Home » Archived » Visual Editor (VE) » VE crashes when loading Table
| VE crashes when loading Table [message #91747] |
Thu, 19 May 2005 07:31  |
--------------000902030506060000010700
unfortunately my visual editor crashes (always !) when I try to load the
JavaTest.java (see attached file). There are no problems when loading
other files. The problem only appears when I try to load a table with
tableitems. When there are no tables on the shell, then there are no
errors with my files.
I'm using Eclipse 3.0.1 and VE 1.0.2.1 on a windows xp pro machine.
Eclipse hangs up on 75% when loading/ building the shell while
"initializing the model" (progress window). Then I can only restart
Eclipse, but I cannot load the Table on the shell.
Could anybody help me?? Please try loading the attached file and please
tell my what happens!
thx
Flik
name="JavaTest.java"
Content-Disposition: inline;
filename="JavaTest.java"
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.TabFolder;
import org.eclipse.swt.widgets.TabItem;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Font;
import org.eclipse.swt.widgets.TableItem;
public class JavaTest {
private Shell scrSgridframe = null;
private TabFolder tabFolderscrSgridframe = null;
private TabItem tabItemVisiblescrSgridframe = null;
private Composite CSvisiblescrSgridframe = null;
private TabItem tabItemHiddenscrSgridframe = null;
private Composite CShiddenscrSgridframe = null;
TableItem tabitem;
private TableColumn F1 = null;
private TableColumn F2 = null;
private TableColumn gridList = null;
private TableColumn F4 = null;
private TableColumn F5 = null;
private Composite B1cs = null;
private Table B1 = null;
private void createscrSgridframe() {
scrSgridframe = new Shell (); // @jve:decl-index=0:visual-constraint="10,10"
scrSgridframe.setSize(new org.eclipse.swt.graphics.Point((int) (6*137.00) + 10, (int) (14*37.64) + 35));
createtabFolderscrSgridframe();
private void createtabFolderscrSgridframe() {
tabFolderscrSgridframe = new TabFolder(scrSgridframe,SWT.BOTTOM);
tabFolderscrSgridframe.setBounds(new org.eclipse.swt.graphics.Rectangle(0,0,(int) (6*137.00) + 10, (int) (14*37.64) + 35 ));
TabItem tabItemVisiblescrSgridframe = new TabItem (tabFolderscrSgridframe,SWT.NONE);
TabItem tabItemHiddenscrSgridframe = new TabItem (tabFolderscrSgridframe,SWT.NONE);
createCSvisiblescrSgridframe();
createCShiddenscrSgridframe();
tabItemVisiblescrSgridframe.setText("workplace");
tabItemHiddenscrSgridframe.setText("hidden-always");
tabItemVisiblescrSgridframe.setControl(CSvisiblescrSgridfram e);
tabItemHiddenscrSgridframe.setControl(CShiddenscrSgridframe) ;
private void createCShiddenscrSgridframe() {
CShiddenscrSgridframe = new Composite(tabFolderscrSgridframe,SWT.NONE);
CShiddenscrSgridframe.setBounds(tabFolderscrSgridframe.getBo unds().x,tabFolderscrSgridframe.getBounds().y,tabFolderscrSg ridframe.getBounds().width,tabFolderscrSgridframe.getBounds( ).height);
private void createCSvisiblescrSgridframe() {
CSvisiblescrSgridframe = new Composite(tabFolderscrSgridframe,SWT.NONE);
CSvisiblescrSgridframe.setBounds(tabFolderscrSgridframe.getB ounds().x,tabFolderscrSgridframe.getBounds().y,tabFolderscrS gridframe.getBounds().width,tabFolderscrSgridframe.getBounds ().height);
// END of TabDecks
// END of TabCards
String[][] gridContentB1 = new String[5][16];
B1cs = new Composite (CSvisiblescrSgridframe,SWT.NONE);
B1cs.setBounds(new org.eclipse.swt.graphics.Rectangle(18, 18,(int) (6*117.00), (int) (14*23.71)));
B1 = new Table (B1cs,SWT.SINGLE | SWT.BORDER | SWT.H_SCROLL | SWT.V_SCROLL | SWT.FULL_SELECTION | SWT.HIDE_SELECTION);
B1.setBounds(new org.eclipse.swt.graphics.Rectangle(0, 0,(int) (6*117.00), (int) (14*23.71)));
B1.setLinesVisible(true);
B1.setHeaderVisible(true);
// END of GridFrames
F1 = new TableColumn (B1,SWT.LEFT);
F1.setText("1");
F1.setWidth((int)((6*9.17) -(0.0)));
F2 = new TableColumn (B1,SWT.LEFT);
F2.setText("2");
gridContentB1[1][1-1] = "output";
gridContentB1[1][2-1] = "output";
gridContentB1[1][4-1] = "output";
F2.setWidth((int)((6*19.83) -(55.019999999999996)));
gridList = new TableColumn (B1,SWT.LEFT);
gridList.setText("3");
gridContentB1[2][1-1] = "listbox";
gridContentB1[2][7-1] = "listbox";
gridContentB1[2][8-1] = "listbox";
gridContentB1[2][9-1] = "listbox";
gridContentB1[2][10-1] = "f";
gridContentB1[2][11-1] = "g";
gridContentB1[2][12-1] = "h";
gridContentB1[2][13-1] = "j";
gridList.setWidth((int)((6*41.83) -(174.0)));
F4 = new TableColumn (B1,SWT.LEFT);
F4.setText("4");
F4.setWidth((int)((6*63.83) -(424.98)));
F5 = new TableColumn (B1,SWT.LEFT);
F5.setText("5");
gridContentB1[4][1-1] = "output";
gridContentB1[4][2-1] = "output";
F5.setWidth((int)((6*75.83) -(807.96)));
tabitem = new TableItem(B1,SWT.NULL,0);
tabitem.setText(new String[]{gridContentB1[0][0],gridContentB1[1][0],gridContent B1[2][0],gridContentB1[3][0],gridContentB1[4][0]});
tabitem = new TableItem(B1,SWT.NULL,1);
tabitem.setText(new String[]{gridContentB1[0][1],gridContentB1[1][1],gridContent B1[2][1],gridContentB1[3][1],gridContentB1[4][1]});
tabitem = new TableItem(B1,SWT.NULL,2);
tabitem.setText(new String[]{gridContentB1[0][2],gridContentB1[1][2],gridContent B1[2][2],gridContentB1[3][2],gridContentB1[4][2]});
tabitem = new TableItem(B1,SWT.NULL,3);
tabitem.setText(new String[]{gridContentB1[0][3],gridContentB1[1][3],gridContent B1[2][3],gridContentB1[3][3],gridContentB1[4][3]});
tabitem = new TableItem(B1,SWT.NULL,4);
tabitem.setText(new String[]{gridContentB1[0][4],gridContentB1[1][4],gridContent B1[2][4],gridContentB1[3][4],gridContentB1[4][4]});
tabitem = new TableItem(B1,SWT.NULL,5);
tabitem.setText(new String[]{gridContentB1[0][5],gridContentB1[1][5],gridContent B1[2][5],gridContentB1[3][5],gridContentB1[4][5]});
tabitem = new TableItem(B1,SWT.NULL,6);
tabitem.setText(new String[]{gridContentB1[0][6],gridContentB1[1][6],gridContent B1[2][6],gridContentB1[3][6],gridContentB1[4][6]});
tabitem = new TableItem(B1,SWT.NULL,7);
tabitem.setText(new String[]{gridContentB1[0][7],gridContentB1[1][7],gridContent B1[2][7],gridContentB1[3][7],gridContentB1[4][7]});
tabitem = new TableItem(B1,SWT.NULL,8);
tabitem.setText(new String[]{gridContentB1[0][8],gridContentB1[1][8],gridContent B1[2][8],gridContentB1[3][8],gridContentB1[4][8]});
tabitem = new TableItem(B1,SWT.NULL,9);
tabitem.setText(new String[]{gridContentB1[0][9],gridContentB1[1][9],gridContent B1[2][9],gridContentB1[3][9],gridContentB1[4][9]});
tabitem = new TableItem(B1,SWT.NULL,10);
tabitem.setText(new String[]{gridContentB1[0][10],gridContentB1[1][10],gridConte ntB1[2][10],gridContentB1[3][10],gridContentB1[4][10]});
tabitem = new TableItem(B1,SWT.NULL,11);
tabitem.setText(new String[]{gridContentB1[0][11],gridContentB1[1][11],gridConte ntB1[2][11],gridContentB1[3][11],gridContentB1[4][11]});
tabitem = new TableItem(B1,SWT.NULL,12);
tabitem.setText(new String[]{gridContentB1[0][12],gridContentB1[1][12],gridConte ntB1[2][12],gridContentB1[3][12],gridContentB1[4][12]});
tabitem = new TableItem(B1,SWT.NULL,13);
tabitem.setText(new String[]{gridContentB1[0][13],gridContentB1[1][13],gridConte ntB1[2][13],gridContentB1[3][13],gridContentB1[4][13]});
