Home » Modeling » GMF (Graphical Modeling Framework) » extending the Diagram notation interface
extending the Diagram notation interface [message #92974] Mon, 15 January 2007 14:31 Go to next message
Originally posted by: NOSAPM.xyz.com
Hello everybody,
I extended the Diagram because I need to introduce some additional
references.
Is it possible to hook the new "MyDiagram" EClass by means of the tooling?
The only point I could think of is in the .gmfgen - the Diagram Element /
Diagram Run Time Class
property of the "Gen Diagram XXXEditPart" .
I loaded my new notational .ecore in the .gmfgen and expected the new
"MyDiagram" type to
appear as a choice in the said "Diagram Run Time Class" combo. It didn't,
however : (
Whet is the right way to hook a new Diagram notation type to the generated
editor?
By the way, in that "Diagram Run Time Class" combo one can choose between
the
Ecore types ( EClassifier, EObject ...) and notation types ( View, Edge
Isn't this misleading? Does "Diagram Run Time Class" mean the ruin-time
class of
the semantic element or the view element?
Theo
Re: extending the Diagram notation interface [message #93032 is a reply to message #92974] Mon, 15 January 2007 15:20 Go to previous messageGo to next message
"Theo" <NOSAPM@xyz.com> wrote in message
news:eogmif$ikt$1@utils.eclipse.org...
> Hello everybody,
> references.
> "MyDiagram" type to
> however : (
> editor?
> the
> class of
> Cheers,
> Theo
Just got it myself: one have to "Load resource" both the .ecore anf the
..genmodel
with the new extension. But still, why both semantic and notation types
appear in
"Diagram Run Time Class" property in the .gmfgen?
Theo
Re: extending the Diagram notation interface [message #93047 is a reply to message #93032] Mon, 15 January 2007 15:56 Go to previous message
news:eognm4$kut$1@utils.eclipse.org...
>> Hello everybody,
>> references.
>> tooling?
>> "MyDiagram" type to
>> however : (
>> generated editor?
>> the
>> class of
>> Cheers,
>> Theo
> .genmodel
> appear in
> Theo
Not so fast with champagne... The .gmfgen accepts and validates the notation
extension but the editors generated by the .gmfgen with :
1) Diagram Run Time Class = Diagram-> View
and
2) Diagram Run Time Class = MyDiagram-> Diagram
are identical byte by byte.
I expected that XXXDiagramViewFactory.createDiagram( ...) would be
overriden...
I guess I will have to face the truth :) - apparently such a feature simply
isn'i supported yet and "Diagram Run Time Class" is just a placeholder
Good luck, Theo
Previous Topic:Adding more tabs in property view in GMF
Next Topic:Arrows
Current Time: Thu Oct 30 22:53:07 EDT 2025
Powered by FUDForum. Page generated in 0.04139 seconds
