Home » Language IDEs » ServerTools (WTP) » Problems working with modules
Problems working with modules [message #92264] Thu, 14 April 2005 14:49
Originally posted by: mugwai2.icogitate.com
Hi. I have been trying to play with some of the new module framework in
the latest integration builds, and have run into some problems. Can
someone help, or are these just intermittent issues to be solved in the
next builds? Should I enter these into bugzilla, or should bugzilla only
refer to bugs in the official M builds? The latest build I tried is
I20050413:
1. After creating a flex project with a server, the server page in
project properties shows no server selected -- instead the page is blank
with a "this project cannot be deployed to a server" message.
2. (Before having seen above problem) When building a flex project with
a web module, and adding an ejb, the following error comes up during
build: (I specified Servlet 2.4 as the servlet spec for web module --
this is the default, but my server for the project was JBoss 3.2.3)
BUILD FAILED
C:\eclipse\test_workspace\.metadata\.plugins\org.eclipse.jst .common.launcher.ant\tempAnt.xml:66:
2.4 is not a legal value for this attribute
3. XDoclet no longer seems to generate server specific descriptors --
maybe this is related to problem #1 above?
4. (minor) The "Specify class file destination" page of the "Create
EnterpriseJavaBean" wizard has a "Generate an annotated servlet class"
checkbox -- I think that's a type-o for "annotated java class"
Thanks a lot for any help
-Helen
Previous Topic:minimum files
Next Topic:Some module usage related questions
Current Time: Fri Nov 07 08:27:43 EST 2025
Powered by FUDForum. Page generated in 0.03536 seconds