tabitem = new TableItem(B1,SWT.NULL,14);
tabitem.setText(new String[]{gridContentB1[0][14],gridContentB1[1][14],gridConte ntB1[2][14],gridContentB1[3][14],gridContentB1[4][14]});
tabitem = new TableItem(B1,SWT.NULL,15);
tabitem.setText(new String[]{gridContentB1[0][15],gridContentB1[1][15],gridConte ntB1[2][15],gridContentB1[3][15],gridContentB1[4][15]});
org.eclipse.swt.widgets.Display display = org.eclipse.swt.widgets.Display.getDefault();
JavaTest test = new JavaTest();
test.createscrSgridframe();
test.scrSgridframe.open();
while (!test.scrSgridframe.isDisposed()) {
if (!display.readAndDispatch ()) display.sleep();
display.dispose ();
--------------000902030506060000010700--
| Re: VE crashes when loading Table [message #91799 is a reply to message #91763] |
Thu, 19 May 2005 10:39   |
--------------040406050001030403060708
hello,
i'm sorry, but i cannot find any log-file....
But I tested a lot and maybe I have found the problem: I have attached a
new file of the Table.
VE _can_ now display the shell, but only when leaving out the tabitem /
TableItem part (at the end of the file). Then VE shows the screen correctly.
But when I use:
tabitem.setText(..................................
Then VE doesn't show anything! He also doesn't hang up like before, but
the ve-display only shows a blank shell and an icon called 'tabitem'
[see code -> tableitem] (see attached ve.jpg)!
I think VE has a problem with TableItems. I also notice that the
tableitem does not exist in the swt palette?!
Is this maybe the reason for my problem? - HOW can I fix it??
thx
flik
Rich Kulp schrieb:
> Could you please attach the .log file so we know what the errors were?
TableItem tabitem;
// END of TabDecks
// END of TabCards
F1.setText("1");
F2.setText("2");
F4.setText("4");
F5.setText("5");
// END of GridFrameColumns
display.dispose ();
Content-Type: image/jpeg;
name="ve.JPG"
filename="ve.JPG"
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CAQABQADASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDhrPUZ3eKKKCaed13BIk3n HrgVdn8QXWnO
UuLeeN14KsoyKueDrmPTop7uG5eHUFtXSLZ97ZxvK/KSWAyeM9M4GM0X39ky W7GST5COzn/4
ivr6+MqwnKPMtH5f5HnwwGGlFNw382EeuXEsKSByAwyBgUHWrrP+sP5Cs+JE 8hPKyY8fKT6d
uw/lXdnSW1fw14OgbH2aC11K5uWa4EKpGsqfMWKtgAkfwn+o9CVeNKlTnNfF /k3+h431ZTrT
hDpf87HJf21df89D+VH9tXX/AD0P5V1sngnSJ9Sl0/T7m8muJ9Hj1KwBZQJC xb5DlVJztGOF
75xUg8EaMuuTWsk9wthHdQ6f9pe6VWkumXLLGgibdjcvB24w2TgcZ/2hhrfj t/X9XK+o1f6Z
x39tXX/PQ/lR/bV1/wA9D+VMvtOFvrt3p0MgYQ3clsryMEB2uUyScAdOp4qt NB5MzxebBKUI
BaCZJU6Z4ZCQevY13RcJWtbXX5HNKm43v0Ln9tXX/PQ/lR/bV1/z0P5V0+k6 XPrHgHTdNt0M
j3HiTBQSBMqLVi3zEHGACc4PToelWI/B3h2e/wBDiiv7lodXiuVieKYOizRF QMOY13ISSPuj
PGOOa4njqMJOM1qm/PZX/wA/uOlYKcoqUepyH9tXX/PQ/lR/bV1/z0P5V1E3 gzT7CRVvmnjW
zsY7jVZZLpY0gkkbCRrtjcs3DcYOSVweedPw3aS+Hvi6vh601C8awhkctEZS Ectbb8sowrEZ
XnHYUpY+i4ydNXaTfbReev8ATBYKaa59E2l95wn9tXX/AD0P5Uf21df89D+V b3h7R7XXfD8W
veJ9avZPMuY7FZbjUETyhs3li0x5A3H5V568HtIPCujy+GLy+sby41O6tWnE htJotkYRyquV
PJRlBbIJ/GqWNop8slrdLbv5g8FO11sc7/bV1/z0P5Uf21df89D+VbHja30+ 3uNDj0+yNssm
jwXEh3qdxctjOFGW4OW78cDHLtCsJL3wTr8dq9yLk3FlF5KOgSfzJgqA7lyM Ek5DDORnpzp9
Yh7FVuWyvbX1sR9WftPZ31/4FzF/tq6/56H8qP7auv8Anofyrrbnwh4ftFsZ Zru4CNq39l3a
wXAlET7C3DmJBkEDdwQORnIpbvwDbafPb2kxma5/0m5uTJdJDFDaREqrs2xi CxKnoeM8Dtl/
aGG/pf1/TRf1Gqcj/bV1/wA9D+VH9tXX/PQ/lV7xXotjo2o2cWnTyzW91YxX iNJycOWA52r/
AHe4B9qx57NrdYS81sxlXeEiuY5HUYB+ZVYlOo4YD9K6qc6dSKnHrsYToyhJ xfQtf21df89D
+VH9tXX/AD0P5V0etXclv8OPC9vFqGo27TpeqYLVisc6+coPmEOvADHA2tnc elUPEuk6NoV5
d6RGdQl1K1EIacsnkuzKHb5cbgAGGOTzn0ycKWJjOXK463aXydm9vTuazw3L HmT6J/eZf9tX
X/PQ/lR/bV1/z0P5V3njKMNL4/lSa5jaC401WjRk8uVWWIKCChYbSWPDDOR6 c0dU8G6Ba3Ws
QR3V9brpF5ZxXE08iOrxT7PmGFG0rv8Afp78Y0sxoyinKNr2891H/wCSSNJ4 CcW1F3/p/wCR
yP8AbV1/z0P5Uf21df8APQ/lXZS+BNLGrlUe+XTYrKe889riArcrGRjy5OFX IYElwAPXHNcl
4hsNLsdSji0nUI7yCS3SZgk8cxhZsgxs8Z2kgr29R9a3o4uhWmoQ3avsZVMJ UpxcpbIi/tq6
/wCeh/Kj+2rr/nofyr0jxdqQtNS8YW+qajaz200Eaafp7TrJKkxijw6oCTGo bJOQM9frk6vo
8OoXGl3V+3l6ZY+G7F55ftHlbGd5AMfu3LE4IAC8nHI78tLMYSipShZP59L9 lr09TeeAabUZ
Xt/mcb/bV1/z0P5Uf21df89D+VdfqWg6ToWkeN7RbaS6n0+SzSGeR1DL5pUj B2HGC3zY+8OB
t61a1exsdQbTLFmvbbR9O8NjWJbeGZT5h+boNoHmHnLnrngLyTbzClo1HTv/ ANup/qSsBLq9
f+DY4b+2rr/nofyo/tq6/wCeh/KunHhLRo9RuWmnvjYJoH9tIiMgmUf3CcYP Ruw7VPpHhDw/
qQ0ONpNUjm1k3ZgIkjKxLCxxu+XkldvTvmtJY/DxV7fh5N/oyFgqjdv19P8A NHI/21df89D+
VH9tXX/PQ/lV3XNL0y30XQtV0trsRapHM/lXTKzJ5bKvVQBzurC2V1UpQqx5 orv+GhhUpOnL
lkaH9tXX/PQ/lR/bV1/z0P5Vn7KNla8i7EWRof21df8APQ/lR/bV1/z0P5Vn 7KNlHIuwWRof
21df89D+VH9tXX/PQ/lWfso2Uci7BZGh/bV1/wA9D+VH9tXX/PQ/lWfso2Uc i7BZGh/bV1/z
0P5Uf21df89D+VZ+yjZRyLsFkaH9tXX/AD0P5Uf21df89D+VZ+yjZRyLsFka H9tXX/PQ/lR/
bV1/z0P5Vn7KNlHIuwWRof21df8APQ/lR/bV1/z0P5Vn7KNlHIuwWRof21df 89D+VH9tXX/P
Q/lWfso2Uci7BZGh/bV1/wA9D+VH9tXX/PQ/lWfso2Uci7BZGh/bV1/z0NH9 tXX/AD0NZ+w+
lG0+lHs12CyND+2rr/noaP7auv8Anoaz9p9KNp9KPZrsFkaH9tXX/PQ0f21d f89DWftPpRtP
pR7NdgsjQ/tq6/56Gj+2rr/noaz9p9KNp9KPZrsFkaH9tXX/AD0NH9tXX/PQ 1n7T6UbT6Uez
XYLI0P7auv8AnoaP7auv+ehrP2n0o2n0o9muwWRof21df89DR/bV1/z0NZ+0 +lG0+lHs12Cy
ND+2rr/noaP7auv+ehrP2n0o2n0o9muwWRof21df89DR/bV1/wA9DWftPpRt PpR7NdgsjQ/t
q6/56Gj+2rr/AJ6Gs/afSjafSj2a7BZGh/bV1/z0NH9tXX/PQ1n7T6UbT6Ue zXYLI0P7auv+
eho/tq6/56Gs/afSjafSj2a7BZGh/bV1/wA9DR/bV1/z0NZ+0+lG0+lHs12C yND+2rr/AJ6G
j+2rr/noaz9p9KNp9KPZrsFkaH9tXX/PQ0f21df89DWftPpRtPpR7NdgsjQ/ tq6/56Gj+2rr
/noaz9p9KNp9KPZrsFkaH9tXX/PQ0f21df8APQ1n7T6UbT6UezXYLI0P7auv +eho/tq6/wCe
hrP2n0o2n0o9muwWRof21df89DR/bV1/z0NZ+0+lG0+lHs12CyND+2rr/noa P7auv+ehrP2n
0o2n0o9muwWRof21df8APQ0f21df89DWftPpRtPpR7NdgsjQ/tq6/wCeho/t q6/56Gs/afSj
afSj2a7BZGh/bV1/z0NH9tXX/PQ1n7T6UbT6UezXYLI0P7auv+eho/tq6/56 Gs/afSjafSj2
a7BZGh/bV1/z0NH9tXX/AD0NZ+0+lG0+lHs12CyND+2rr/noaT+2rr/nqf0q htPpRtPpR7Nd
gsi//bV1/wA9T+lH9tXX/PU/pVDafSjafSj2a7BZF/8Atq6/56n9KP7auv8A nqf0qhtPpRtP
pR7Ndgsi/wD21df89T+lH9tXX/PU/pVDafSjafSj2a7BZF/+2rr/AJ6n9KP7 auv+ep/SqG0+
lG0+lHs12CyL/wDbV1/z1P6Uf21df89T+lUNp9KNp9KPZrsFkX/7auv+ep/S j+2rr/nqf0qh
tPpRtPpR7Ndgsi//AG1df89T+lH9tXX/AD1P6VQ2n0o2n0o9muwWRf8A7auv +ep/Sj+2rr/n
qf0qhtPpRtPpR7Ndgsi//bV1/wA9T+lH9tXX/PU/pVDafSjafSj2a7BZF/8A tq6/56n9KP7a
uv8Anqf0qhtPpRtPpR7Ndgsi/wD21df89T+lH9tXX/PU/pVDafSjafSj2a7B ZF/+2rr/AJ6n
9KP7auv+ep/SqG0+lG0+lHs12CyL/wDbV1/z1P6Uf21df89T+lUNp9KNp9KP ZrsFkX/7auv+
ep/Sj+2rr/nqf0qhtPpRtPpR7Ndgsi//AG1df89T+lH9tXX/AD1P6VQ2n0o2 n0o9muwWRf8A
7auv+ep/Sj+2rr/nqf0qhtPpRtPpR7Ndgsi//bV1/wA9T+lH9tXX/PU/pVDa fSjafSj2a7BZ
F/8Atq6/56n9KP7auv8Anqf0qhtPpRtPpR7Ndgsi/wD21df89T+lH9tXX/PU /pVDafSjafSj
2a7BZF/+2rr/AJ6n9KP7auv+ep/SqG0+lG0+lHs12CyL/wDbV1/z1P6Uf21d f89T+lUNp9KN
p9KPZrsFkX/7auv+ep/Sj+2rr/nqf0qhtPpRtPpR7Ndgsi//AG1df89T+ldf 4ZWK60k313tn
d5pIkSUsEUIqEn5SCSfMHfjHvxwO0+ldfo0ph8L2g6br25/9At65cXB8iUdL v9GdGGUefXU1
5r21iJ/4l1h/31P/APHaqxX8F7qNrp4sLWIXUyQCaB5t8ZdgoYbnYHBPQjke nWmX2h6usbyv
pl6kaAszNAwCgdSTjiszRDt8UaMCeuoW/wD6MWuRQi6UpRldpdzqfKpqLitf I39FjgOhW13c
JHcTXEbS/vi4CgSOgACMv9wnJ9fbm4ltczRCW28OxzRtna8cV0ynnHUSVQ0A JKnhizlGY5og
rrnGQbqYEVrtrkFzpF7b6bDdaS0EayJMupTMiZlRT8g7fOTwD9M1z1XUVRqN 3r30Su13X4I0
pwp8ibS2/S5z1xdiee4sjYQ2k0cM8gkiMoZGijZyrK7sMHYRjAIP0wdvTdNt /wCzbT/RlvLq
aGKU+YZMkuivgBGXgBsdzxXOXFzFd+LdVnhffFNHqMkbYIypgmIODz0rdtLu 5t5dP+xs4uFs
7Py9gySTbx8Y756Y715me4ith6MOSTjdrrrs/mepkmEo4mtLminZPfbdDD9i aRYo9Ks3kchV
VWuCWJ6ADza5nxRBazaHqrR2MdlPZwiUmF5PnBkSMqwdm/56A5GOh6549au4 Dbi6v9PtLX/h
