| extending the Diagram notation interface [message #92974] |
Mon, 15 January 2007 14:31  |
Originally posted by: NOSAPM.xyz.com
Hello everybody,
I extended the Diagram because I need to introduce some additional
references.
Is it possible to hook the new "MyDiagram" EClass by means of the tooling?
The only point I could think of is in the .gmfgen - the Diagram Element /
Diagram Run Time Class
property of the "Gen Diagram XXXEditPart" .
I loaded my new notational .ecore in the .gmfgen and expected the new
"MyDiagram" type to
appear as a choice in the said "Diagram Run Time Class" combo. It didn't,
however : (
Whet is the right way to hook a new Diagram notation type to the generated
editor?
By the way, in that "Diagram Run Time Class" combo one can choose between
the
Ecore types ( EClassifier, EObject ...) and notation types ( View, Edge
Isn't this misleading? Does "Diagram Run Time Class" mean the ruin-time
class of
the semantic element or the view element?
Theo
| Re: extending the Diagram notation interface [message #93047 is a reply to message #93032] |
Mon, 15 January 2007 15:56  |
"Theo" <NOSAPM@xyz.com> wrote in message
news:eognm4$kut$1@utils.eclipse.org...
> news:eogmif$ikt$1@utils.eclipse.org...
>> Hello everybody,
>> references.
>> tooling?
>> "MyDiagram" type to
>> however : (
>> generated editor?
>> the
>> class of
>> Cheers,
>> Theo
> Just got it myself: one have to "Load resource" both the .ecore anf the
> .genmodel
> with the new extension. But still, why both semantic and notation types
> appear in
> "Diagram Run Time Class" property in the .gmfgen?
> Theo
Not so fast with champagne... The .gmfgen accepts and validates the notation
extension but the editors generated by the .gmfgen with :
1) Diagram Run Time Class = Diagram-> View
and
2) Diagram Run Time Class = MyDiagram-> Diagram
are identical byte by byte.
I expected that XXXDiagramViewFactory.createDiagram( ...) would be
overriden...
I guess I will have to face the truth :) - apparently such a feature simply
isn'i supported yet and "Diagram Run Time Class" is just a placeholder
Good luck, Theo
FUDForum. Page generated in 0.03027 seconds
