Home » Language IDEs » Java Development Tools (JDT) » Problems in starting eclipse Antrunner from console
Problems in starting eclipse Antrunner from console [message #91862] Wed, 03 September 2003 12:12 Go to next message
Originally posted by: mayer.markus.gmx.at
I'd like to start eclipse's Antrunner from the command-line to execute
eclipse ant-scripts in a nightly build. i'm issuing the following command
on the command line:
c:\jdk1.3.1_01\jre\bin\java.exe -Xmx256m -cp
C:\programme\eclipse\startup.jar org.eclipse.core.launcher.Main
-application org.eclipse.ant.core.antRunner -data
C:\vp\DEVELOP\entwicklungsumgebung\eclipse\workspace\ -file metrics.xml
but the only thing that happens is that eclipse creates a folder named
"workspace" in the current directory
Anybody already tried to do something similar?
thanks in advance,
markus
Re: Problems in starting eclipse Antrunner from console [message #91878 is a reply to message #91862] Wed, 03 September 2003 12:18 Go to previous messageGo to next message
Specify -noupdate as one of the args
-noupdate -application org.eclipse.ant.core.antRunner -data
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=21617
Darins
"markus mayer" <mayer.markus@gmx.at> wrote in message
news:bj53sh$rn1$1@eclipse.org...
> thanks in advance,
> markus
Re: Problems in starting eclipse Antrunner from console [message #92033 is a reply to message #91878] Thu, 04 September 2003 02:35 Go to previous messageGo to next message
hi darin,
thanks for your swift reply to my question. you suggested to include the
"-noupdate" parameter. but i think i did that. the command i use is
C:\programme\eclipse\startup.jar org.eclipse.core.launcher.Main -noupdate
if i omit the -noupdate flag the command starts up the eclipse ide with a
new empty workspace
eclipse is in: c:\programme\eclipse
jdk is in: c:\jdk1.3.1_01\
workspace is at: c:\vp\develop\entwicklungsumgebung\eclipse\workspace
btw. is there any documentation on how to access this functionality from
the command line?
thanks,
markus
> c:jdk1.3.1_01jrebinjava.exe -Xmx256m -cp
> C:programmeeclipsestartup.jar org.eclipse.core.launcher.Main
> C:vpDEVELOPentwicklungsumgebungeclipseworkspace -file metrics.xml
> Darins
> > Hi,
> > thanks in advance,
> > markus
Re: Problems in starting eclipse Antrunner from console [message #92444 is a reply to message #92033] Thu, 04 September 2003 11:48 Go to previous message
You original posting did not include -noupdate in your commandline string.
With your latest command I see no reason why it would not work.
Currently I am your documentation.
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=41819
Darins
news:bj6mfl$9oc$1@eclipse.org...
> hi darin,
> new empty workspace
> the command line?
> thanks,
> markus
> > Darins
> > > Hi,
command
> > > thanks in advance,
> > > markus
Previous Topic:Could not find the main class, when starting Tomcat.
Next Topic:xdoclet tasks with autocomplete
Current Time: Sat Nov 08 20:12:55 EST 2025
Powered by FUDForum. Page generated in 0.07461 seconds