Jxbq80CPv8rOdzouMFyMZHuOufn8i1eV5/D/AIjeV2eRrAMzMclibqDJJrws HmGMjjKUJVZO
77u1v6+496tgMHPCVKkKUU4rsr3+XTs+pyVlDlY54p5LefYF82I4bbnOAewP fHXp0qafR1vC
xmvp23HJHAH6CvbrvwH4H0yya5vbOC1tYsbpZ7yREXJAGWL4HJAqlHoHw3mh Sa3ezuI3lWFT
b38kuXLogHyuf4pYwfTeucZr6SebZbOTk6ctf6/mPmPYY1aRqJL+vI840q5m 0WW3nsrho54P
uSADI4x346Grp8SawdQS9fUnadImhT92gRY25K+WFCEHvkc4Gegr1D/hXPhT /oFn/wACZf8A
4qj/AIVz4U/6BZ/8CZf/AIqtf7dy92vTbsrbLbtucv8AZuKu37Td367nmD+J 9Zl1K01CXUnk
urRNkEhijGwc9goB696jsPEOq6Ysos9QeMyzefIxRHzJk5fDKQGOTkgDrXoM 3hr4c2+pDTZp
LCO/LKgtX1JhKWbG0bDJnJyMDHORU9x4M8D2l5BaXFmkU06l4w9zMAwDonXd jO6WMAdSWGM0
f25l9uX2Tt6L179w/s7FXv7T8X6Hld3dy393Nd3cxmuJnLu5VVyT7KAP0psE xtriOeFyksTB
0YdVYHINeuwfD/wdc28dxb6eksMqh45I7uVldSMggh8EEd6k/wCFc+FP+gUf /AmX/wCKrVcR
4NR5VCVvRf5mbyiu3zOSv8zzC48Ua1dXtvdzapKZbaQyw7ESMK54LYVQGJHG WzwSO5pt14k1
a9+yC51AutpIZIFEMaCNsg8bVHTHTpXoVt4T+H17fzWFoLOe8g3ebbxag7SR 7Tg7lD5GCQDn
vV//AIVz4U/6BR/8CZf/AIqslneXK1qT08l/mavLsW73qfizy2LxFqsN9e3y ag4ur05nkMaM
HIxtO0rtyMDBxxilPiPVjrY1k6gx1FV2pP5UeVG3b024PBPUGvUf+Fc+FP8A oFH/AMCZf/iq
P+Fc+FP+gUf/AAJl/wDiqP7cy7/n09rbLbtuL+zcV/z8893ueVaPrup6BaG2 0y/eCM7TyiPy
BgMAykA+4FOfxDqz2D2J1F/s8iyJIPLj3Osh3OC+3cAx5IBAr1P/AIVz4U/6 BR/8CZf/AIqq
moeDfAmk263GpQ21lCzbFkub941LYJwCzgZwDx7UPPMvk7uk7+i/zBZbikrK p+Z5uniDU472
yu0vds1jB5Fu/kx5RMEYztywAJwGJAycdalttYt9P8K3WmWn2o317NbySzsV RIVhk3rsIJZm
JA7ADPtz6VB8P/B1zbx3Fvp6SwyqHjkju5WV1IyCCHwQR3qCPwX4Kl1KXT49 Nke4hXdJtkuC
idDtL52h8Mp2Z3YIOMHNKed4CS5eSSWmyXR3799Rxy7Exd+dP7+1vyPOtQ8T axqlo9peagZL
Z5fNaIQxqC3rkKD3znOT3pD4i1VtWOptfu12YRBvZEIMYGNhXGGHJOCDya9R /wCFc+FP+gUf
/AmX/wCKqOH4f+DrhC8OnpIgZkLJdykBlJVhw/UEEEdiCKazzLkrKk7ekeu/ UTy3FN3dT8We
V6lrF/rMkL6letctDH5cZaNFwM5/hUVS+SvZf+Fc+FP+gUf/AAJl/wDiqP8A hXPhT/oFH/wJ
l/8Aiq0hxFg6ceWEJJei/wAyJ5TXm+aU038zyeTV76TTodPN1H9lgR0iRrSB zGHOW2syFlJP
cHsPSpbzxDql/a/Zbm/aSAqiupjTc4T7oZ9u9se5r0z/AIQbwT9v+wfZIftn led9n+2yeZ5e
cb9u/O3PGemafB8P/B1zbx3Fvp6SwyqHjkju5WV1IyCCHwQR3qP7dwF7+ze9 9lv33L/s3FWt
zrt12PLr3XdS1CO9S4viy3zQm6xFGDL5RBTJC54wOepwBnFaXiHxhd6vr13c WU81rp5uoriG
ExxozOiIA7lcl8MpIDE8BeOBjv5vh/4Ot0DzaekaFlQM93KAWYhVHL9SSAB3 JAqT/hXPhT/o
FH/wJl/+KrN5zlzkpeyenkrdPPyRawGLUXH2i19f66nmH/CUayb+K8OpP50I kWMLFGiKJDlx
sVQpyeTkHJFU9Q1K71a6+06jdtczbQgZlVcKOgAUAAfhXq5+H/g5bhLdtPQT OrOsZu5dzKpA
Ygb8kAsuT23D1qT/AIVz4U/6BR/8CZf/AIqtIZ7l8HzRpNP0X+ZEssxUlaVS 6+Z5DfXs+p6j
c6hfXBnurhg0khVVzhQoGFAHAUCr8fifWIdnlagV2W62y/uY2xGpyoOVOdpJ IznGTjGTXp//
AArnwp/0Cj/4Ey//ABVULnwn8PrK/hsLsWcF5Pt8q3l1B1kk3HA2qXyckEDH em8+wEoqDpuy
20X+YllmJUnJT1fqee3fiPV75b4XOoGT7ciJOWgiO4J93gpgEHkHqDznpTIt f1SHUIb5L9xP
DarZxfIm1YVzhCNuGHzH72f0r1T/AIVz4U/6BR/8CZf/AIqj/hXPhT/oFH/w Jl/+KqVnmXJW
9k/uXp37aD/s7FP/AJefizyiXW9Tnlvp5dSlee+tjaTylEyYSACgG3aowP4Q O56nNOt9e1O0
m0+S2v2iOnJKloBGhEXm/fPKnJPvnHavTrjwL4MtZrWGbTisl1KYYR58x3OE ZyOG4+VGPPp9
Kn/4Vz4U/wCgUf8AwJl/+Ko/tzL7W9k7ei9O/ZtD/s7FXv7T8/66Hjz3M0tj p9lLcs9rp8bx
20ZVQEDkFjkDJJKjqfpUfyV7DP8AD/wdbW8lxcaekUMSl5JJLuVVRQMkkl8A Ad6g0/wb4E1a
3a402G2vYVbY0ltfvIobAOCVcjOCOPetY8RYOCtGEl8l/mZyymvJ3lNfieS/ JR8ley/8K58K
f9Ao/wDgTL/8VUcHw/8AB1zbx3Fvp6SwyqHjkju5WV1IyCCHwQR3qv8AWXC/ yy+5f5k/2NW/
mX4nj3yUfJXsMnw/8HRPEkmnojzNsjVruUF2wWwPn5OFY49AT2qT/hXPhT/o FH/wJl/+Ko/1
lwv8svuX+Yf2NW/mX4njXyUfJXrWoeDfAmk263GpQ21lCzbFkub941LYJwCz gZwDx7VPB8P/
AAdc28dxb6eksMqh45I7uVldSMggh8EEd6P9ZcL/ACy+5f5h/Y1b+ZfiePfJ R8ley/8ACufC
n/QKP/gTL/8AFUf8K58Kf9Ao/wDgTL/8VR/rLhf5Zfcv8w/sat/MvxPGvko+ SvYT8P8Awctw
lu2noJnVnWM3cu5lUgMQN+SAWXJ7bh61B/whvgTZbv5NtsuVDwN9vfEqkqoK /P8AMCZEAI7u
o7ij/WXC/wAsvuX+Yf2NW/mX4nkvyUfJXsv/AArnwp/0Cj/4Ey//ABVQW/gX wZdTXUMOnFpL
WUQzDz5htcorgctz8rqePX60f6y4X+WX3L/MP7GrfzL8TyH5KPkr2X/hXPhT /oFH/wACZf8A
4qj/AIVz4U/6BR/8CZf/AIqj/WXC/wAsvuX+Yf2NW/mX4njXyUfJXsM3w/8A B1ugebT0jQsq
Bnu5QCzEKo5fqSQAO5IFA+H/AIOa4e3XT0MyKrtGLuXcqsSFJG/IBKtg99p9 KP8AWXC/yy+5
f5h/Y1b+ZfiePfJR8levJ4F8GPfzWK6cTcwxJNInnzcI5cKc7scmN/y9xU// AArnwp/0Cj/4
Ey//ABVH+suF/ll9y/zD+xq38y/E8a+Sj5K9l/4Vz4U/6BR/8CZf/iqP+Fc+ FP8AoFH/AMCZ
f/iqP9ZcL/LL7l/mH9jVv5l+J4ziOjEdezf8K58Kf9As/wDgTL/8VR/wrnwp /wBAs/8AgTL/
APFUf6zYX+WX4f5h/Y1b+ZfieM4joxHXs3/CufCn/QLP/gTL/wDFUf8ACufC n/QLP/gTL/8A
FUf6zYX+WX4f5h/Y1b+ZfieM4joxHXs3/CufCn/QLP8A4Ey//FUf8K58Kf8A QLP/AIEy/wDx
VH+s2F/ll+H+Yf2NW/mX4njOI6MR17N/wrnwp/0Cz/4Ey/8AxVH/AArnwp/0 Cz/4Ey//ABVH
+s2F/ll+H+Yf2NW/mX4njOI6MR17N/wrnwp/0Cz/AOBMv/xVH/CufCn/AECz /wCBMv8A8VR/
rNhf5Zfh/mH9jVv5l+J4ziOjEdezf8K58Kf9As/+BMv/AMVR/wAK58Kf9As/ +BMv/wAVR/rN
hf5Zfh/mH9jVv5l+J4ziOjEdezf8K58Kf9As/wDgTL/8VR/wrnwp/wBAs/8A gTL/APFUf6zY
X+WX4f5h/Y1b+ZfieM4joxHXs3/CufCn/QLP/gTL/wDFUf8ACufCn/QLP/gT L/8AFUf6zYX+
WX4f5h/Y1b+ZfieM4joxHXs3/CufCn/QLP8A4Ey//FUf8K58Kf8AQLP/AIEy /wDxVH+s2F/l
l+H+Yf2NW/mX4njOI6MR17N/wrnwp/0Cz/4Ey/8AxVH/AArnwp/0Cz/4Ey// ABVH+s2F/ll+
H+Yf2NW/mX4njOI6MR17N/wrnwp/0Cz/AOBMv/xVH/CufCn/AECz/wCBMv8A 8VR/rNhf5Zfh
/mH9jVv5l+J4ziOjEdezf8K58Kf9As/+BMv/AMVR/wAK58Kf9As/+BMv/wAV R/rNhf5Zfh/m
H9jVv5l+J4ziOjEdezf8K58Kf9As/wDgTL/8VR/wrnwp/wBAs/8AgTL/APFU f6zYX+WX4f5h
/Y1b+ZfieM4joxHXs3/CufCn/QLP/gTL/wDFUf8ACufCn/QLP/gTL/8AFUf6 zYX+WX4f5h/Y
1b+ZfieM4joxHXs3/CufCn/QLP8A4Ey//FUf8K58Kf8AQLP/AIEy/wDxVH+s 2F/ll+H+Yf2N
W/mX4njOI6MR17N/wrnwp/0Cz/4Ey/8AxVH/AArnwp/0Cz/4Ey//ABVH+s2F /ll+H+Yf2NW/
mX4njOI6MR17N/wrnwp/0Cz/AOBMv/xVH/CufCn/AECz/wCBMv8A8VR/rNhf 5Zfh/mH9jVv5
l+J4ziOjEdezf8K58Kf9As/+BMv/AMVR/wAK58Kf9As/+BMv/wAVR/rNhf5Z fh/mH9jVv5l+
J4ziOjEdezf8K58Kf9As/wDgTL/8VR/wrnwp/wBAs/8AgTL/APFUf6zYX+WX 4f5h/Y1b+Zfi
eM4joxHXs3/CufCn/QLP/gTL/wDFUf8ACufCn/QLP/gTL/8AFUf6zYX+WX4f 5h/Y1b+ZfieM
4joxHXs3/CufCn/QLP8A4Ey//FUf8K58Kf8AQLP/AIEy/wDxVH+s2F/ll+H+ Yf2NW/mX4njO
I6MR17N/wrnwp/0Cz/4Ey/8AxVH/AArnwp/0Cz/4Ey//ABVH+s2F/ll+H+Yf 2NW/mX4njOI6
MR17N/wrnwp/0Cz/AOBMv/xVH/CufCn/AECz/wCBMv8A8VR/rNhf5Zfh/mH9 jVv5l+J4ziOj
Edezf8K58Kf9As/+BMv/AMVR/wAK58Kf9As/+BMv/wAVR/rNhf5Zfh/mH9jV v5l+J4ziOjEd
ezf8K58Kf9As/wDgTL/8VR/wrnwp/wBAs/8AgTL/APFUf6zYX+WX4f5h/Y1b +ZfieM4jpNqV
7P8A8K58Kf8AQLP/AIEy/wDxVJ/wrjwn/wBAr/yZl/8AiqP9ZsL/ACy/D/MP 7GrfzL8Txnal
G1K9m/4Vx4T/AOgV/wCTMv8A8VR/wrjwn/0Cv/JmX/4qj/WbC/yy+5f5h/Y1 b+ZfieM7Uo2p
Xs3/AArjwn/0Cv8AyZl/+Ko/4Vx4T/6BX/kzL/8AFUf6zYX+WX3L/MP7Grfz L8TxnalG1K9m
/wCFceE/+gV/5My//FUf8K48J/8AQK/8mZf/AIqj/WbC/wAsvuX+Yf2NW/mX 4njO1KNqV7N/
wrjwn/0Cv/JmX/4qj/hXHhP/AKBX/kzL/wDFUf6zYX+WX3L/ADD+xq38y/E8 Z2pRtSvZv+Fc
eE/+gV/5My//ABVH/CuPCf8A0Cv/ACZl/wDiqP8AWbC/yy+5f5h/Y1b+Zfie M7Uo2pXs3/Cu
PCf/AECv/JmX/wCKo/4Vx4T/AOgV/wCTMv8A8VR/rNhf5Zfcv8w/sat/MvxP GdqUbUr2b/hX
HhP/AKBX/kzL/wDFUf8ACuPCf/QK/wDJmX/4qj/WbC/yy+5f5h/Y1b+ZfieM 7Uo2pXs3/CuP
Cf8A0Cv/ACZl/wDiqP8AhXHhP/oFf+TMv/xVH+s2F/ll9y/zD+xq38y/E8Z2 pRtSvZv+FceE
/wDoFf8AkzL/APFUf8K48J/9Ar/yZl/+Ko/1mwv8svuX+Yf2NW/mX4njO1KN qV7N/wAK48J/
9Ar/AMmZf/iqP+FceE/+gV/5My//ABVH+s2F/ll9y/zD+xq38y/E8Z2pRtSv Zv8AhXHhP/oF
f+TMv/xVH/CuPCf/AECv/JmX/wCKo/1mwv8ALL7l/mH9jVv5l+J4ztSjalez f8K48J/9Ar/y
Zl/+Ko/4Vx4T/wCgV/5My/8AxVH+s2F/ll9y/wAw/sat/MvxPGdqUbUr2b/h XHhP/oFf+TMv
/wAVR/wrjwn/ANAr/wAmZf8A4qj/AFmwv8svuX+Yf2NW/mX4njO1KNqV7N/w rjwn/wBAr/yZ
l/8AiqP+FceE/wDoFf8AkzL/APFUf6zYX+WX3L/MP7GrfzL8TxnalG1K9m/4 Vx4T/wCgV/5M
y/8AxVH/AArjwn/0Cv8AyZl/+Ko/1mwv8svuX+Yf2NW/mX4njO1KNqV7N/wr jwn/ANAr/wAm
Zf8A4qj/AIVx4T/6BX/kzL/8VR/rNhf5Zfcv8w/sat/MvxPGdqUbUr2b/hXH hP8A6BX/AJMy
/wDxVH/CuPCf/QK/8mZf/iqP9ZsL/LL7l/mH9jVv5l+J4ztSjalezf8ACuPC f/QK/wDJmX/4
qj/hXHhP/oFf+TMv/wAVR/rNhf5Zfcv8w/sat/MvxPGdqUbUr2b/AIVx4T/6 BX/kzL/8VR/w
rjwn/wBAr/yZl/8AiqP9ZsL/ACy+5f5h/Y1b+ZfieM7Uo2pXs3/CuPCf/QK/ 8mZf/iqP+Fce
