Home » Newcomers » Newcomers » Update Existing Plugin
Update Existing Plugin [message #92226] Thu, 04 August 2005 14:53
How do you update an existing plugin?
I have the plugin in for the XML parser xerces_2.6.2 installed as a
pluring in my Eclipse 3.1 version. However, I have found a bug in that
version of xerces and need to upgrade to the newer version (2.7.1) of
xerces. If I install and copy the plugin to my plugin directory then I
have both plugins appearing in my plugin list. Should I then delete the
older plugin out of the directory?
Is there any side affects for doing this?
Ben
Previous Topic:cannot find org.eclipse.swt.widgets. files
Next Topic:Problem with Plug-in Development Tutorial
Current Time: Sat Jul 26 10:35:09 EDT 2025
Powered by FUDForum. Page generated in 0.10497 seconds
