Home » Language IDEs » ServerTools (WTP) » Exception creating Web Services example
Exception creating Web Services example [message #91941] Wed, 13 April 2005 14:53 Go to next message
Whenever I try to generate a web services project, I get an error dialog
whose exception is below. I have installed using the bundled Eclipse/WTP
and added all the external jars per instructions:
IWAB0213E Error in starting server.
org.eclipse.core.runtime.CoreException[0]:
org.eclipse.core.runtime.CoreException: Could not load the Tomcat server
configuration at \Servers\Tomcat v5.0 Server @ localhost-config. The
configuration may be corrupt or incomplete.
org.eclipse.jst.server.tomcat.core.internal.Tomcat50Configur ation.load(Tomcat50Configuration.java:257)
org.eclipse.jst.server.tomcat.core.internal.TomcatServer.get TomcatConfiguration(TomcatServer.java:81)
org.eclipse.jst.server.tomcat.core.internal.TomcatServer.sav eConfiguration(TomcatServer.java:115)
org.eclipse.wst.server.core.internal.ServerWorkingCopy.save( ServerWorkingCopy.java:243)
org.eclipse.wst.server.core.internal.ServerWorkingCopy.saveA ll(ServerWorkingCopy.java:255)
org.eclipse.jst.ws.internal.common.ServerUtils.modifyModules (ServerUtils.java:151)
org.eclipse.jst.ws.internal.consumption.command.common.Creat eWebProjectCommand.execute(CreateWebProjectCommand.java:161)
org.eclipse.jst.ws.internal.consumption.command.common.Creat eServiceProjectCommand.execute(CreateServiceProjectCommand.j ava:138)
org.eclipse.wst.command.env.core.fragment.CommandFragmentEng ine.runCommand(CommandFragmentEngine.java:322)
org.eclipse.wst.command.env.core.fragment.CommandFragmentEng ine.visitTop(CommandFragmentEngine.java:288)
org.eclipse.wst.command.env.core.fragment.CommandFragmentEng ine.moveForwardToNextStop(CommandFragmentEngine.java:208)
org.eclipse.wst.command.env.ui.widgets.SimpleCommandEngineMa nager$4.run(SimpleCommandEngineManager.java:206)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:344)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:289)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 824)
org.eclipse.wst.command.env.ui.widgets.SimpleCommandEngineMa nager.runForwardToNextStop(SimpleCommandEngineManager.java:1 75)
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.runForwardToNextStop(WizardPageManager.java:69)
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.getNextPage(WizardPageManager.java:91)
org.eclipse.wst.command.internal.env.ui.widgets.SimpleWizard Page.getNextPage(SimpleWizardPage.java:123)
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:741)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:338)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:543)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2908)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2541)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:718 )
at org.eclipse.jface.window.Window.open(Window.java:696)
org.eclipse.wst.command.internal.env.ui.widgets.popup.Dynami cPopupWizard.run(DynamicPopupWizard.java:123)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:244)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:557)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:507)
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:421)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1612)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1578)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:293)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:333)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:150)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:268 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:260)
at org.eclipse.core.launcher.Main.run(Main.java:887)
at org.eclipse.core.launcher.Main.main(Main.java:871)
Re: Exception creating Web Services example [message #92049 is a reply to message #91941] Thu, 14 April 2005 03:53 Go to previous messageGo to next message
I had this problem
The only way I got around it was to make sure no instances of tomcat were
running - that icluded stopping the tomcat service
"Cameron Bateman" <cbateman@rim.com> wrote in message
news:c5b05c8eac75815d1023b9489e867612$1@www.eclipse.org...
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Exception creating Web Services example [message #92181 is a reply to message #91941] Thu, 14 April 2005 14:04 Go to previous messageGo to next message
> Eclipse/WTP and added all the external jars per instructions:
Can you tell us how to generate a "web services project"...I can't find
any tutorials that are simple and relate to the WTP ( I know it's brand
new ) -- everything seems really out of date.
Re: Exception creating Web Services example [message #92221 is a reply to message #92181] Thu, 14 April 2005 14:38 Go to previous messageGo to next message
The tutorial is entitled "Top Down Web Service Tutorial". It is under the
tutorials section available from the WTP top-level project page. The link
is
http://www.eclipse.org/webtools/jst/components/ws/tutorials/ TopDownWebService.html.
--Cam
Re: Exception creating Web Services example [message #92235 is a reply to message #92049] Thu, 14 April 2005 14:33 Go to previous messageGo to next message
plork123 wrote:
> Hi
> I had this problem
Ok, I think we're on the same page now.
I'm seeing the same exact error.
I'm using this tutorial : http://eclipse.org/webtools/index.html
The error is occuring at the the "Service Deployment Configuration"
property sheet.
I installed the 5.0 version ( latest ) of Tomcat.
It seems up and running on my XP Pro workstation -- so I don't know why
Eclipse is having trouble running it. I installed the java JRE 1.5 as
well.
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Re: Exception creating Web Services example [message #92251 is a reply to message #92221] Thu, 14 April 2005 14:39 Go to previous messageGo to next message
> the tutorials section available from the WTP top-level project page.
> The link is
One thing I notice is that at the top of the
"Service Deployment Configuration" section there is a warning message:
The project, converter, has a server target which is not compatible with
the selected server type.
My configuration is:
Server Side Deployment
Web service Runtime: Apache Axis 1.1
Server: Tomcat v.5.0 Server
J2EE Version: 1.4
Service Project: converter
Client-Side Environment Selection:
Web Service Runtime: Apache Axis 1.1
Server: Tomcat Server v5.0 Server
J2EE version: 1.4
Client type: Web
Client project: converter
Re: Exception creating Web Services example [message #92996 is a reply to message #92049] Mon, 18 April 2005 22:25 Go to previous message
plork123 wrote:
> Hi
> I had this problem
I tried your suggestion by stopping tomcat from Windows Services, but
received the exact same error message.
Is that what you mean when you say "stopping the tomcat service" ?
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Previous Topic:Server start and stop inmediatly
Next Topic:org.apache.axis.*
Current Time: Sun Jun 22 03:26:00 EDT 2025
Powered by FUDForum. Page generated in 0.31953 seconds