E/8AoFf+TMv/AMVR/rNhf5Zfcv8AMP7GrfzL8TxnalG1K9m/4Vx4T/6BX/kz L/8AFUf8K48J
/wDQK/8AJmX/AOKo/wBZsL/LL7l/mH9jVv5l+J4ztSjalezf8K48J/8AQK/8 mZf/AIqj/hXH
hP8A6BX/AJMy/wDxVH+s2F/ll9y/zD+xq38y/E8Z2pW3abrrRbe2tZbdbi3u ZZXSe4SHcrrG
AQzkA4MZyM55Hvj0v/hXHhP/AKBX/kzL/wDFUf8ACuPCf/QK/wDJmX/4qs6v EWFmvhl9y/zN
KeVVoO/Mvx/yOWufE3jC7tZbea/05opUKOv2+xGVIwRw1c/Y2dzZ65p+oXkt jHa2lzHcSFL+
CViEYNgKjliTjA4784HNek/8K48J/wDQK/8AJmX/AOKo/wCFceE/+gV/5My/ /FVywzjCQi4x
i0nvaKX/ALcdEsDWlJSbTa83/kedQvPcWmly6dcWyS2cJidZLuOB0bzZJAwL suRhxyOhB6cV
aubvxJd27QXGowyxN95JNbt2U855Blru/wDhXHhP/oFf+TMv/wAVR/wrjwn/ ANAr/wAmZf8A
4qqlneFcuaz+cV6/zCWArKPK2vvf+R5jbW02nXct7fTWSRLa3EarDewzO7SR PGoCxsx6vkk4
GAe+BWzZ6lcrcWepaVd2aNHbQxfvbyGJ0dIljYFZGGQdpOcEYP1rtf8AhW/h P/oFf+TMv/xV
H/Ct/CX/AECf/JiX/wCKrjzDHYHHwUavOmne6SX6+Z2ZfHEYGblTUWmrWd3v /wAMcTHdapBe
Lew3lgt0r7xL/a1qSW75zJznvnrmsLX53h0fXJr+6tZLi/txEiwXUc7M5mjk Zj5bEKMRnrjk
jHfHqX/CtvCX/QJ/8mJf/iqRvhn4QdSraRweo+0y/wDxVebhqGWUK0aydRuL vb3bX+89Svme
NrUpUpRglJWbV72L/i60uL3QUgtjMsrX9kQ8CBnjAuoiXAII+UAtyCOOeKwv EGm6vFqGkwLe
anqcHmpLK8kaYUre2JGREirwqysCRkDfzgHHe7F/56p+R/wo2L/z1T8j/hXG jmOC8ERa4l+X
1W9vZZTa/wCnRS2k8caXGV+68sjI2P3gHkKIyOTgeWK7qn7F/wCeqfkf8KNi /wDPVPyP+FDA
4myley8b6wZ7jWoo7i/jMVvFpzSWswNtCm9pRCcYYEH94oGznvnn4oNSbU9G uEi106skESar
JKtz5ayteWRlEZb92EIWbIi+Qqp/hAr1bYv/AD1T8j/hRsX/AJ6p+R/wpgcx 4Esxp3hKxsWj
vY7m2ijhukujKdsyxqHCGTgpkcbPk67a6Sn7F/56p+R/wo2L/wA9U/I/4UgP O1e+hsjY6E+t
SaPDFGsqXNk9vJawrNEPLgJjSR8wefyN7gomCGI3T6dd3unaqt7IutP4fH2i K2WSC5nm+ZbY
qXjIab76XWGccA4BCsue92L/AM9U/I/4UbF/56p+R/wpgeaaJbeID4Yubu9n 1o3I+wRtDI8g
ZYPItDdMi/fLnEwyMsGDbMOW3GrRanLc239kXutW1gLUfYPMtL2eZrjzJN+/ dImP+WWPtOYy
DxhQ+fS9i/8APVPyP+FGxf8Anqn5H/Ci4DK57xPbahc3fh86ayRzRaiztNLb tNHEv2adcsqs
pwSwXO4csOvQ9JsX/nqn5H/CjYv/AD1T8j/hSA80vrTWIdO0+1aW9soklu5N Ra3tbqYNdySL
KPL+zOkhiPmTFTuKgYVx5gAFqw0/U7Sw8Q39xFqEupzNBC7M8kYZTa2yyzCG J9pdSJD+6O4l
Civ0r0HYv/PVPyP+FGxf+eqfkf8ACncDzDTX1EjytXl12bRIp5kjktra+gmZ vLt2jyNzXBTL
XQyzFcjthALcdnLYQ3EMketJG2sXE2pi3Nyf9Hke4eEw7PVmhLeRzz8/8Vei bF/56p+R/wAK
Ni/89U/I/wCFFwOJ8MW2rTa5LPqE+prZwWqm0imd1R1M90EL5+ZnEPk5DHPI LguFI7On7F/5
6p+R/wAKNi/89U/I/wCFJgcTrFldw+Lb7XrW1meWwsLR08uMk3EYkufPhXH3 2KMrBMgeYIie
BXP2H9u2lv4XjSLULOa2g022+zra3UiyxERiZnKt5EZAaVSJELjy92RlCPVt i/8APVPyP+FG
xf8Anqn5H/CmBwTW3iBI1jee9ZdMurSyiaN5C13GbqFnmkP8eIBGrMMDcbkE bcVk293qENzb
wAa1Jqsujz/2pHO935Ym8y2WSWJchW2b5WAtyMjCqRuWvU9i/wDPVPyP+FVL TSNNsLi5uLO1
s7ea6bfcSQwhGmbJOXIGWOSeT6mgDzvQra+k12xudTbV57K0nuLe0nW3vIGJ kFo6B1dmlMe5
Z8mUsny4JA2gaXgiLXEvy+q3t7LKbX/TopbSeONLjK/deWRkbH7wDyFEZHJw PLFd7sX/AJ6p
+R/wo2L/AM9U/I/4UXAZXKXrvaeJW/sh9TF3cXULXVqbJjaSghEkkMzR4DLC vAWQDdGBgkkN
12xf+eqfkf8ACjYv/PVPyP8AhSA8w0dfEsFjeSXU+oXV09nsvoWtLqNYpmZA zozSneUBmYLa
hVbbgFSYqn8MQ61d67bw3d5q50y1a5aN2huLZZgBaMiuJi0hG9psbmJO1lB2 ZSvSNi/89U/I
/wCFGxf+eqfkf8KdwPN7bTX1SPQIb1NdOoJeI+rO8t3Escv2S4DGJ8hVTzDj MJCHKjoVFdf4
c+1jSDHeed5kV1cxRmfO8xJO6xEk8t+7CfMclupJzmtnYv8Az1T8j/hRsX/n qn5H/CkwMPxf
BLc+Ctet7eJ5ZpdOuEjjjUszsY2AAA5JJ7Vi3+g6s+r6dc3OpzNNd3SW95Jp kT2yC2jguWVW
+dyMvJgtuHVNu1gGrtti/wDPVPyP+FGxf+eqfkf8KAOGt4b+411YZjq4upLy 6S/O+dLcWREo
h8tsiIP/AMe3MREgO7PO+sLw6fEN5Lod3PqWoZeCxeELbTyrLAYYjKXk80QA ljPkyK0ndcny
xXqU9rBc28lvceTLDKpSSORSyupGCCCMEEdqk2L/AM9U/I/4UwPNBZm603SJ tRj8QNeWt1HN
rJU3gZZDbzIxg29V81wD9n+XBH8FekU/Yv8Az1T8j/hRsX/nqn5H/CkwOb8T 22oXN34fOmsk
c0Wos7TS27TRxL9mnXLKrKcEsFzuHLDr0OVp0t5oc2nyXsGoCGNb1b9La2lm Q3c00UwZEjDF
ozmbY+DtB2sQ+RXc7F/56p+R/wAKNi/89U/I/wCFAHmmgWmuLo8WpXTa1/ak d1pkQSaecqYm
itFnJiJ2H70+5ipIIY5BXI9Ip+xf+eqfkf8ACjYv/PVPyP8AhQ9QOY8XWmpG O11DRTs1KLzL
VZNm/ak67AduCNqzCCRjjhY268q2FFpGrWZKqkwj0u6tNPsPJDgrbNeRySYI ALp9n+zozHPM
Mue5b0TYv/PVPyP+FGxf+eqfkf8ACgDzS3tNcsdD0Xym1pmu9Mjl1bzZ55pF YS2vmBdxLRv5
b3OFj2sSOAWVcR2MCxahfPJF4jTw/NeSuGVb4XLy+RaLGTj9+U+W4GT8nAB6 JXp+xf8Anqn5
H/CjYv8Az1T8j/hTuB53a/8ACYWifab7zppbSKDUriJdzGZjBHFJAgT5Gb5L p9g48x4DnBYV
2eiW13ZaDp1pfz+feQWsUc828t5kiqAzbjyckE5PNaOxf+eqfkf8KNi/89U/ I/4UgOf8XWlx
e6CkFsZlla/siHgQM8YF1ES4BBHygFuQRxzxXKa3pWu2mtXZi1PU57aWKzFz evas7iNftZ2K
tqInbEhhJ2HcN+WymRXpexf+eqfkf8KNi/8APVPyP+FCA8llS9tNV0xtWn1p rW4+zwvNbw3M
M0yKuouibYmaU4HkkgsXxtMmDmvQfDf2v+w4vtnnbvNm8nz8+Z5Hmt5O7d82 7y9md3zZ+982
a1ZLWCV4nk8l3hbfGzKSUbBXI44OGYZ9CR3qTYv/AD1T8j/hQ9QGUU/Yv/PV PyP+FGxf+eqf
kf8AClYYyin7F/56p+R/wo2L/wA9U/I/4UWAZRT9i/8APVPyP+FGxf8Anqn5 H/CiwDKKfsX/
AJ6p+R/wo2L/AM9U/I/4UWAZRT9i/wDPVPyP+FGxf+eqfkf8KLAMop+xf+eq fkf8KNi/89U/
I/4UWAZRT9i/89U/I/4UbF/56p+R/wAKLAMop+xf+eqfkf8ACjYv/PVPyP8A hRYBlFP2L/z1
T8j/AIUbF/56p+R/wosAyin7F/56p+R/wo2L/wA9U/I/4UWAZRT9i/8APVPy P+FGxf8Anqn5
H/CiwDKKfsX/AJ6p+R/wo2L/AM9U/I/4UWAZRT9i/wDPVPyP+FGxf+eqfkf8 KLAMop+xf+eq
fkf8KNi/89U/I/4UWAZRT9i/89U/I/4UbF/56p+R/wAKLAMop+xf+eqfkf8A CjYv/PVPyP8A
hRYBlFP2L/z1T8j/AIUbF/56p+R/wosAyin7F/56p+R/wo2L/wA9U/I/4UWA ZRT9i/8APVPy
P+FGxf8Anqn5H/CiwDKKfsX/AJ6p+R/wo2L/AM9U/I/4UWAZRT9i/wDPVPyP +FGxf+eqfkf8
KLAMop+xf+eqfkf8KNi/89U/I/4UWAZRT9i/89U/I/4UbF/56p+R/wAKLAMo p+xf+eqfkf8A
CjYv/PVPyP8AhRYBlFP2L/z1T8j/AIUbF/56p+R/wosAyin7F/56p+R/wo2L /wA9U/I/4UWA
ZRT9i/8APVPyP+FGxf8Anqn5H/CiwDKKfsX/AJ6p+R/wo2L/AM9U/I/4UWAZ RT9i/wDPVPyP
+FGxf+eqfkf8KLAMop+xf+eqfkf8KNi/89U/I/4UWAZRT9i/89U/I/4UbF/5 6p+R/wAKLAMo
p+xf+eqfkf8ACjYv/PVPyP8AhRYBlFP2L/z1T8j/AIUbF/56p+R/wosAyin7 F/56p+R/wo2L
/wA9U/I/4UWAZRT9i/8APVPyP+FGxf8Anqn5H/CiwDKKfsX/AJ6p+R/wo2L/ AM9U/I/4UWAZ
RT9i/wDPVPyP+FGxf+eqfkf8KLAMop+xf+eqfkf8KNi/89U/I/4UWAZRT9i/ 89U/I/4UbF/5
6p+R/wAKLAMop+xf+eqfkf8ACjYv/PVPyP8AhRYBlFP2L/z1T8j/AIUbF/56 p+R/wosAyin7
F/56p+R/wo2L/wA9U/I/4UWAZRT9i/8APVPyP+FGxf8Anqn5H/CiwDKKfsX/ AJ6p+R/wp/2c
4yXQD/ayP5inYRDRU32f/prF/wB9UfZ/+msX/fVFmBDRU32f/prF/wB9UfZ/ +msX/fVFmBDR
U32f/prF/wB9UfZ/+msX/fVFmBDRU32f/prF/wB9UfZ/+msX/fVFmBDRU32f /prF/wB9UfZ/
+msX/fVFmBDRU32f/prF/wB9UfZ/+msX/fVFmBDRU32f/prF/wB9UfZ/+msX /fVFmBDRU32f
/prF/wB9UfZ/+msX/fVFmBDRU32f/prF/wB9UfZ/+msX/fVFmBDRU32f/prF /wB9UfZ/+msX
/fVFmBXdwk8UWMmRGfPpggf1p1RTf8f9r/1wk/8AQ1qhrWnRaqtlZzsyo9x1 UKTwjn+IEU4p
OSTFJtJtGmzKiM7sFVRkknAApI5FlQOhyD6jBB7gjsfaqEPhO2gsZLaGdwTy rPFGQGGcZXaA
w56H9Dg1JYxeVNeFpA7tNuYhAgGQGAwOpw3LHk9+2Iq3hVUFqn1HTfNDmejL tFYXifVta0e0
gn0bQP7ZZ5RHJEt0IXTcQFYZUgrk8nI29emSNmAytbxtcIkcxUGRI3LqrY5A YgEjPfAz6CmM
BKpOFWRuv3Y2PQ4PahplQEskqgAnmJhwO/So1uGt1SYKCqGVTlguMv7/AEpJ Ls3cUsoUBFhk
TIcNknHp9K1UETcs00uAxUK7EDJCoWx+Q9qdWJHf3hhE4lw1xFFIhhiICghi VJ2vkgnrgdR+
Kp03PYJSUTYjljmQPG4ZT3Bp9YdtPcQ7ZCUAzGkoeI5kLSFQQwCDgEfw+npk 7lKUJQ3BST2G
lwLlocfdjR8/72eP0p1RN/yE5v8ArhF/7NWH4wikOi3FwFufLggld3trt4nQ bc5CAhZBxyGI
wAcZJxU21sNuyubVve213FbywzKy3EXnRDoXTj5gDzj5l+mRU9eeZXTdHi1G xvp7d/sxVYAQ
626Btzxx7w2HG3Bz12ngYGztdJvRf2CSmdJpASHKwPBg9QDG5LLwQeeoIPQi h26EQqKReorn
tf1jxBp2pafb6V4cTU7e7by3uDe+SLduSS42NhMDO4Z5GMZKhuhpGhQvNa0+ wl8qef8Aed0j
RpGHpkKCR+NTWWoWmoxl7WdZAvDDoy/UHkfjXIfD64GrXerrqMIw0e6UyDGS Wyx9ug+mB6VB
pF7AvjkQadNJPakvH5rJt3LtZvxAZV546n15zUpXV9mckcQ3Z9Gd/RUc5lW3 ka3RJJgpMaSO
UVmxwCwBIGe+Dj0NY3hjVta1i0nn1nQP7GZJTHHE10JnfaSGY4UALkcHJ3de mCdDrNW7vrax
RWuJQm44VQCWY+wHJ/CmWWp2eobvs0wcr95SpVh+BANc/rMlxaeONHupXVNO ClWdjwrDcT+m
364rPsdTivPGv2qwtZYbDD8KjMzgDkhAMgbmTjtkZxkVDk0zn9rJ1ORK+u3X 1O7oqOCeK5t4
riBxJFKgdHXoykZBH4Vha/rHiDTtS0+30rw4mp2923lvcG98kW7cklxsbCYG dwzyMYyVDWdD
03OhpruEniixkyIz59MED+tOqKb/AI/7X/rhJ/6GtAEjuqIzuwVVGSxOABUc d1bywtNHPE8S
53OrggY5OTUN46rcWAcZU3HIPQ4R2H5EA/UCsa5uf7U8U3liLlfJFijAhFk2 yB2HzAj5gMn5
