Home » Archived » BIRT » I need change the connection of the database JDBC HSQLDB
I need change the connection of the database JDBC HSQLDB [message #91891] Thu, 17 November 2005 05:50 Go to next message
Hello to all,
I write an application using the swt library and the Jface. I use as
database HSQLDB driver. In my project I runs the database engine as part
of my application program in the same Java Virtual Machine, so i used:
"Connection c =
DriverManager.getConnection("jdbc:hsqldb:file:mydatabase", "sa", "");"
to connect with the db.
Now I like to integrate in my application the BIRT project, the problem
is that I don't know how connect with the db. In jasper report I used :
JasperPrintManager.printReport(
JasperFillManager.fillReport(jasperReport, parameters,
DbConnection.getReference().getConnection()) , true);
where DbConnection.getReference().getConnection() is the method that
return the Connection with my Standalone db. So i hope there is a
similar method with BIRD project. Can anybody help me?
Thanks to all
Stefano
Re: I need change the connection of the database JDBC HSQLDB [message #92178 is a reply to message #91891] Thu, 17 November 2005 11:34 Go to previous messageGo to next message
Stefano,
BIRT has a set of APIs to run a BIRT report. When the Engine runs a report
it looks for the connection information in the design file, which is
typically built in the designer. BIRT also has an API to manipulate the
Design File. I may be misunderstanding what you want.
Are you trying to run a report with the APIs? Are you trying to pass in a
preexisting connection?
Jason Weathersby
BIRT PMC
"Stefano Zaccaria" <szaccaria@cedacosrl.it> wrote in message
news:dlhn90$8pg$1@news.eclipse.org...
> Hello to all,
> "Connection c = DriverManager.getConnection("jdbc:hsqldb:file:mydatabase",
> "sa", "");"
> Now I like to integrate in my application the BIRT project, the problem is
> JasperPrintManager.printReport( JasperFillManager.fillReport(jasperReport,
> parameters, DbConnection.getReference().getConnection()) , true);
> return the Connection with my Standalone db. So i hope there is a similar
> Thanks to all
> Stefano
Re: I need change the connection of the database JDBC HSQLDB [message #92248 is a reply to message #92178] Thu, 17 November 2005 12:27 Go to previous messageGo to next message
Jason Weathersby ha scritto:
> Stefano,
> Jason Weathersby
> BIRT PMC
>> Hello to all,
>> "sa", "");"
>> Thanks to all
>> Stefano
Yes, and I can
>Are you trying to pass in a preexisting connection?
Yes but I don't how
Re: I need change the connection of the database JDBC HSQLDB [message #92294 is a reply to message #92248] Thu, 17 November 2005 13:06 Go to previous messageGo to next message
Stefano,
I dont think passing in a connection is supported. You can use the DE API
to write it to the design file. Using a Scripted Data Source you could
probably get a prexisting connection object, but this may be more pain than
it is worth. You could also use script to change connection parameters at
run time, if that is the ultimate goal.
Jason
news:dliehi$eng$1@news.eclipse.org...
>> Stefano,
>> report it looks for the connection information in the design file, which
>> is typically built in the designer. BIRT also has an API to manipulate
>> the Design File. I may be misunderstanding what you want.
>> Jason Weathersby
>> BIRT PMC
>>> Hello to all,
>>> "Connection c =
>>> Thanks to all
>>> Stefano
> Yes, and I can
> Yes but I don't how
Re: I need change the connection of the database JDBC HSQLDB [message #92427 is a reply to message #92294] Fri, 18 November 2005 02:37 Go to previous messageGo to next message
> Stefano,
Thanks Jason,
I'll try to use the script to change the connection parameters... so
an other small request O:-) : You have some idea for to do this?
If yes, I will be recognizing to you.
Stefano
Re: I need change the connection of the database JDBC HSQLDB [message #92442 is a reply to message #92427] Fri, 18 November 2005 02:46 Go to previous messageGo to next message
--------------020407000207010405080109
You excuse to me ,
I found this link
http://www.eclipse.org/birt/wiki/index.php?n=BPS.BPS35,
there is script:
/Some examples of the types of external context objects that may be
passed through to a BIRT data source provider include: /
* /An open JDBC connection /
* /A pooled connection /
* /User authorization keys /
* /Query parameter values collected outside of BIRT/
what do you think about?
