arm-elf toolshain [message #92947] |
Thu, 29 January 2004 11:00  |
Originally posted by: jesperk.privat.dk
I'm a new user who is trying to set-up CDT as the IDE for the cross-tools
arm-elf-gcc and arm-elf-gdb among others. I have these running under cygwin.
After studing the documentation I have come to the conclution that i need to
generate a new plug-in for this toolchain.
I have done the tutorial on the subject and everything seens to be OK. What
I'm looking for is the plugin for the standart toolchain (gcc,gdb..) that I
can load into the plug-in development inviroment as an example on how to set
up a complete toolchain with verious compilers,linkers and all that stuff.
I am of the impression that I can more or less just edit this plug-in to use
arm-elf-xxx instead of just xxx tools. Can anyone give me directions to
these standart plug-in's for both compiler and debugger.
Thanks Jesper.
Re: arm-elf toolshain [message #94629 is a reply to message #92947] |
Wed, 18 February 2004 14:34  |
Originally posted by: d89-ahg.ludd.luth.se
I might be missing the point, but under Linux, there is no need for a new
plugin. (CDT 2.1.? )In the makefile you write - specify the compiler. In the
debug-as menu, you can specify the remote debugger (assuming you have an
arm-target running a gdb-server connected either through internet or
serial.) The userinterface is buggy though, but we are currently
demonstrating this on the following hardware: www.excito.com
regards
Anders Hedberg, www.addcore.com
"Jesper Kjeldsen" <jesperk@privat.dk> wrote in message
news:bvbae7$qhg$1@eclipse.org...
cygwin.
to
What
I
set
use
> Thanks Jesper.
FUDForum. Page generated in 0.07598 seconds