TxzkYPNZObvK3RXKsklfqdFHIsqB0OQfUYIPcEdj7U6s/S1Ie8MjK0xn/ebA AuSobAAAzjdj
cRk4yewFXxBKynT4hZPdLJcHKgrjIRsA5I69fwPTjLjUvDnHye9ymqbmECQ+ YpMTBHCnJViA
QuBzkhhgdTketSKyuiujBlYZBByCK4ezupIXvpRpj24troSCRhGUGFU4brjO PvAErnjuK67T
bY2ljHGxO8gM+VVcMeuFX5V+g/UkkqE5Sla2g501FblmSRIo2kkdURRksxwA PrVZNUsJULRX
kEqqcExyBsdeuPYE+wBPasjUSl/4xsNKukaS1EDXAjBwJHG7APrjHH1rD/ty V7b7UNF/s+NW
kgEhiDISVI27SCd3JORgHG08cipuSjeKucvtoqdpaI76io7eFbeBIVJKqMAn /OB9BgDoABWF
d6x4gh8WW2l2/hxJ9MmXzG1P7btWJRjcGTYTvyeFz82c5GG22rtGx0NNLgXL Q4+7Gj5/3s8f
pTqib/kJzf8AXCL/ANmoESEhVJJAA5JPaqVpq9hfTGG3uA74yBtI3D1GRyPp UOoeXdy3dncX
DQwLahiyttxv3gsTkdAvQ8cnIPGPOzoeoacirbxveB2bfm2mORgYyHUDHXjJ 5x6ZCjVo8suZ
2a2Xcc4zjHmSb9D1iiuf8HfbDoZa84zM4iXptUcYx2+YNx2/StTUL77HGAqF pHBIO0lUA6s2
OgGf/wBXULmVriheS1VmTT3MVsF8wtljhVRC7H8ACadDNHcRLLE25G6HGPau dt7w3d+1vLEt
xdE+bHIMhFCkcEZ6AkEdecHqAa6C1txa24iDFuWYse5JJP6k1EZzc3GStY1l FKKaZJK4igMm
M/OiY/3mxTqivP8Ajy/7bw/+hiotRguLiwlitZfKnbGyTcRsOR83HXHXaeGx g8E1sZFqiua8
P6ZI3h2BLu4AuEMbQhsyLBsK/KV4ww27Dg9ieCzZ2DNPBcW6TTwzLO5jASEx lTtZs5LHP3cY
9653iIc/KnfzNFBuNy7TPOj87yfMTzdu/ZuG7b0zj0pl3JLDbO8Kb3GOMFsD PJwOTgZOBycY
HWqdwdMhS2mOq/ZmKuVm82PM27aSSWBB+6vToMAcYFOrWUNAhDmNKiqFhcrP cTpDd/bLdFQr
PlT8xLblyoA4AU46/N7ioPEeo6lpOizX2laT/as8PzNarP5bsncp8rbmH93v zjJwDpCanHmR
MouLszWoqppk17c6bbzajZpZXbruktkm80RH+7vwATjGcDGc4JHJlMsQkcTX DREH5QNoyMDn
kHvn8qtK5JKrK2drA4ODg9DS1FvtxbqYJDJICdrZB35JJBx75+n51LQ1YAoq CKS5e7kja2VI
UGfOMn3s9ABjr/L8sz0hjQ4M88YH+qfZn1+UH+tJLNFBH5k0iRpkDc7ADJ+t NT/j9v8A/rv/
AOyLWJ4yjtf7AluLiVY3g+eHcMh3xwmO+ent1olpsaUYKpUjB9TdlmihCmWR IwzBQXYDJPQf
Wn15HaajHqV/ZWV/dstru8tmkfcIRj7oz0yQF3HpmvW1UIgVegGBzUQlzHTj cE8I1GT1YtQ/
aoDbfaFlV4ezxncDzjjHXnjioXdZ742s4xCq79h/5bjv/wABHGR1ORnA+9Bc iCyLSmaaUtI0
kFqduGlLFh2ycE55OBjJ6ZrGeJUZcpzRp3VzRjkSWNJI2DI4DKR3B6UiSpIz KpyV68Ef56Gm
2sP2a0hgH/LONU49hioVYB3iZzHKrEqVx8yk57jnHNdMU2tdzN76FpWV1DKw YHuDmlqFmSJI
xGDkAJg9XwMfnx/ntNTasIKKxJxCZryVokNwl/bokpUblU+TkA9QPmP5mjSh CG0tookR5bBn
lZVAMjfuuWPc8n8zXL9Y9/lt/V7G3svdubEj7AnGd0iJ/wB9MBn9aiEctxfS RLcSRKkSsAiq
cklh3B9BT5+kP/XeL/0YtLbf8hSf/rjH/wChP/n/AB6V1IxIxCpvGtBqkv2g RiXy9qZ2kkA/
d5GR2/qMzfYJf+f+f/vlP/ifp/nGYDbR3evXiuzIy2sDRyKfmRt83I6+p68E Eg5BOZbHU4bq
4msmnge8g4kWJwQRnG4DJI54IPIPBzkF6stguF5MljZyzybmSGHzGxjccLk+ gzUQuZisJ+w3
AMhww3R/u+erfN+PGafqjSJYXLwzRwSrbkpLKQEQ7OGYnsOpqaoadxplaC8E 13PbGCWJ4QrZ
fbh1YsARgn+6euDVmqkMhk1S7CrCY4440MikF9/zMUbnIwrIQCP4/em6nffY bdCoUyyv5cYY
4BbBP8gcdMnAyOomT5I3kG+xCmvWT6ibLc6vv8tXYAKzcjA5z1BGSMEggEni tOvPJ/s9/fi7
Cub2NzLCIVIUyr98GIkkOAu7aGwxTkZHPR+F9an1ZbyOZGb7LIEE5HDkjJGQ ACRweg4YZAOa
56Ndylyy67A1Y6CisLxPq2taPaQT6NoH9ss8ojkiW6ELpuICsMqQVyeTkbev TJGzAZWt42uE
SOYqDIkbl1VscgMQCRnvgZ9BXUAsT+bBFLjHmRq+PTIBx+tRm8gDld53A4IC k/0p1p/x4Wv/
AFwj/wDQBWdqTx21gki28PmSyyDzXRSchjhckYyRnr6fiKSWtxNmiLiM4+/g kDJjYDn8KlrJ
0u9t9QsZSLaFLiCSPLogXILYBx2PBBHt74rWokktgTMlPEmly/clmbPpay// ABNWodTtZ5Uj
QzBnOF3wOgJwT1IA6A1zlvZTSukNlpOmuiW0chZtPhkbmPIyftCtlmBAJQDP fALVesUP9pZk
023szHdBEVIIkdAYpG2sUlfJxtPIX1wc8dM6VJU+dP8AFHPCpUc+Vo6Giiiu Q6QooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACiiigAooooAKKKKACiiigAooooAKUAkgAZJpKlGYk3EYdvu8dB6 0AJkR8ABm7k8
gfSmEkkknJNJRQAUjMqIzuwVVGSScACsrxJbw3eiSW9w+yGSaFXb5eB5qc/M CPzFZOn6Bplu
L2O0upZMOEjlisY5U+4Dzsjw3LHg+3Q4NWopwbT17f8ABIcmpJW0OqjkWVA6 HIPqMEHuCOx9
qgs7ae4soJ3vpg0iBiAqY5H+79f85xX0bMltLcyf62aaTeoXaAQ7DGMD06kb j37APmvo9N8J
C6kkkjCW6gPHt3BiAARuGM5I65H5cZ023G8i52jfsQRalpc919mi8RxvKQuA rxfNuJAAOME5
HQcjIzjNWJWhg1G3sJNUuFurhWaJPKX5gv3udmBj3x/PHn9gDcXCRw6vKhjN ruPnxbI4o3A3
Asg5XdkA+o+927N7PUL/AMZ2OotaLDZWUcqrN5ysJgwwCoHI/HHTrxxdFc93 LQmc4tJ03e5s
fYJf+f8An/75T/4n6/5zg+wS/wDP/P8A98p/8T9f85xzd3rV9oWua1C95JqA Fvaz2drcLtIe
SS4DRp5ELSMAkIONrsAhJIAJVYvHiyaeZzpzRzSQN9khkdkNxcpcG3eH5kBj AlMADOF4lBKr
sYLXKO50f2CX/n/n/wC+U/8Aifr/AJzhyWrQ72e5ll+XgMFAHI54APr/AJ6Y q+LR/wAJbHo5
tN9tNK0EN5EJmUyqjOysTEsQx5cinbIzBlwVGG2dHJ91v93+o/z/AJwE1YCh LOyTpDHbyTSO
rMAhUYAIB+8R/eFJb3SXJkUBkkjbbJG+Nyn8CR+IqvcgPqtvERkPbyjpn+OL tg/yqK0gu7iC
11SGSB5Z497Ry4QBGAIAKpnd93JOQcHAGRjCpNU7NvcuMea5qUVyHiq7uJm0 m18i+kf+1DBc
W+m3hheUfZZZAFk3x8D5GOSPu9+M0IvEGuR6Xo9ppdu93dXa3c4MqLNJBDHK qrFIrzRfvFEq
I5Llg0bAhiSw0i1JXRLVnZnfUVwt3401KygGpXlnDa2bWDXNtAq/aBeutsZ2 VLmN9keMMPmQ
7ghZS2cLfTXtWs/E1noV81lcyTSxl7iCB4R5bxXTBQhdvmDWw+bOCHxgYyXY R1dFcKnjLVt+
uXDW1k1npFrcXMijeskvlz3cSoOoGRboS3OCCNp3Apb1bVfE+m3FlptulrqF /crNcGW2sgqp
FGYl2mOS5XJJlzu8zjGNpzkFgOvoqppd42oaRZXrxpG9xAkrJHKsqqWUHAde GAz94cHrVukM
hfe99EfLYJHEylyRgksp45z2Pam3MEsr28kMqRyQS+YN6FgflZcEAj+961YJ AGTwKjSSWZd8
FpPLH2cbVB+m4jI9xxT1YiWee6eILE8KP3LxllP4bgf1qtbQzRvcS3Escks8 gcmOMoowqrgA
k/3fXvU2Lv8A6B8//fcf/wAVRi7/AOgfP/33H/8AFUuV7hcdRTcXf/QPn/77 j/8AiqMXf/QP
n/77j/8AiqdmBWMNwHUoUGyRnB3kHnPoPeo/s10TOzMjGVduS5OOvqPeruLv /oHz/wDfcf8A
8VRi7/6B8/8A33H/APFVfNIVkOrkjoXiCD91bajCYE+WPe207R0yNh/nXV4u /wDoHz/99x//
ABVGLv8A6B8//fcf/wAVTp1J09hSipbnNWmi6213C19fxG3SRZGVDuLFSCB9 wdwO9dPTcXf/
AED5/wDvuP8A+Koxd/8AQPn/AO+4/wD4qipOdR3YRio7Ea73vppTGyJ5aIpY j5iu7JGD05HW
lubaK7t2gnTfE+NyZIDDPQ+oPQjoRkHINPxd/wDQPn/77j/+KqrJqHlSCOW1 uI3JIAk2pk5x
wSwB/DPUVnZlGRF4Q09768uruEMs9x5q2ySMIVACgZUYDE7dxyMZYjnGT0dV /tMv/PlP/wB9
J/8AFUfaZf8Anyn/AO+k/wDiqG29xKKWyLFFV/tMv/PlP/30n/xVH2mX/nyn /wC+k/8AiqRR
h6h4SW4kunsb17Rbz/j4j2blfnPYgjJ5POKsaD4ZtdDLSrI01wy7C5G0Aeij t0HUnpWp9pl/
58p/++k/+Ko+0y/8+U//AH0n/wAVS5Ve5kqNNS5ktSxRVf7TL/z5T/8AfSf/ ABVH2mX/AJ8p
/wDvpP8A4qmaks0MVxEYpokkjbqjqCD+BridZ8Galc6vLcaZdWttbMBshwAF 4Gfl2MOSM/ie
mTnr5Lx4o2keznCqCxOU4A/4FTvtMv8Az5T/APfSf/FVMoqW5rRrSoy54b7G Z4W0e70TSWtb
ydZpDKXBUkgDAAGSBnp/+s81t1X+0y/8+U//AH0n/wAVR9pl/wCfKf8A76T/ AOKppWViak3U
k5S3ZYqF9730R8tgkcTKXJGCSynjnPY9qb9pl/58p/8AvpP/AIqpIZ0nUlCc jgqwIIPuDTII
7u0W7jRS7xsjb0dMZU4I7gjoSOR3rPh8Px27yvBe3EbStukKJCCx9T8nJqzq us2Gi23n39ws
S87QerHGcAdzXP8A/Cy/Df8Az3uP+/Bq44GpXTlCm5LyTf5EvERpu0pJetjp 7S0W0jdQ7yM7
b3d8ZY4A7ADoAOB2pmoaemoRRq00sLRP5iPEQGBwR3BHQntXN/8ACy/Df/Pe 4/78Gj/hZfhv
/nvcf9+DWyy7EpcqpSt/hf8AkR9bpXvzq/qi+vhZT9qSbVL2SKd8snyDI2gE E7eeh5GOMDtk
9BXIf8LL8N/897j/AL8Gj/hZfhv/AJ73H/fg0LL8StqUvuf+QSxdKW8196Nz WNEh1dImMjwX
MB3QzxnDIf6jgce1U7fw3K95Fc6rqk+omA7oo3BCq3qQSc1n/wDCy/Df/Pe4 /wC/Bo/4WX4b
/wCe9x/34NP6hiv+fUvuZk6mGb5nJfedfRXIf8LL8N/897j/AL8Gj/hZfhv/ AJ73H/fg0/qG
K/59S+5/5F/WaP8AOvvR19Qrve+mlMbInloiliPmK7skYPTkda5b/hZfhv8A 573H/fg0f8LL
8N/897j/AL8Gj6jiv+fUvuf+QfWaP86+9GzqGjy3WoLdwXaxnYqtHLEZEO0k qcBlOQWbqSOh
xkZoXTL52C3F/E0J++sMDRsR6Bt5x+WfTB5rKh+I3hyeZY1uZFLd3jKgfUmt y11WO9iWS2he
VGUMCjxng9D96uOtgOSXNVg033ujop4rmVoSTXyLqIkUaxxqqIoCqqjAAHQA VLbutu0jhMyP
j5iegA4H06/maqfaZf8Anyn/AO+k/wDiqPtMv/PlP/30n/xVDinuK5W07R4N OlmmXDyyuxDb
cBEJyEUdgOPrgegA0ar/AGmX/nyn/wC+k/8AiqPtMv8Az5T/APfSf/FU0raA 3cddb3hWJI2Y
tLGxYEYUKwJzk/yqaq/2mX/nyn/76T/4qj7TL/z5T/8AfSf/ABVAFXUNIjvW BDqivIjTxsm5
ZQrA8j1+UDPpwQcDFm306xtJDJbWdvC5G0tHEqkj0yBS/aZf+fKf/vpP/iqP tMv/AD5T/wDf
Sf8AxVQqcE3JLUpzk1a5YqpHp0MWoG8RnVijL5YI2AsQWYDGQSVHfHU4ySS/ 7TL/AM+U/wD3
0n/xVH2mX/nyn/76T/4qqcU9xJtbFiiq/wBpl/58p/8AvpP/AIqj7TL/AM+U /wD30n/xVMRY
oqv9pl/58p/++k/+Ko+0y/8APlP/AN9J/wDFUASRwpGzMMksScntk5wKkqv9 pl/58p/++k/+
Ko+0y/8APlP/AN9J/wDFUAWKKr/aZf8Anyn/AO+k/wDiqPtMv/PlP/30n/xV ADoN7TXUrxtG
JZdyqxGcbVHYn0NUtb0Kz161SC88wCNw6PE21lPQ8+4JH4+tW/tMv/PlP/30 n/xVH2mX/nyn
/wC+k/8AiqHqVCcqclKDs0ZWoeD9F1G2t7d7XyUt8BfIOwlO6E9wfz981uKq oioowqjAHoKg
+0y/8+U//fSf/FUfaZf+fKf/AL6T/wCKosOdWc0oybaX6jrm2S6i2MWVlO5H Xhkb1H+cEEg5
