| Settings java permissions for a particular plug-in [message #91767] |
Wed, 03 August 2005 14:08  |
Eclipse User  |
Originally posted by: tata668.gmail.com
I'm developping an Eclipse plugin and it uses RMI to connect to another
server. I have to set some java permissions in order to make this plugin
works (java.net.SocketPermission and others).
My plugin works when I debug it using the RUN configuration inside Eclipse
by launching a new workspace with
"-Djava.security.policy="C:\pathToMySecurityFile" in the VM Arguments.
But where do I put this "-Djava.security.policy" line in normal mode, when
the plug is installed? Do I necessarily have to start the whole Eclipse
with the right permissions or is there a way to give the needed
permissions to my plugin only?
Thanks a lot!
FUDForum. Page generated in 0.29940 seconds
