NullPointerException when running more tests with tptp:execution ANT task [message #91987] |
Wed, 31 January 2007 03:44  |
I have a problem (NPE) when running more tests with tptp:execution ANT task.
ANT task:
<tptp:execution deployment="runner/headlessDeployment.deploy"
resultsrefid="tptp.test.results">
<fileset dir="${project.dir}">
<include name="**/*.testsuite"/>
</fileset>
</tptp:execution>
I use Eclipse 3.2.1, TPTP 4.3.0, Java 1.5.0.
Has anyone faced this problem? Have I missed something? Is there any
workaround to avoid this? Can anyone help?
Karel
OUTPUT:
test.execution:
[echo] Executing test suite
adding file src\tptp\demo\test\MathTestCase.testsuite
adding file src\tptp\demo\test\extended\ExtendedMathTestCase.testsuite
Test started!
Test 'src\tptp\demo\test\MathTestCase.testsuite' executing
Waiting....
Collected results:
'org.eclipse.hyades.models.common.testprofile.impl.TPFExecut ionResultImpl @1493995
(eProxyURI:
platform:/resource/tptp.demo.test/MathTestCase_1170231666375 .execution#D382C493A8652AC283932A50ADD911DB)'
Test 'src\tptp\demo\test\MathTestCase.testsuite' completed
Test 'src\tptp\demo\test\extended\ExtendedMathTestCase.testsuite' executing
org.eclipse.hyades.test.tools.core.internal.plugin.util.Work benchLocationUtil.getPropertyValue(WorkbenchLocationUtil.jav a:155)
org.eclipse.hyades.test.tools.core.internal.plugin.util.Work benchLocationUtil.getUseDefaultPlugins(WorkbenchLocationUtil .java:325)
org.eclipse.hyades.test.tools.core.internal.plugin.util.Work benchLocationUtil.getExternalPlugins(WorkbenchLocationUtil.j ava:313)
org.eclipse.hyades.test.tools.core.internal.plugin.harness.W orkbenchExecutionDeploymentAdapter.collectTestSuiteFiles(Wor kbenchExecutionDeployment
Adapter.java:173)
org.eclipse.hyades.execution.harness.JavaExecutionDeployment Adapter.collectDeployableArtifacts(JavaExecutionDeploymentAd apter.java:324)
org.eclipse.hyades.execution.harness.JavaExecutionDeployment Adapter.collectDeployableFiles(JavaExecutionDeploymentAdapte r.java:240)
org.eclipse.hyades.test.tools.core.internal.plugin.harness.W orkbenchExecutionDeploymentAdapter.collectDeployableFiles(Wo rkbenchExecutionDeploymen
tAdapter.java:110)
org.eclipse.hyades.execution.harness.JavaExecutionDeployment Adapter.deployTestAssets(JavaExecutionDeploymentAdapter.java :468)
org.eclipse.hyades.test.tools.core.internal.plugin.harness.W orkbenchExecutionDeploymentAdapter.deployTestAssets(Workbenc hExecutionDeploymentAdapt
er.java:106)
org.eclipse.hyades.execution.harness.util.ExecutionAdapterUt ilities.adaptExecutionDeployment(ExecutionAdapterUtilities.j ava:159)
org.eclipse.hyades.execution.harness.TestExecutionHarness.la unchTestExecution(TestExecutionHarness.java:1973)
org.eclipse.hyades.execution.harness.TestExecutionHarness.ac cess$3(TestExecutionHarness.java:1817)
org.eclipse.hyades.execution.harness.TestExecutionHarness$2. run(TestExecutionHarness.java:741)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
org.eclipse.core.runtime.CoreException: IWAT4039E The Test Execution Harness
reported the following problems:java.lang.NullPointerException
org.eclipse.hyades.test.core.launch.delegates.AbstractLaunch ConfigurationDelegate2.launch(AbstractLaunchConfigurationDel egate2.java:197)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:639)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:565)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:558)
org.eclipse.hyades.test.core.services.AbstractTestExecutionS ervice.launch(AbstractTestExecutionService.java:615)
org.eclipse.hyades.test.core.services.AbstractTestExecutionS ervice.execute(AbstractTestExecutionService.java:425)
org.eclipse.hyades.automation.server.AbstractService.execute (AbstractService.java:43)
org.eclipse.hyades.automation.server.ServiceProxy$1.run(Serv iceProxy.java:140)
org.eclipse.hyades.automation.core.utils.ReusableThread.run( ReusableThread.java:131)
at java.lang.Thread.run(Unknown Source)
BUILD FAILED
Re: NullPointerException when running more tests with tptp:execution ANT task [message #98604 is a reply to message #91987] |
Mon, 14 May 2007 08:14  |
Hi Karel,
This is a problem with not having any workbench properties for your
location. Can you try the latest release (4.3.1) to see if the problem has
since been resolved?
If not, please open a defect
( https://bugs.eclipse.org/bugs/enter_bug.cgi?classification=T PTP >> TPTP
Testing >> Test.Execution) with any relevant information including your
configuration and this stack trace?
Paul
"Karel Brezina" <karel.brezina@cloudsmith.com> wrote in message
news:eppksl$f7n$1@utils.eclipse.org...
> task.
> ANT task:
> </fileset>
> </tptp:execution>
> Karel
> OUTPUT:
> test.execution:
> Test started!
> Waiting....
> Collected results:
> (eProxyURI:
> executing
> at
> at
> at
> at
> Adapter.java:173)
> at
> at
> at
> tAdapter.java:110)
> at
> at
> er.java:106)
> at
> at
> at
> at
> Harness reported the following problems:java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> BUILD FAILED
FUDForum. Page generated in 0.04309 seconds
