Home » Newcomers » Newcomers » Eclipse 3.1 failing on install
Eclipse 3.1 failing on install [message #92198] Thu, 04 August 2005 13:45 Go to next message
Originally posted by: dhogancamp.ruger.com
I have just installed 3.1 on my computer at work. When I try launching
eclipse I receive an error "An error has occured. See the logfile
c:\eclipse 3.1\Configuration\1123177302467.log
When I look in that file it says:
SSION Thu Aug 04 13:41:42 EDT 2005
!ENTRY org.eclipse.core.launcher 4 0 2005-08-04 13:41:42.483
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.RuntimeException: Could not find framework
at org.eclipse.core.launcher.Main.getBootPath(Main.java:635)
at org.eclipse.core.launcher.Main.basicRun(Main.java:272)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Can anyone help me make sense of it?
Thanks in advance
Dwight
Re: Eclipse 3.1 failing on install [message #92212 is a reply to message #92198] Thu, 04 August 2005 14:23 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
This error usually indicates that the Eclipse zip file was not unpacked
properly. Check the eclipse directory to see if there are features and
plugins directories, etc. Try unzipping it again, or redownloading the
zip if it is corrupted.
Hope this helps,
- Jeff
> !STACK
> Thanks in advance
> Dwight
Re: Eclipse 3.1 failing on install [message #92242 is a reply to message #92212] Thu, 04 August 2005 15:02 Go to previous messageGo to next message
I used winzip and extracted the download file. It appears there are still
alot of sub-zip files. Is there an option on the extract that makes it
extract in more detail?
Dwight
"Jeff Myers" <myersj@gmail.com> wrote in message
news:dctmh5$2pe$1@news.eclipse.org...
> Hope this helps,
> - Jeff
>> 2005 ------------------------------------------
>> !STACK
>> Thanks in advance
>> Dwight
Re: Eclipse 3.1 failing on install [message #92481 is a reply to message #92242] Fri, 05 August 2005 06:57 Go to previous message
Originally posted by: info.ecosol24.de
You have to unzip this with the original folder structure ... not only
all files in one folder...
You can set this option in winzip.
Holger
-------- Original-Nachricht --------
> Dwight
>>Hope this helps,
>> - Jeff
>>>!STACK
>>>Thanks in advance
>>>Dwight
Previous Topic:WTP Install From Update Site?
Next Topic:Using external diff tool
Current Time: Fri Nov 07 08:27:35 EST 2025
Powered by FUDForum. Page generated in 0.09645 seconds
