 Go to previous messageGo to next message
Originally posted by: webmaster.forentersoft.com
Hi all :-)
I have the same problems!
"Dominic Mailhot" <dominic_mailhot@videotron.ca> wrote in message
news:d4ommk$pse$1@news.eclipse.org...
> Gorkem, Angelo,
> Thanks
> > Hi Angelo,
new
> > Gorkem Ercan
3.2.6;
> >> i
> >> jboss326.server:
> >> <tns:ServerRuntime
> >> type="directory"
> >> context="runtime"
> >> label="Address:"
> >> type="string"
> >> context="server"
> >> <property id="port"
> >> label="Port:"
> >> type="string"
> >> context="server"
> >> default="8080" />
> >> type="string"
> >> context="server"
> >> type="directory"
> >> context="runtime"
> >> <port>
> >> <no>${port}</no>
> >> <name>Http</name>
> >> </port>
> >> <module>
> >> herReference>
> >> </module>
> >> <module>
> >> herReference>
> >> </module>
> >> <project>
> >> </project>
> >> <start>
> >> </start>
> >> <stop>
> >> </stop>
> >> <publisherdata>
> >> </publisherdata>
> >> <publisherdata>
> >> </publisherdata>
> >> <publisherdata>
> >> </publisherdata>
> >> <publisherdata>
> >> </publisherdata>
> >> <publisherdata>
> >> pattern.jar" />
> >> util.jar" />
> >> transaction.jar" />
> >> </classpath>
> >> </classpath>
> >> jboss326.xml:
basedir=".">
> >> </zipfileset>
> >> </jar>
> >> </target>
> >> </zipfileset>
> >> </jar>
> >> </target>
> >> </delete>
> >> </target>
> >> </delete>
> >> </target></project>
> >> <plugin
> >> version="1.0.0"
gin
> >> <runtime>
> >> <export name="*"/>
> >> </library>
> >> </runtime>
> >> <requires>
> >> </requires>
> >> <extension
> >> </serverdefinition>
> >> </serverdefinition>
> >> </serverdefinition>
> >> </plugin>
> >> in
> >> In
/se
> >> in
/bu
> >> Generic
see
> >> the
> >> JonAS
> >> (downloaded
> >> Thanks
Re: JBoss 3.2.6 problem [message #100300 is a reply to message #100035] Fri, 06 May 2005 12:43 Go to previous message
Try to use these files
"Darius" <webmaster@forentersoft.com> ha scritto nel messaggio
news:d5fhbl$h3r$1@news.eclipse.org...
> Hi all :-)
>> Gorkem, Angelo,
>> instructions
>> Thanks
>> > Hi Angelo,
> new
>> > Gorkem Ercan
> 3.2.6;
>> >> i
>> >> jboss326.server:
>> >> <tns:ServerRuntime
>> >> type="directory"
>> >> context="runtime"
>> >> label="Address:"
>> >> type="string"
>> >> context="server"
>> >> <property id="port"
>> >> label="Port:"
>> >> type="string"
>> >> context="server"
>> >> default="8080" />
>> >> type="string"
>> >> context="server"
>> >> type="directory"
>> >> context="runtime"
>> >> <port>
>> >> <no>${port}</no>
>> >> <name>Http</name>
>> >> </port>
>> >> <module>
>> >> herReference>
>> >> </module>
>> >> <module>
>> >> herReference>
>> >> </module>
>> >> <project>
>> >> </project>
>> >> <start>
>> >> </start>
>> >> <stop>
>> >> </stop>
>> >> <publisherdata>
>> >> </publisherdata>
>> >> <publisherdata>
>> >> </publisherdata>
>> >> <publisherdata>
>> >> </publisherdata>
>> >> <publisherdata>
>> >> </publisherdata>
>> >> <publisherdata>
>> >> pattern.jar" />
>> >> util.jar" />
>> >> transaction.jar" />
>> >> </classpath>
>> >> </classpath>
>> >> jboss326.xml:
> basedir=".">
>> >> </zipfileset>
>> >> </jar>
>> >> </target>
>> >> </zipfileset>
>> >> </jar>
>> >> </target>
>> >> </delete>
>> >> </target>
>> >> </delete>
>> >> </target></project>
>> >> <plugin
>> >> version="1.0.0"
> gin
>> >> <runtime>
>> >> <export name="*"/>
>> >> </library>
>> >> </runtime>
>> >> <requires>
>> >> </requires>
>> >> <extension
>> >> </serverdefinition>
>> >> </serverdefinition>
>> >> </serverdefinition>
>> >> </plugin>
>> >> in
>> >> In
> /se
>> >> in
> /bu
>> >> Generic
> see
>> >> the
>> >> JonAS
>> >> (downloaded
>> >> Thanks
Previous Topic:Bugzilla Bug 84843
Next Topic:Define custom mapping for package to namespace
Current Time: Fri Nov 07 22:22:37 EST 2025
Powered by FUDForum. Page generated in 0.06863 seconds