BIqDTdOSwhbPlPcSO7ySpHsLFmLepPGcdT0qX7TL/wA+U/8A30n/AMVR9pl/ 58p/++k/+Kqe
SPNzW1J5nbl6FimuiSDDqrDrgjNQ/aZf+fKf/vpP/iqPtMv/AD5T/wDfSf8A xVUIdb24gRRn
cQNoOMYHoBU1V/tMv/PlP/30n/xVH2mX/nyn/wC+k/8AiqAIZNMWS4eT7TOq PKkzwjbtZ124
OSu7+Beh7UWemLZvEwuZ5RDEYYlk24RDt4GFBP3V656VN9pl/wCfKf8A76T/ AOKo+0y/8+U/
/fSf/FVHs43vYrnlaxJMpYR4GcTRsfoHBP6CnW0b/wBoTPsYoYkUNtJGctkf r/npUP2mX/ny
n/76T/4qj7TL/wA+U/8A30n/AMVWiZAXuiJqF3LNNNcqjxIgSIshVlZmD5HO QW4HTIycnFLp
MV7GZ/tMBiVyrbAMjzMfOUxnCE4IzzkuSOcFPtMv/PlP/wB9J/8AFUfaZf8A nyn/AO+k/wDi
qdwsSanZpfWdxZTF1SeAxOV4YBlwcZ781WFlcBbcHVLsmJiXJWLMwznDfJwO 3y7Tj35qX7TL
/wA+U/8A30n/AMVR9pl/58p/++k/+Ko5mLlRQ0nw/BpF9e3MVxdSG5kDBZbm WQKNiLghmIY5
TO484OOgq9qFhDqVm9tPu2tyGU4ZGHRgfUf54pftMv8Az5T/APfSf/FUfaZf +fKf/vpP/iqm
XvfENK2xiaZ4U+xasuo3N79pljz5e2Ly/wCHaC3zHcQpIB44PsMdHVf7TL/z 5T/99J/8VR9p
l/58p/8AvpP/AIqphCMFaIyxRVf7TL/z5T/99J/8VR9pl/58p/8AvpP/AIqq Akt1KWlujDDJ
CisPQhQDSNG72z2ziCSBySVkiJ6nPr60z7TL/wA+U/8A30n/AMVR9pl/58p/ ++k/+KpptCsN
trJLO2NvbpDHEzq7bVYsSCD1LE9qtVX+0y/8+U//AH0n/wAVR9pl/wCfKf8A 76T/AOKobbAy
YvDNujb5LXSZ5TGkbST2BcsFGAeXxn1IAzx6CprPQYrO8FxDDYQZk8xxbWpj 3EIUA++QBznA
HXnvWh9pl/58p/8AvpP/AIqj7TL/AM+U/wD30n/xVF3awWLFFV/tMv8Az5T/ APfSf/FUfaZf
+fKf/vpP/iqQyxRVf7TL/wA+U/8A30n/AMVR9pl/58p/++k/+KoAsUVX+0y/ 8+U//fSf/FUf
aZf+fKf/AL6T/wCKoAsUVX+0y/8APlP/AN9J/wDFUfaZf+fKf/vpP/iqALFF V/tMv/PlP/30
n/xVH2mX/nyn/wC+k/8AiqALFFV/tMv/AD5T/wDfSf8AxVH2mX/nyn/76T/4 qgCxRVf7TL/z
5T/99J/8VR9pl/58p/8AvpP/AIqgCxRVf7TL/wA+U/8A30n/AMVR9pl/58p/ ++k/+KoAsUVX
+0y/8+U//fSf/FUfaZf+fKf/AL6T/wCKoAsUVX+0y/8APlP/AN9J/wDFUfaZ f+fKf/vpP/iq
ALFFV/tMv/PlP/30n/xVH2mX/nyn/wC+k/8AiqALFFV/tMv/AD5T/wDfSf8A xVH2mX/nxn/7
6T/4qgCxRVf7TL/z4z/99J/8VS/aZf8Anxn/AO+k/wDiqAJ6Kg+0y/8APjN/ 30n/AMVR9qk/
58Zv++k/+KoAnoqD7VJ/z4Tf99J/8VR9qk/58Jv++k/+KoAnoqD7VJ/z4Tf9 9J/8VR9qk/58
Jv8AvpP/AIugCeioPtUn/PhN/wB9J/8AF0v2qT/oHzf99J/8XQBNRUP2qT/o Hzf99J/8XR9r
k/6B83/fSf8AxdAE1FQ/a5P+gfL/AN9J/wDF0fa5P+gfL/30n/xdAE1FQ/a5 P+gfL/30v/xd
H2uT/oHS/wDfS/8AxdAE1FQ/a3/6B0v/AH0v/wAXR9rf/oHS/wDfS/8AxdAE 1FRfa3/6B0v/
AH0v/wAXR9rf/oHS/wDfS/8AxdAEtFRfbH/6B0v/AH0v/wAXR9tmH3bCVfp5 f9WpiLITy/mk
HPZe9MZizFj1NVjdOvL2lwq9zhWx+Ckn9KmR1kRXRgysMgjvSGOoqMSs8jJB DLMy/e2AYX2J
JAzyOM5p2Lv/AKB8/wD33H/8VTsxFfULWS8tPKilWKQSRyK7JvAKOrcjIyPl x1FRRJrUMs8i
3+nkzOJGzYvwdqrx+99FFXcXf/QPn/77j/8AiqMXf/QPn/77j/8Aiqa5lsGh BYW0lpamOWVZ
ZGlklZ0TYCXdnOBk4A3Y6mnDTY77w/HYXsEhjeFVddpBBGD+YIB/AfhLi7/6 B8//AH3H/wDF
UYu/+gfP/wB9x/8AxVCT7CaTVmcPrHgjULCNV0AXE3m5E0khQSgZBCjIUBeM nucD6V2Xh2wu
tL8P2dndkvPEh3lVOMkk4/DgfgPwmxd/9A+f/vuP/wCKoxd/9A+f/vuP/wCK rT2j5FBLRCjC
MVaJRXwlpCwPGYL13Z1f7S95cPcKVBC7Zi/mKAGcYVgMO/8AfarFp4e02xt7 KCC1l2WU8lzA
ZJJJGWVxIHcsxJYnzZPvE/e7cbY5NQ8qQRy2txG5JAEm1MnOOCWAP4Z6ipPt Mv8Az5T/APfS
f/FVnzFWI18MaXHq8eppb3K3EUrzxoLibyUkZWVnWHd5YYhmyQoJLE9Tkasg OxvlYDb3GO4/
z/nAzvtMv/PlP/30n/xVH2mX/nyn/wC+k/8AiqOYLDp7S2umRri3hlMZyhkQ Nt+menQVmw6Z
qdrBHb2+o2wgiUJGJLVmYKBgZIkAJx3wPoK0PtMv/PlP/wB9J/8AFUfaZf8A nyn/AO+k/wDi
qxqUoVPiRcZyjsQWmmrFmW6MdxcmbzxJ5WAj7PLygJJX5OOvduxxS3miaTqM bx32mWV1HJKJ
nWe3Rw0gXaHII5baAueuBipvtMv/AD5T/wDfSf8AxVH2mX/nyn/76T/4qrjF RVkJtt3YyPS9
Pi1KXUo7C1S/mXZJdLColdeOC+MkfKvGew9Kgj8O6JFpsumx6Pp6WEzb5LVb ZBE7cclMYJ+V
ecdh6Va+0y/8+U//AH0n/wAVR9pl/wCfKf8A76T/AOKpiGWOl6fpibLCwtbR NoTbBCsY2gsw
HA6Zdzj1Ynuaqf8ACL+H/sH2D+wtM+x+b532f7JH5fmYxv24xuxxnrir32mX /nyn/wC+k/8A
iqPtMv8Az5T/APfSf/FUAWKKrG72czW80Sd3YAgfXaTj69KsggjI5FAEMyLL NbQv/q5JcMPU
BS2PodoB9qsapfT2kth5Eckvm3BR4o9u518tzgbiAOQD1HSq8hxd2Z/6an/0 W9N1VbmWbTja
lVdLksXeMuqjypBkgEeuOo5IrSDJZlab4vvb3xR/ZksEUcRkdNp271x5vBxI ef3a/wAPfsNp
OxqHirStL1A2N3NOkqxLPIy2srxwxsWAeSRVKRrlH5YgAKSeBmsLTrbxDH4l 867eRrPzG3EO
QhH73BC+acDmPjb27YyztR8OT6v4o1KW4urqDSrrTbe1lihMW26Ae48yN9yl 1G2RRlSp+c4O
RxlRcrPm7mtZRuuXsdnvqnJqkMWsW2mMr+fcW8twjADaFjaNWB5znMq447H8 fNtY8O+Ib3xJ
c3djDPZ39x9qibUIPs0Nv5TW8qQZdf8ASWYN5BYNlQykqMKmLcnht729sn0z w5HollDb3Sz2
MqwRxXTM9sQkggZvkcRsCRn7mGVlOx9rmR6Vvo315NqOg+I9S1yW/tLO603U btLlJLtDaRRJ
G1tKkIaSMm4Z1YwbgSyh0JXIVCMyLTrPxLd6hN4c0X7Jo6/Y/tVtp4sXF0VF 3lQAz27sGkgY
q5yAoOM7MlwPYNT1a00ewa9vXdYFdE/dxPKxZ2CKAqAsSWYDAHejTtVg1S3a e3S6RFcoRc2k
tu2cA8LIqkjnrjHX0Ncbd6HeL8OrfS47W9nljureb7OLqNZxEt2kpRXTy0Rl jGAEIVMBVYgA
l89he3+mWkFjpWo6fcwPIFuNQ1HMoiO0vH5qSSORLnZ1+TbvGGjjDFwsd3vo 31z6Xd5a6fNH
Y6D5cdvYRvaW3nRx7pMP/o+FyqbdsY3ZK/PxwtX0uLg6hNC1tttkijaO48wH e5Lhk29RtCoc
99/saLhYde6hcW95bQQWqzecrsS0uw/Lg7VyMM5BYgEj7p5wCREdUknu7eAW JNpclkLTZSTA
UksYiudmcLkkcsOMEEw6i1w9xaolo1xbgmRgrqmJFZTHuJOQmck7QT8o4IyC wNfrqsEjwK7u
PLuLiLCxNGAzL8pYsrhjjjIIYknoFLhYsz2jWmZLbc0OctAB90eqf4fl6FEd ZEV0YMrDII71
c31RniaCRp4FLIxzJEP/AEJff1Hf69YaGMu7y3sIVmuZNkbSxwg4J+eRwiDj 1ZlH481GdStR
qR07e7XQVHZFiYhVfzNpLAYAPlOMk9QB1YZzvElk2u6Cltakyh7y0djFN5ZC JcRu5DAgghVY
8HPHHOK5bWfBmp/21M+ivdIkkCLHd3OoSStFL9nv49wZ2ZwA08P3f72QODSS QHotFeb6d4Kc
3Fkj6bexaaL9ZZ7a6e1iG0W9wpbyrUBCrGSNWyWLj5WXavNfxJ4Z13UNT1Ke 206b7VdRXkMk
0ItI4JoWtpUhQvxOzZ8jIclAwJHCqQWA9QqppeoRatpFlqVurrDdwJPGsgAY K6hgDgkZwfWu
fk0CGz8R2sh0L+0bFIoUtWPlyGymEkjSzMZWDbn3xsXXc7GMluQM4UPhRNF8 Nae0lvDpEdto
TSalcwRqfLvIjbyRSuqH98yNHKw6g/MP4uSwHoF//wAg66/65P8AyNM1Kee3 smkt1zJvQf6p
pNqlwGbavJwCTgelZmnWdxbeH725vo/L1C/D3V0mQfLdkAWPI4OxFSPcMbtm 7qTW9SGYVxqN
5HbSyQXXnSqhKRf2JcrvYDhcluMnjNaOqXE9rYmS2UNMZY41BXdnc6r03Lk8 +o+tXKq6hDNP
bKIAhlSaKUCRioOyRWxkA4zt9DTEZl7ceIbOxuLprQ7YYmkO62jA4GecXJOO OwP0Nak6hby2
kHDMxjb3G0t+hH6mo9RudXv9Mu7P7BYx/aIXi3/bHO3cpGceVz1qW5/19p/1 1P8A6A1OVugI
8c8czz3vim6SViUgby41ycAdfz/wrqpfBHhm30vS5pY75rjUdkcYjkG0SMm4 Zz0XioYrK1uv
iBqP2qIS/fKIyhlLYAOQQc4UsR7gVsC5F5a+Hftl1ZWS2pS7cOxTPy/KqK+D jJYc8gBepr2M
VjlH2GGhJxtC7s2tWk+no38zgoYZyVStJJ+9ZXV9meYa5oMmiatNYynLJgjn sRkZ/CoL7R7j
TniW4Ef71PMRopkkVlyVyGUkdVI/Cuq8WNBqXi24liuImhcxqJgdyAbVBOVz kD2zVqyvLWya
BIL5FuLa28gTlriOF1MskjY8vEmfmTGQBw3+ya+iwuLqvDQm/efXz8+x5Fal BVpRWiOB+z1L
b6e91OsMZjVmzgyyrGvTPLMQB+Jrs77ULIm+e2RRIkk0FkVUqBbysxOFxgAA uMHn9922Cnaz
dWVzoSW0U8cpimj+zKzTNLHEFcENv+RT9zIjwCR6AY6frM3b3Xr+H9f5mXso 6+9scfqGj3Gm
XTW10I1mX7yxzJJtOSCCVJAOQeDzUVtp8t5dQ20Cb5pnWONcgZYnAGTx1rvL bVbaHWNbuIJo
Ynursyw3EpnQeXuckZiw4zuQ4PHy88gU621izgWGZpvLijvBOtrYh4t4E28+ bGcxnCjC7WyM
KDkDKx9aqpW5NdPy/Qr2VO/xaHnn2eny2bRSvG20sjFSUYMMj0I4I9xxXSTQ zTXzTrqct5qI
miEMkYkZ5Tg/MGYBsqQoAxnnjpXR3N/p4k1mIXULQ3Et27xyPM2+Rt/ltGq/ uiv+rOW5BBPZ
a0nipRtaNyI0k73djzX7PR9nruDqNrLc20jFo3nl+13bqWH+kKCqEkchd25z swcSkDlRVXxJ
LBf3drLHJDLKLfbPJF5pDPvfHzS/Ox27Rk56YHAFOOIk5KLjYTpxSbUjPtvB OqX+l2d/p8aX
kdxIYikLZaFgf4x/CO+egGM4yKjmgvvCOvyQW97G89u43tA5MbHH3T0zjJB9 Dmun8P8AiiDw
xpkaWFi0t5NLuvHmbClFJ2qmDwcHqRwc8HjHP6pFYSanO+mRTR2bNmNJsFl4 5HBPGc45PGK8
+hVxFWq6ddN09d0tdevby7nXVjRhTU6T97Trt6fr2PRvCfi2PXYBBclY79B8 y9A/uP8ACuor
wmAS206TQuySIcqy9Qa9R8NeKItUgEF2yx3aDnJwH9xXh5rlf1d+1pfB+X/A PRwWNVVck/i/
M6WiiivEPSCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigA
ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKzdQuNQW+trWwiEjSRSSP8Au1cjaUH8 UiDHz+p7cVpV
UmF3DqdveWsME2yGSJklmMf3mQgghW/uH86atfURTW41iC+s47y32QzymMlo ET+BmGCsz8/L
6evNWJGNsb8x9ohMB2DENn/0HP1Jp9xJqN/c2RntbWGK3mMpMdy0hP7t1xgx r/e9e1R3n/MQ
/wCvQf8As9N2voCDxAjWmn6ZFAt81ulziYWZkEjL5UnJ8r5vv7SfeqGnate2 ayxwiNRcXhW2
j1m8mhkYeXEMR71ZmG8t+J461e8SakbCGwY37WMUt15csy7MhfLkYDLggfMq 9qxredNVc3Rt
73XRZ3ZW3nhnij2gLDJhsNGrjeAeh+7zXfTT9ldrT+vl+JxVGva2T1/r5/gd c2pNYaUbzV/J
t2T76wM0oyWwqr8oZmYlQFC5JIABOMv07VrTVbdprR3IRyjpLE8UkbYBw6OA ynBBwQMhgehB
rAurGR7HSLux0sWr6ZdNdLpw8tC4McsbKpUlAxEpcc4JABK5LLmXVhqlzrtt 4o/sydWgliH9
