[QVTO] Avoiding multiple object creation [message #91769] |
Wed, 08 October 2008 11:37  |
Originally posted by: mahdider.students.uni-mainz.de
I have the following code for creating a mutator for each attribute:
Generates a mutator or setter method for a given attribute.
mapping SIMPLE_UML::UmlAttribute::attribute2Setter() :
SIMPLE_UML::UmlMethod {
name := 'set' + self.name.firstToUpper();
visibility := UmlVisibility::PUBLIC;
-- TODO add parameters.
-- Create a new object, since void is unknown in the incoming model.
classifier := object UmlClassifier {
The issue is of course, that this method is being called multiple times
and this will result in multiple "void" classifier instances in the
target model. I played around with var, basically trying to keep a
reference to the created object but it did not really work (syntax wise)
as I expected.
What is a good way to create such instances only once? Or should I
basically check somehow if there is already such an instance in self.
with some resolve() call) and then create the instance only?
Thanks for your help!
Best Regards,
Mahdi D-Manesh
Re: [QVTO] Avoiding multiple object creation [message #91783 is a reply to message #91769] |
Wed, 08 October 2008 12:16   |
Hi Mahdi,
The easiest way to define a singleton is using mapping with no input =
parameters.
If such a mapping is executed, a trace for the mapping call with empty s=
et =
of source
objects is recorded.
Any subsequent call represents a call on the same source objects (empty =
set) and
the result is fetched from traces instead of executing the mapping again=
See the example bellow:
main() {
var x :=3D map singleVoid();
var y :=3D map singleVoid();
assert fatal (x =3D y);
mapping singleVoid() : UML::Classifier {
Another technique could be to check for existing instances in the init {=
section and
eventually assign one of them to the 'result' variable explicitly, thus =
limiting a repeated creation.
This might be useful, if you have specific constraints on the number of =
instances
to be created. The former way is the simplest for your usecase.
/Radek
On Wed, 08 Oct 2008 17:37:26 +0200, Mahdi D-Manesh =
<mahdider@students.uni-mainz.de> wrote:
> Hello,
> mapping SIMPLE_UML::UmlAttribute::attribute2Setter() : =
> name :=3D 'set' + self.name.firstToUpper();
> visibility :=3D UmlVisibility::PUBLIC;
> classifier :=3D object UmlClassifier {
> The issue is of course, that this method is being called multiple time=
s =
> and this will result in multiple "void" classifier instances in the =
> target model. I played around with var, basically trying to keep a =
> reference to the created object but it did not really work (syntax wis=
e) =
> as I expected.
> What is a good way to create such instances only once? Or should I =
> basically check somehow if there is already such an instance in self. =
> Best Regards,
> Mahdi D-Manesh
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: [QVTO] Avoiding multiple object creation [message #91867 is a reply to message #91783] |
Thu, 09 October 2008 05:25  |
Radek,
I tried your approach and it works like expected. So I am using the
"singleton" way now. :)
Best Regards,
Mahdi
Radek Dvorak schrieb:
> Hi Mahdi,
> parameters.
> set of source
> set) and
> the result is fetched from traces instead of executing the mapping again.
> main() {
> var x := map singleVoid();
> var y := map singleVoid();
> assert fatal (x = y);
> {} section and
> instances
> /Radek
>> Hello,
>> times and this will result in multiple "void" classifier instances in
>> the target model. I played around with var, basically trying to keep a
>> wise) as I expected.
>> Best Regards,
>> Mahdi D-Manesh
FUDForum. Page generated in 0.33754 seconds
