Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Fail to reload model
Fail to reload model [message #91919] Thu, 26 July 2007 12:18 Go to next message
Originally posted by: kaiyup.optiosoftware.com
I upgraded to eclipse 3.3 and EMF 2.3 from 3.2 and 2.2. When I reload the
model and click Finish, I got the following exception in the log and the
dialog showing:
org.eclipse.emf.ecore.xmi.DanglingHREFException: The object
'org.eclipse.emf.ecore.impl.EClassImpl@15898ce (name:
EStringToEStringMapEntry) (instanceClassName: java.util.Map$Entry)
(abstract: false, interface: false)' is not contained in a resource.
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.handleDanglingH REF(XMLHelperImpl.java:759)
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.getHREF(XMLHelp erImpl.java:793)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveEObjectSingle (XMLSaveImpl.java:1796)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1240)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:2590)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:1105)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:986)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedMany (XMLSaveImpl.java:2291)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1464)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.writeTopObject(XM LSaveImpl.java:653)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:581)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:253)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:205)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:1253)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.saveOnlyIfC hangedWithMemoryBuffer(ResourceImpl.java:1083)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:956)
org.eclipse.emf.importer.ModelImporter.saveGenModelAndEPacka ges(ModelImporter.java:770)
org.eclipse.emf.importer.ui.contribution.base.ModelImporterW izard.doPerformFinish(ModelImporterWizard.java:150)
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rWizard$1.execute(ModelConverterWizard.java:228)
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:101)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1797)
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:113)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 934)
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rWizard.performFinish(ModelConverterWizard.java:246)
org.eclipse.emf.importer.ui.contribution.base.ModelImporterW izard.performFinish(ModelImporterWizard.java:157)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:742)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:373)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:616)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:227)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
org.eclipse.emf.converter.ui.OpenWizardActionDelegate.run(Op enWizardActionDelegate.java:115)
org.eclipse.emf.converter.ui.OpenWizardActionDelegate.run(Op enWizardActionDelegate.java:105)
org.eclipse.ui.actions.ActionDelegate.runWithEvent(ActionDel egate.java:70)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:246)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:545)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
!ENTRY org.eclipse.emf.converter 2 0 2007-07-26 12:03:43.499
!MESSAGE
!STACK 0
java.lang.reflect.InvocationTargetException
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:116)
Caused by: org.eclipse.core.runtime.CoreException: An error occurred while
performing this operation.
org.eclipse.emf.common.util.DiagnosticException.toCoreExcept ion(DiagnosticException.java:47)
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rWizard$1.execute(ModelConverterWizard.java:235)
... 46 more
Root exception:
org.eclipse.core.runtime.CoreException: An error occurred while performing
this operation.
org.eclipse.core.runtime.CoreException[2048]:
org.eclipse.emf.common.util.DiagnosticException: An error occurred while
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rWizard$1.execute(ModelConverterWizard.java:234)
Caused by: org.eclipse.emf.ecore.resource.Resource$IOWrappedException: The
object 'org.eclipse.emf.ecore.impl.EClassImpl@1f3ad7 (name:
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.endSave(XMLSaveIm pl.java:303)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:267)
... 49 more
Caused by: org.eclipse.emf.ecore.xmi.DanglingHREFException: The object
... 56 more
Re: Fail to reload model [message #91936 is a reply to message #91919] Thu, 26 July 2007 12:41 Go to previous message
Kaiyu,
This is an EMF question best asked on the EMF newsgroup. I'd need to be
able to reproduce your problem to help. What is the source of your
model that you are reloading, i.e., is it an Ecore model, Java @model
annotations, XML Schema, UML2, or Rose? If it's Ecore, try opening the
..ecore file and invoking "Validate..." on the root EPackage...
> dialog showing:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 46 more
> Root exception:
> this operation.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 49 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 56 more
Re: Fail to reload model [message #608937 is a reply to message #91919] Thu, 26 July 2007 12:41 Go to previous message
Kaiyu,
> dialog showing:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !MESSAGE
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 46 more
> Root exception:
> this operation.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 49 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 56 more
Previous Topic:Fail to reload model
Next Topic:[Teneo] can't deserialize EObjects which contain Teneo proxies
Current Time: Sat Nov 08 07:18:26 EST 2025
Powered by FUDForum. Page generated in 0.02996 seconds