m+ZEbho0iuk3Z3+XuLXWdu/G1M53HYORvVnXHZHVan4isdLt9UlmZ3fTbL7d cRRr83lYkxjO
ASfKcYz25xkVoQ3KzoXQOAHZPnjZDlWKnggHGRwehGCMgg15M/hTUZ7LW7if w75l/qVhfQ2b
O0DSWTvNeSAM2/5fMW4jX5C3IO7AGTYbwbeSx+JbqXSYH1FrW4/smdjGZIp2 ur2VGjfOY2xL
A27IwSOcqcK4z1XfVC91C4t7y2ggtVm85XYlpdh+XB2rkYZyCxAJH3TzgEji NH8NX1p42k1O
4jvTN9quJZLvfbLDLC5fy49yp9ok2q0Y2OQgMeQSEQHrNRa4e4tUS0a4twTI wV1TEispj3En
ITOSdoJ+UcEZBLhYmOqST3dvALEm0uSyFpspJgKSWMRXOzOFySOWHGCCSe0a 0zJbbmhzloAP
uj1T/D8vQ1g1+uqwSPAru48u4uIsLE0YDMvyliyuGOOMghiSegXU30nZgU0d ZEV0YMrDII70
6o54mgkaeBSyMcyRD/0Jff1Hf69VjljmQPE6up6FTkVmyh9FFFABRRRQAVl3 l5cxag0KyeTA
IkZX/s+a43sSwIyhAGAF6+talFAGXZ3lzLqCwtJ50Bidmf8As+a32MCoAy5I OQW6elF1cao+
qSWthD5iRwxyMRCrnLM453Sp/c7Z79K1KqA31pqk91a29vOk0McZEs7RlSjO eyNnO/8ASqVr
6iK1rcaomqR2t/D5aSQySKTCqHKsg42yv/f747dat2aiMzxL9yOXCj0BUNj6 c00m+u9Ugurq
3t4EhhkjAinaQsXZD3RcY2frT7b/AF93/wBdR/6AtJ2voAXBxcWn/XU/+gPV rdVW5/19p/11
P/oDVYpDHbqN1NooAduo3U2igB26jdTaKAHbqN1NpGYKMmgB+6jdVf7QiSPH KyRuhAKlxnkA
/wBalBDAEEEHkEU9UA/dRuqN5Y48b3Vc9NxxTI5hJuZcGMPs3q2RnAPPp1/z xRqIn3UbqbTM
s8hRDgqoYkrnrnAxkehoWoxklsryGVHkikP3mQj5vqDkfjjPFMH21OMQS/7W TH+mGp4mYK5a
MlUJDspXAx14zn8KmoaaEV995/zwg/7/AB/+Io33n/PCD/v8f/iKfbEtZWzE kkwxkk9ztFVp
9QaKdohEGIJAxvYnAUk4VTgfMKcYuTshOSWrJt95/wA8IP8Av8f/AIijfef8 8IP+/wAf/iKg
j1L96qzQSRqxAD+XJjcSAAcoMZzV52CIznJCjJ2gk/gByaJRcdxpqWxUuFvJ 7aWHyYF3oVz5
xOMjH92pN95/zwg/7/H/AOIqhcambSS2upp4vs9xGxWITRLj7pU7mYbjgtnB I5A56m5YajDq
CO0OcIcEhlcf99KSM+2cjjjkZwhWhJ8q3NHTklcfvvP+eEH/AH+P/wARRvvP +eEH/f4//EVY
orUgr77z/nhB/wB/j/8AEVFI1wbm082KJV808rIWOdjf7Iq7Ve5/19p/11P/ AKA1AHnmp2F7
d6/qRsoLiXEpD+SjNgZ4zj6fpVVtB1l1Ctp1+ygkgGByAT17ewr0Dwn/AMh3 xB/11j/9nrrK
+gWY+w5IqCbUY69fhR5P1P2vM3JpNvTpuzxH/hHdW/6Bd7/4Dv8A4Uf8I7q3 /QLvf/Ad/wDC
vbqKv+26n8qJ/sqH8zPEf+Ed1b/oF3v/AIDv/hR/wjurf9Au9/8AAd/8K9uo o/tup/Kg/sqH
8zPEf+Ed1b/oF3v/AIDv/hR/wjurf9Au9/8AAd/8K9uoo/tup/Kg/sqH8zPE f+Ed1b/oF3v/
AIDv/hR/wjurf9Au9/8AAd/8K9uoo/tup/Kg/sqH8zPEf+Ed1b/oF3v/AIDv /hR/wjurf9Au
9/8AAd/8K9uoo/tup/Kg/sqH8zPEf+Ed1b/oF3v/AIDv/hR/wjurf9Au9/8A Ad/8K9uoo/tu
p/Kg/sqH8zPEf+Ed1b/oF3v/AIDv/hSjw9q6kEaZfAjkEW78fpXttFH9t1P5 UP8AsuH8zPMr
LUPFVooV9Ou50A4Els+fzxWwNd1HHPh3Uc/9c2/+JrtaK82pVoVHf2SXo2js hSqwVue/qji/
7d1D/oXdR/79t/8AE0f27qH/AELuo/8Aftv/AImu0orO9H+T8WXy1P5vwOL/ ALd1D/oXdR/7
9t/8TR/buof9C7qP/ftv/ia7Sii9H+T8WHLU/m/A4v8At3UP+hd1H/v23/xN H9u6h/0Luo/9
+2/+JrtKKL0f5PxYctT+b8Di/wC3dQ/6F3Uf+/bf/E0f27qH/Qu6j/37b/4m u0oovR/k/Fhy
1P5vwOL/ALd1D/oXdR/79t/8TR/buof9C7qP/ftv/ia7Sii9H+T8WHLU/m/A 4v8At3UP+hd1
H/v23/xNH9u6h/0Luo/9+2/+JrtKKL0f5PxYctT+b8Di/wC3dQ/6F3Uf+/bf /E0f27qH/Qu6
j/37b/4mu0oovR/k/Fhy1P5vwOL/ALd1D/oXdR/79t/8TR/buof9C7qP/ftv /ia7Sii9H+T8
WHLU/m/A4v8At3UP+hd1H/v23/xNH9u6h/0Luo/9+2/+JrtKKL0f5PxYctT+ b8Di/wC3dQ/6
F3Uf+/bf/E0f27qH/Qu6j/37b/4mu0oovR/k/Fhy1P5vwOL/ALd1D/oXdR/7 9t/8TR/buof9
C7qP/ftv/ia7Sii9H+T8WHLU/m/A4v8At3UP+hd1H/v23/xNH9u6h/0Luo/9 +2/+JrtKKL0f
5PxYctT+b8Di/wC3dQ/6F3Uf+/bf/E0f27qH/Qu6j/37b/4mu0oovR/k/Fhy 1P5vwOL/ALd1
D/oXdR/79t/8TR/buof9C7qP/ftv/ia7Sii9H+T8WHLU/m/A4v8At3UP+hd1 H/v23/xNH9u6
h/0Luo/9+2/+JrtKKL0f5PxYctT+b8Di/wC3dQ/6F3Uf+/bf/E0f27qH/Qu6 j/37b/4mu0oo
vR/k/Fhy1P5vwOL/ALd1D/oXdR/79t/8TR/buof9C7qP/ftv/ia7Sii9H+T8 WHLU/m/A4v8A
t3UP+hd1H/v23/xNH9u6h/0Luo/9+2/+JrtKKL0f5PxYctT+b8Di/wC3dQ/6 F3Uf+/bf/E0f
27qH/Qu6j/37b/4mu0oovR/k/Fhy1P5vwOL/ALd1D/oXdR/79t/8TR/buof9 C7qP/ftv/ia7
Sii9H+T8WHLU/m/A4v8At3UP+hd1H/v23/xNH9u6h/0Luo/9+2/+JrtKKL0f 5PxYctT+b8Di
/wC3dQ/6F3Uf+/bf/E0f27qH/Qu6j/37b/4mu0oovR/k/Fhy1P5vwOL/ALd1 D/oXdR/79t/8
TR/buof9C7qP/ftv/ia7Sii9H+T8WHLU/m/A4v8At3UP+hd1H/v23/xNH9u6 h/0Luo/9+2/+
JrtKKL0f5PxYctT+b8Di/wC3dQ/6F3Uf+/bf/E0f27qH/Qu6j/37b/4mu0oo vR/k/Fhy1P5v
wOL/ALd1D/oXdR/79t/8TR/buof9C7qP/ftv/ia7Sii9H+T8WHLU/m/A4v8A t3UP+hd1H/v2
3/xNH9u6h/0Luo/9+2/+JrtKKL0f5PxYctT+b8Di/wC3dQ/6F3Uf+/bf/E0f 27qH/Qu6j/37
b/4mu0oovR/k/Fhy1P5vwOL/ALd1D/oXdR/79t/8TR/buof9C7qP/ftv/ia7 Sii9H+T8WHLU
/m/A4v8At3UP+hd1H/v23/xNH9u6h/0Luo/9+2/+JrtKKL0f5PxYctT+b8Di /wC3dQ/6F3Uf
+/bf/E0f27qH/Qu6j/37b/4mu0oovR/k/Fhy1P5vwOL/ALd1D/oXdR/79t/8 TR/buof9C7qP
/ftv/ia7Sii9H+T8WHLU/m/A4v8At3UP+hd1H/v23/xNH9u6h/0Luo/9+2/+ JrtKKL0f5PxY
ctT+b8Di/wC3dQ/6F3Uf+/bf/E0f27qH/Qu6j/37b/4mu0oovR/k/Fhy1P5v wOL/ALd1D/oX
dR/79t/8TR/buof9C7qP/ftv/ia7Sii9H+T8WHLU/m/A4v8At3UP+hd1H/v2 3/xNH9u6h/0L
uo/9+2/+JrtKKL0f5PxYctT+b8Di/wC3dQ/6F3Uf+/bf/E0f27qH/Qu6j/37 b/4mu0oovR/k
/Fhy1P5vwOK/t7UP+hd1H/v23/xNL/buof8AQu6j/wB+2/8Aia3dXnSAbpWV YwGZmc4AAC8m
uPsPE1jqt7JbRoYycmBpFx56Dgsv4g8eg+oG9OjRmr8v4szk6kXbm/A0v7e1 D/oXdR/79t/8
TTF8S3bqGXQr0qRkEKcEflW/E5eHk52lR/5DQ/1qGxWVtLthCqlvKTlkLADb 6AiuaU6MZW5P
xZoo1Gr834GP/wAJHef9AG+/74P+FH/CR3n/AEAb7/vg/wCFb3lX/pB/34f/ AOLo8q/9IP8A
vw//AMXS56P8n4sfJU/n/Awf+EjvP+gDff8AfB/wo/4SO8/6AN9/3wf8KwvG Wu6hp3iXwnp8
Gq3lvZ363X2qSwtFnlk2RqyFV8uQ9TzhehPpkVF8e6zofhDTJda0+GfXjYS3 l3ZlpY5ViQ4W
RljikCbhjJfYobI4wQpz0v8An3+LDkqfz/gdR/wkd5/0Ab7/AL4P+FH/AAkd 5/0Ab7/vg/4V
wNt8RnsvEXiDUFjvb22vpdIi06zkkbbCbi3Ln5VDleASQisScDBzmtKXxv4j vfEfhi2tNLew
e7nv4biyvt0MdyIo1ZHWRovMCYbIOxSSCpHGaOel/wA+/wAWHJU/n/A6z/hI 7z/oA33/AHwf
8KP+EjvP+gDff98H/CuTsvHuq6Zo3jLWNVhS9sNJ1a4tbfZIEl4dEji2hMbP nyXLFuvymur8
MeIrzXXvorzRbrT3tWQJJJHKIp1YZyhljjYkEEEFRjjk5o56X/Pv8WHJU/n/ AAF/4SO8/wCg
Dff98H/Cj/hI7z/oA33/AHwf8K33ju2bMSxBMDG6JmPT1DD+VJ5V/wCkH/fh /wD4uj2lH+T8
WHJU/n/Awf8AhI7z/oA33/fB/wAKP+EjvP8AoA33/fB/wrbZLpHjMzxIpbGF iZS/B4yWP1/C
paXtKP8AJ+LDkqfz/gc//wAJHef9AG+/74P+FLa6n/alvqkpgeBo4fKZHPII D/41n/De+17U
PCsM2uR+gtp3Y+bNHjhnH8mzlhyR/E0+l/8AMyf9dZP/AGatKkKfJO0bONut yISnzRu7p+R1
W6jdTaK4jqHbqN1NooAduo3Vj6jq5tba52GKOZJ0t4jKruHZlVvuoMk4Y4A6 ke9GganNqltd
POqB4Ll4AURk3BcclWJIPPQ9KrlaVzP2kebk6mxuo3U2uftdcvRftpF1awvq i5ZTG5SO4jGP
nTOSCMjchyVyOSCCXCEp/CVKSjqzot1G6qNrfGa4ltpoTBcxgFoy2eD3B/L8 6uUpRcXZhGSk
roduqvJbK8hlR5IpD95kI+b6g5H44zxTLDULXU7UXFpL5ke4ocqVZWBwVZSA VYHgggEVm6bf
XM2tXFvPPlf3pjRVRk2q4XhlOQRkBlYdTx0NPket+gOS0NIfbU4xBL/tZMf6 Yal33n/PCD/v
8f8A4irFUbjWLC0uhbz3AWTjPykqmem5gML+JFQDko6tk2+8/wCeEH/f4/8A xFG+8/54Qf8A
f4//ABFWKr317b6dZS3l05S3iGZHCFtoz1OAcAdSegGScAE00m3ZDDfef88I P+/x/wDiKN95
/wA8IP8Av8f/AIiotSvTaaJeX0BR2it3mjzyrYUkdOoqzBIJoUfIJIGcdjRZ 2uF1exHvvP8A
nhB/3+P/AMRRvvP+eEH/AH+P/wARViikMr77z/nhB/3+P/xFNsy5kujIqq3m jIVsj7i98CrV
V7b/AF93/wBdR/6AtABc/wCvtP8Arqf/AEBqsVXuf9faf9dT/wCgNT/PH/PG 6/8AAaT/AOJo
AloqLzx/zxuv/AaT/wCJo88f88br/wABpP8A4mnZgS0VF54/543X/gNJ/wDE 0yO8imUtEk7q
GKkrbuRkEgjp1BBB9xRZiLFFReeP+eN1/wCA0n/xNHnj/njdf+A0n/xNFmMl pjhgyyIMsufl
Pf6e/wD9f1pvnj/njdf+A0n/AMTR54/543X/AIDSf/E0K6EEd5PKX8tE2q23 LOQeg7Y96dGp
VPmIySWOPc5/rTfPH/PG6/8AAaT/AOJo88f88br/AMBpP/iabbYDszRSs8O0 7lAIY46Z9vem
C8uJWkgZEyODzuGCByePfpS+eP8Anjdf+A0n/wATR54/543X/gNJ/wDE0JsC RV2oFyTgYyep
qrdJcHf5BKl1Vd64JXB54yOxx1qbzx/zxuv/AAGk/wDiaPPH/PG6/wDAaT/4 mkroDGt5p5Jl
i8tYMwhHQAAFiCMHnsSCOCevNb1Vy0RfebScv13G0fP/AKDT/PH/ADxuv/Aa T/4mqk2wSsFp
/wAeFr/1wj/9AFUdl0+sslpJHDcGORkknhaRMfuewZc9CODx+lXI5VjijjEN 1hEVBm2k6AY/
u+1MmW3udvn2Usu3pvs3bH5rThLllcmUeZWGXVvrMVtu1C8sJ4fNhAW3tHiY N5qc5MjcdeMf
jV2qK21ijq6aYyspyCLFgQf++as+eP8Anjdf+A0n/wATRUlzhCPKjHumNhq5 nhtZm/dsAoWQ
plyCzDZG2CSozyOcnHOS/TbmQFJPtLT/AGqWTMBDZiw7AlSwBCr8oIIHPQ5I U6vnj/njdf8A
gNJ/8TVe3itrRpWhtbpWlcu5NvKSSST3HAyScDjJPrXH7CammnodHtIuNmtS 7XGeNfAcXiUC
7snitdSGFMjqSki9PmA5yB0PfGD2I67zx/zxuv8AwGk/+Jo88f8APG6/8BpP /ia64ylB3RiZ
fhnwzYeFtKWyslLOx3Tzv9+Z/wC839B0A4FaNz/r7T/rqf8A0Bqf54/543X/ AIDSf/E1FM++
