Home » Eclipse Projects » Eclipse Platform » Upgrade strategies
Upgrade strategies [message #92325] Fri, 11 July 2003 21:50 Go to next message
Greetings -
I wanted to share my only significant frustration with Eclipse after a
year and half of using it with the group. That is, upgrades. They are a
pain. The usual routine I find myself doing is:
(1) Download the latest release, unzip it, and drop it in a shared
directory for all my eclipse versions. Looks like this:
+-usr/
+-local/
+-eclipse/
+-eclipse
+-eclipse-2.0
+-eclipse-2.1
+-eclipse-2.1.1
+-eclipse-3.0-M1
+-current -> eclipse-2.1.1
+-features -> current/features
+-plugins -> current/plugins
+-workspace
where /usr/local/eclipse/eclipse is a shell script:
(cd /usr/local/eclipse/current; \
./eclipse -data /usr/local/eclipse/workspace &)
(2) Back-up workspace
(3) Copy plugins that I custom installed from current/plugins to the new
version's plugin directory; repeat with features
(4) rm current; ln -s eclipse-3.0-M1 current
(5) run ./eclipse and pray to god that nothing broke
Many times I have had to blow away workspace/.metadata and reconstruct
projects; sometimes have had to blow away even the .project files in
each module. Many times the plugins fail so I will have to retrieve
more recent versions. At least it forces me to keep current.
Things are getting worse now that I have multiple workspace directories
here and there.
Is anyone else manageing to make this process easier? Am I missing some
crucial thing that would simplify my life 100 times. Are there any
plans to apply the Update Manager to the core and plugins of Eclipse
itself ("Physician, heal thy self" vs "The shoemaker's children"
syndrome). I for one would love to see the latter. Netbeans at least
had it (did not always work, but hey! you take what you can get).
Jeffrey Bonevich
Ann Arbor, Michigan
bonevich at covad dot net
jeff at bonevich dot com
http://www.bonevich.com
"Make me a fire and I'm warm for a night. Set me
on fire and I'm warm for the rest of my life."
- Ancient Didactical Saying
Re: Upgrade strategies [message #92658 is a reply to message #92325] Sat, 12 July 2003 19:34 Go to previous messageGo to next message
Originally posted by: oshteynbuk.nyc.rr.com
You can use Ant script at
http://home.nyc.rr.com/olegs/eclipse/antscript/readme.htm
It does what you have described and a little bit more.
oleg
Jeffrey Bonevich wrote:
> Greetings -
> +-usr/
> +-local/
> +-eclipse/
> +-eclipse
> +-eclipse-2.0
> +-eclipse-2.1
> +-eclipse-2.1.1
> +-eclipse-3.0-M1
> +-workspace
> here and there.
Re: Upgrade strategies [message #92794 is a reply to message #92658] Sun, 13 July 2003 16:03 Go to previous messageGo to next message
Oleg -
Thanx for the info. I was thinking along these lines too, glad someone
else beat me to it.
Too bad no one from the actual development/project side has responded
with an appropriate strategy that Eclipse plans to address. I will have
to locate the thread you mentioned at your site.
jeff
> oleg
>> Greetings -
>> a pain. The usual routine I find myself doing is:
>> +-usr/
>> +-local/
>> +-eclipse/
>> +-eclipse
>> +-eclipse-2.0
>> +-eclipse-2.1
>> +-eclipse-2.1.1
>> +-eclipse-3.0-M1
>> +-workspace
>> new version's plugin directory; repeat with features
>> directories here and there.
>> some crucial thing that would simplify my life 100 times. Are there
>> any plans to apply the Update Manager to the core and plugins of
>> Eclipse itself ("Physician, heal thy self" vs "The shoemaker's
>> children" syndrome). I for one would love to see the latter.
>> Netbeans at least had it (did not always work, but hey! you take what
>> you can get).
Jeffrey Bonevich
Ann Arbor, Michigan
Re: Upgrade strategies [message #92854 is a reply to message #92325] Mon, 14 July 2003 04:14 Go to previous message
> Greetings -
> a pain.
I filed a feature request for Update Manager to allow time
stamp/non-version based updates a while ago:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=29776
This could ease updating a lot but it was closed as wontfix. I added
some comments below which might help to improve your update process a bit.
> +-usr/
> +-local/
> +-eclipse/
> +-eclipse
> +-eclipse-2.0
> +-eclipse-2.1
> +-eclipse-2.1.1
> +-eclipse-3.0-M1
> +-workspace
1. Put all your custom plug-ins at one location outside the Eclipse
install tree (e.g. C:/eclipse/customPlugins) and keep them there.
2. Create a file called .link with the following content:
path=C:/eclipse/customPlugins
3. Create a batch file that starts eclipse but before starting, creates
a folder called "links" into the eclipse root directory and then copies
above .link file into "links" folder
NOTE: Plug-ins which you put into C:/eclipse/customPlugins must be in
eclipse/plugins, e.g.:
C:/eclipse/customPlugins/eclipse/plugins/<myCustomPlugin1>
Well you could leave that step away since you might want to go back to
that version and disk space is cheap anyway ;-)
Well I'm developing on the newest builds every week and I think the only
time when I threw my workspace away was because I decided to do so (to
get to a clean and fresh state).
There's now also a workspace restorer plug-in that should help you in
such situations.
HTH
Dani
Previous Topic:GUI locks up when running a custom made plug-in java program
Next Topic:CVS Replace with
Current Time: Tue Aug 19 22:18:45 EDT 2025
Powered by FUDForum. Page generated in 0.08320 seconds