Ciao
Stefano
<html>
<head>
http-equiv="Content-Type">
</head>
You excuse to me ,<br>
Re: I need change the connection of the database JDBC HSQLDB [message #92623 is a reply to message #92442] Fri, 18 November 2005 10:11 Go to previous message
------=_NextPart_000_001C_01C5EC28.627FB230
charset="ISO-8859-15"
Stefano,
From the FAQ
Is it possible getting database's information from a DataSource? object =
with the API?
Gary Xue=20
The best way to achieve this is to edit the beforeOpen script of the =
data source object to set the runtime information of the data source. To =
do this, right click on your JDBC data source and select "Edit Code". In =
the method dropdown list, select "beforeOpen". In the code editor, write =
a script like this:=20
=20
extensionProperties.odaUser =3D "sesame";
extensionProperties.odaPassword =3D "open";
extensionProperties.odaURL =3D "jdbc:my_data_source:....";
extensionProperties.odaDriverClass =3D "com.mycompany.jdbc.Driver";
=20
Refer to the BIRT ROM scripting spec for more information about =
scripting ingeneral. The names of the properties that you can set =
(odaUser, odaPassword, etc.) are defined by the ODA extension. The =
BIRT-shipped ODA-JDBC driver extension recognizes the above 4 =
properties.=20
Jason Weathersby
BIRT PMC
"Stefano Zaccaria" <szaccaria@cedacosrl.it> wrote in message =
news:dlk0sr$esc$1@news.eclipse.org...
You excuse to me ,
I found this link=20
http://www.eclipse.org/birt/wiki/index.php?n=3DBPS.BPS35,=20
there is script:
Some examples of the types of external context objects that may be =
passed through to a BIRT data source provider include:=20
a.. An open JDBC connection=20
b.. A pooled connection=20
c.. User authorization keys=20
d.. Query parameter values collected outside of BIRT=20
Ciao
Stefano
<HTML><HEAD>
content=3Dtext/html;charset=3DISO-8859-15>
<META content=3D"MSHTML 6.00.2900.2769" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Stefano,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>From the FAQ</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV>
<P class=3Dquestion>Is it possible getting database's information from a =
<A=20
class=3Dcreatelinktext=20
href=3D" http://www.eclipse.org/birt/wiki/index.php?n=3DFAQ.DataSourc e?act=
ion=3Dedit">DataSource</A><A=20
class=3Dcreatelink=20
ion=3Dedit"><FONT=20
size=3D1>?</FONT></A> object with the API?</P>
<P>Gary Xue <BR>The best way to achieve this is to edit the beforeOpen =
script of=20
the data source object to set the runtime information of the data =
source. To do=20
the method=20
dropdown list, select "beforeOpen". In the code editor, write a script =
like=20
this: </P><PRE>=20
=20
</PRE>
<P>Refer to the BIRT ROM scripting spec for more information about =
scripting=20
ingeneral. The names of the properties that you can set (odaUser, =
odaPassword,=20
etc.) are defined by the ODA extension. The BIRT-shipped ODA-JDBC driver =
extension recognizes the above 4 properties. </P>
<P>Jason Weathersby</P>
<P>BIRT PMC</P></DIV>
<BLOCKQUOTE=20
<DIV>"Stefano Zaccaria" &lt;<A=20
href=3D"mailto:szaccaria@cedacosrl.it">szaccaria@cedacosrl.it</A>&gt; =
wrote in=20
message <A=20
href=3D"news:dlk0sr$esc$1@news.eclipse.org">news:dlk0sr$esc$1@news.eclips=
e.org</A>...</DIV>You=20
excuse to me ,<BR>&nbsp;&nbsp;&nbsp;&nbsp; I found this link =
<BR><BR><A=20
class=3Dmoz-txt-link-freetext=20
href=3D"http://www.eclipse.org/birt/wiki/index.php?n=3DBPS.BPS35">http://=
www.eclipse.org/birt/wiki/index.php?n=3DBPS.BPS35</A>,=20
<BR><BR>there is script:<BR><BR>
<P><I>Some examples of the types of external context objects that may =
be=20
passed through to a BIRT data source provider include: </I></P>
<UL>
<LI><I>An open JDBC connection </I>
<LI><I>A pooled connection </I>
<LI><I>User authorization keys </I>
<LI><I>Query parameter values collected outside of BIRT</I> =
</LI></UL><BR>what=20
do you think about?<BR><BR>Ciao<BR>Stefano </BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_001C_01C5EC28.627FB230--
Previous Topic:Chart CallBackValue Usage
Next Topic:meter/dial chart
Current Time: Mon Jul 21 22:06:05 EDT 2025
Powered by FUDForum. Page generated in 0.27828 seconds
