| Cascading parameters [message #92746] |
Fri, 18 November 2005 13:15  |
Hi All;
Can anyoine point me to some docs and/or samples for making cascading
parameters work? I'm using BIRT 2.0 M2 and can see UI features in the
designer, but they are not working as I would expect and I don;t know if
it's because I'm using them wrong or if the functionality isn't complete
in the M2 release.
The steps I've taken are roughly:
* Right click on report parms and select "New Cascading Parameter"
* I can create the nested parameters, but expected the value from the
first query to be used as the input value to the 2nd parameter's data set
query.
* The designer UI seems to overwrite the data set source for the first
paramter with the one I specify for the second.
* Does this mean that both parameters must use the same data set source?
Any help appreciated.
Pete H
FUDForum. Page generated in 0.03702 seconds