a0O2Rf3x4dCh+43YgVLvuwKnhP8A5DviD/rrH/7PXWVyfhP/AJDviD/rrH/7 PXWV3Yj4l/hj
/wCko56Pwv1l+bCvGZPHupQ6w090862zysDbiQhUxnfEP4llTDdSQ+04C5Oz 2avFbvTUm0aD
VLdRJrc0kT+bNOshEgOEkYHrkqowTxsHqK4aybtZno4ah7VSb6frf/I0nm8W QeMJtkl09q5L
Fmnk8gQjoRyQDg9OHMi5yYyQvrFfOiarLY3RubUOJZJCE2jE3mZwYJs4Mmcb Qz/NkAEhgrN9
F1OGk5JtmFSPK0FFFFdJmFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQA
UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABR RRQAUUUUAFFF
FABRRRQAUUUUAFFFFABRRRQAUUUUAc/4jt7e8j+z3PktC24OkrhAQQuMEken bkcViT2dhObY
t/Z5Nscwfv4/3fGOOfp+Q9BXT6lPJE6qjEBi2cEjoF9PrWXJdz44mlH/AG0b /Gu6g5cisc9R
K5dgUrBnIIZhhgeDiNBke2QazLeZ5NCSea2t2tYY9zGWQnAQEE42n0P5+9a0 czzRZc5IKjP1
jQ/zJrHi/wCRDvP+vaf+Tf5/zg+dUV5u50x2LSWPmxrJHp2nujAMrLICGB6E HZz/APXHrTv7
Of8A6Bdj/wB9/wD2H+eKnvZoNEUXbzRx2kjfvY3YDax5LJnqTySvfkjnIddX guNS0WWPTroR
yShWSRZCokTcCyh1yU3rld65K79wyQN0JJjuZ9xoS3ep6dqU2m27XenCQWji 5cCMOu1sALg5
AA5B7Y61V1jwla69cfaL/TI2m8hrZpIb+WFpIWOTGxj2l0J/hORz784q65rG nzLoOjaZO+pL
LO135l0+oqmxIGwjXE0JKkXMfO4YIYBGDFjTsvE2uPqd7Ho+mxyXmpT/AG2Q R+XdLEq2VjlQ
TNCrgmYfOHOccKQ2RXKFzcX4f6QkciJokC+Z9m+db6UOpt12wsjdUZV43KQT nknPM8vg62nj
t1ms5pJLaVpYLhtXuWniZl2sFlzvCkYyobB44rM1HxDrWr+EPEWo28tpp8Fl pr744iZpTK1k
s4eO4RwoAMygEK2dhIPzirdxrGtWniddGNxYyX93FbRrdeRL5KFvtshPkGY5 +WALwwJLZJYA
LRYCxN4MsLj+01k0eBotTybuD7bL5MrHbl/LA2B/lU7wA2cHOTV7TdGm0rzf s8c0nmY3fadU
nuOmcY8zdjr2xnj2rnm8Y628WsXSHThBolk9xdRNbuzXTRz3UThG8zEQb7Nk ZEm3fzux83oP
X/P+fX9e+fmVgMiSynmcvJp9nI56s0mSf/HPp+lN/s5/+gXY/wDff/2H+eK2 ev8An/Pr+vfP
zHX/AD/n1/Xvn5jlC5kJZTROHj06yVh0ZZMH/wBA/wA596m23/8Az7Qf9/z/ APE/54rR6/5/
z6/r3z8x1/z/AJ9f175+Y5UFzNIvwMm3t8f9dz/8T/niue05dr+JlznE0o/9 CrsX+430/wA/
z/X354+x/wBd4n/67y/+zVvTVqM/l+ZjP+JD5nTUVG0wViPKnbHdIHYfmBik 88f88br/AMBp
P/ia5bG5LRUXnj/njdf+A0n/AMTR54/543X/AIDSf/E07MDCs5dL1681G2O+ UxXSzABZIzGV
RVBzwVYMrDHXg+lZbzXmh6xc6ZokVkA5WXZK8j7E2jfJIxfCDJ7DJ/LPXK8a M7JbXCtI25yL
WQFjgDJ+Xk4AH4Cs+50fTbue4mls77fc7fO2LcIH2jC5AwOK1hNJ+8tBU4wU uaS1NiuT1vQx
carPczR3LxyR7oXtwS8EwUBXGOhGPcEEg5BIPT+eP+eN1/4DSf8AxNHnj/nj df8AgNJ/8TRR
qypS5kZ1aUaqszkPCsclprcsOoD7PeSRM0aeWUjnXI3PGD93GBlOq57qVJ7S qswt7hommspp
DE/mRl7RzsbBG4ZXg4JGfc1L54/543X/AIDSf/E0V6rqy52FGlGlHljscV4i 0vUYfEE2oWNm
8zS7MxxpxKAoHX+CQY4YkAjCk4AK9JoElnd6dHe26RfaJVC3LrFscyrwwcEA hgQQQeRWj54/
543X/gNJ/wDE1FGLeKaaaOymSWYhpXW0cGQgAAsdvOAAOewpOblGzK5dblqu NvdC1Zb+5S2H
mw3MrSCQuoVNxyQ4PJxnsDwB0rrfPH/PG6/8BpP/AImjzx/zxuv/AAGk/wDi aycb7k1KUai1
G2Vt9jsLe18xpPJiWPe3VsADJ/Kp6i88f88br/wGk/8AiaPPH/PG6/8AAaT/ AOJp2ZokkrI8
5gtbzw7dDz7Rl0xWH2lvJJS3TOHwQMGEqT8vOz02/c9DsrWztLfbYwQQwud+ IECq2R144PGO
af54/wCeN1/4DSf/ABNRW4t7S3jt7aymhgjG1I47R1VR6ABcCtJzc1ruSopM sSxRzRPFKiyR
upV0YZDA9QR3Fect8JbF/Ev2h592ij5/sZzuZs/cLd0/U9D3J9D88f8APG6/ 8BpP/iaPPH/P
G6/8BpP/AImpjKUU0upQ9EWNFRFCooAVVGAB6Cobb/X3f/XUf+gLT/PH/PG6 /wDAaT/4mmW3
+vu/+uo/9AWoGFz/AK+0/wCup/8AQGq5q2px6ZtkuL6zsbURs8txdnCLhkUA ksoGS+OT6VTu
f9faf9dT/wCgNWrcW80lzFPBNHGyIyEPGXBDFT2I/u1pAlmfpeu2upSq9pq2 m6hasHUzWbBl
WQFBtLB2GfnHHXketV9T1+K31eG0bUbGG0lgMjMZP3mQRxncAoIYEHqcNjHW teK2uPtiTzzx
PsjZFWOIr94qcnLH+7XMeIY5U8UidrK6ngNnGgMVmZhvEjHOccFchsd+neid +VpG+GpxqTtI
sN4jtLVXa21awnHynyHuRuPzDdhmfrt3YBIGcdOc6XhmWObSGeOWJ91zPIRH KsmzfK0gUlSR
uAcZwTXK6LpHiF7OOOMWcEZdj/pDOkqKXb5jFs+pA3DPqO3cWFhDp1sIYdzE ndJI5y8jd2Y+
vA9gAAAAAK2jCMKKV7t6mFVNV5K2ibXrqcrB4l1LSRr954jv9New0q4S0H2W zaBpJHjgdCWe
ZlUEzbPmwBwxZRmpLT4jaTqMVqunQT3t9cyyxJZQT27PmNVd8P5vlPhZIzhH Y/N0+V9uxP4b
s7iLU0aSdWv7uO9Z1YZimjWJY2TjHymCNsMGBIOQQcVTv/B8Wq6X/ZupavqV 5ayuWvI5/JYX
Y+XCsPLxGAFGPK8sg5bO75qkRTs/FmozLFNcad5FmmtzafNdNtKPH5s0MRjA cvu81YEYsoHz
kgbeVy7XxhrmqavFa201pawXNvHdWsn9jXN4JYpp51hd2jkURAxRxMd+OWbO 3BA6h/C9s9hq
dh9ru1tL52lSNSn+iSs7SNLE23cH8xvMBYttYDbtAxUdx4VX+0ftmmatfaR/ okNn5NjHb+X5
cRcoAskT7ceYw4wMY44oA6CiiigAooooAKKKKACiiigAooooAKKKKACiiigA ooooAKydV/4/
bL/rof8A0B61qydV/wCP2y/66H/0B6mew0ZPhP8A5DviD/rrH/7PXUTTw2yB 55Y4kLqgZ2Cg
szBVHPcsQAO5IFcv4T/5DviD/rrH/wCz1c8aWL6h4aeFI55FW7tJpRbswkEU dxHJIU2fNuCK
xG35iR8vOK6cR8S/wx/9JRhR+F+svzZ0FYdlb+GZbCy1e2s9OjtrgRS21wbd Y8+YV8vGQCCS
ygDrkgda5PVbjVV8Q6XJpv8AasEMUtlDBG1tfT/abZnTzJJWL+VGwV5VYTIZ B5e7IJQrl+H4
NUtdC8P2+lReIIRFb2CarHdLdLsmFzajEYm6II/tQYRfJt+9xtrCx0RnKOzP TIrDR724h1iG
0sbieRA8V6kaOzKQMFXAyQQByD0xWhXkcOm6lY+FfD2nQz6zY29rbtDqe631 C4YXipCqqghk
STysCbBjYwcdCSpGpZaXrdzqUX9pz64zXGoRW124uJYFMA05JGYLE+yLNyvL Rn7xZNxBIISe
kUVl+Gpr658K6RPqgkGoSWUL3Qkj2MJSgL5XA2ndnjAxWpQAUUUUAFFFFABR RRQAUUUUAFFF
FABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQBj6t/ rY/+BfyWsmXp
Wtq/+uj/AOBfyWsqXpXfh/gRz1N2aNv/AKpv95f/AEVHVWwsnn8LNZuyxm4h dQ24HAcHBxn0
PT/6+bVv/qW/3l/9FR1mwxWk0+kieLzJ0tGki3KCq4MWTzyGyVwR715lVtTd jpjsPudKnt5D
JZF5pJSHZ5J1JEy42uQTgKRlXC/w4AGM1rXtnZ6laPaX9rb3dtJjfDOqOjYO RlWyDyAfr+tQ
6dZFZlNnbkTndKPKX94c5y3HPPPNc5q2sXmh6D4fOkRpfLNIkbgxMXlgS3kl by1BB8xliwoP
GSAfUQm77Dsjo5PD2hS6ZFpkmjaa+nwtvitWt4jEjc8hDwD8zc4/iPqcyXui 6RqUckd9pdhd
RySid1nhjcPIF2hyDnLbQFyeccfXkbfxrItzrt1dww/2RaxW81kyyJE8sckk sRdnldY9rNEW
QggFGU8k4q3a+PdHvEeWJbpreKzN7cXCxh4oYlMqtllJDENCy4XduyCu5QzC rsDp5NM06bU4
tTksLR9QhQpFdNGhlRTnIDnkD5jxn+I+pzXHh7QlsHsF0bTRZuqo1uLeLy2V WZ1BXpgMzMB2
LE9Sc49t4sjk1mLSrrStQsbuVkVFn8lgQ6TuGzHIwxi3kHrnHGDkUb/4kaDp swjuXeMq0ol3
yRIY1jmeIvtZw0gLROQIw7YAyoJUEuwOuXTNOS3e3WwtBA8C2rRiNArQqGCx kdNgDMAvQbj6
nNvd9P8Avof4/wCc/XPI2njjRr3xK2hxS5ufNkgVvNiO+SMHeuwOZFxsf5mR VO3gncu7pKVw
LW76f99D/H/Ofrk3fT/vof4/5z9c1aKOYLFrd9P++h/j/nP1ybvp/wB9D/H/ ADn65q0UcwWL
LHKkZHP+0P8AH/OfrnkLAgy+JyOR58v/ALNXTVy+l/8AMyf9dZP/AGauim70 Z/L8zGf8SHzO
5tf+PZPx/nXNap4ysNHvbW21HWtMs5LqeSNI5yqmNF8zEj7pFwp8orux94gV 0tr/AMeyfj/O
s2fTHNzZs0sDGC7kuLYvE2Y3ZZATxIN3yu4xg9c44yM1sjUuWt6rW5NzNCsi u6tg7RhWYZwS
ccIT+B9Kg1pLi70mWGx1WLT5ZD5f2lk8zbzggDcuG7dePrVy0ga2t/Ldw7F3 csF2jLMW6ZPr
61z/AIr+1yGKKKO4MSNFITCrYI8wFwSoPGwEEHGQxHfiKtV0oc6V2VCCm+Vl u3e50TTLTTlj
N2bW3jhMxWUGQqoG7Co3XHqa1rWc3NrHMUZCw5VlZcHvwwB6+oGa5a3aDXYl EU9hcT4wVaSI
yEDgMymJyMgA8+vbpXU2onFrGLnb5wGGKvuz752r169BWykpxUl1M7Wdl0Ku s6h/ZljHcZxv
u7a3/wBXv/1syR9Ny/3+ueOuGxtOHp3j6y1BLORtM1K1iukt5BJOIiI47htt u7BJGOJHyoAB
KlSXCjBPQanpsOq2qW87SKiXEFwChAO6KVZVHIPG5AD7Z6dax7fwVptta29u k92Ugt9Pt1Jd
clbOUyxE/L1LHDeo6Y60hle08fWVxYW93NpmpWgvLdLiwjmERa7V3jRQmyRg pLTQr+8Kf6wH
oGK2IPGVtPqltpX9m6kmoyvIklsY0Y25TyWbzGVygGyeN8hiCPl+/hDn6L4B Fv4f0601fU7u
7vLOyht4ZFMYW0ZDE+YsRruAkhiYeYH/ANWAeCwbY03wvbafqi6obu7ur8pM ss85QGYyeSCz
BFVQQtvEo2gDAOQSSaAK/h7xQ194Fg8R6zaSaegslu52YKylPKDtIgRnOzk4 B+bjkeuPc+P/
AOyNZ1E61ZXen26W9mtraXUtqjPLI1yWYSeb5YBWH+Nx9wgDLAN0lr4bs7fw 9PoEsk91pkkT
WywTMB5VuU2CFWQK20LwCxL88saz/wDhC1e8kv59e1WfUj5Xk3ji3D2/liUD aqxBDlbiUHcr
fe4wQCACTTfGdlrRtBpFnd34mRXmaFottqpkePLsZAHG6KUZj352EjIKlsvS PH1rDp3ha11i
XN/qun2krT+bAu6WUBR+6DiQ5fjKxlRnkgBsbkXhoW97BeQatqUdwqIlzIWj kN4quzgSb0O0
bpJOI9mA+BgKoXPt/ANlaW9naWup6lDZ272kklspiK3ElsIxG7loywOIYgQh UHb0BJJAB/H+
np4VtPETWV3FZXbosAupbe1Zwyb9w86VBjgjrk4JUMmGNe08cNfPfSwW0jaa l7Yw2l+sSlJE
uFtSFZTIrhz9oJztAUYOGIKnUHhOCDTtJtrHUb6ym0u0FlBdw+U0hhwgKsHR kOTFGSdoOV4I
BINez8C2FjZw2Vve3y2kf2RmhLRkSS2xh8uVjs3bisEakAhSAcKGO6gCNvH1 ktrHcf2ZqRS6
SOTTwBFm+jeWKJXj/efKN08RxJsOH6cMBI/je1WeGxXTb5tXllki/szfAsyl ESRvmaURthJY
2wrscP0+V9pF4FsI1to3vb6WGy8pbGN2jAtIo5YpREpCAspMEQJcs2E4YEkm TVPBllq4v4bi
8u/seo3AnvbQLE0c+I4owpLRllAEKkFGVgSSCDtwAdJRRRQAVgW3+vu/+uo/ 9AWt+sC2/wBf
d/8AXUf+gLWdQaC5/wBfaf8AXU/+gNW/WBc/6+0/66n/ANAat+imDCoL2Zra xuJ0ALRxM4B6
ZAzU9RXUH2mzmg3bfNjZN2M4yMZrQRzz+JbEXdzaweI9Fn1GJXBskkBl3Rhi y7BKSCMHPGeO
elbs2oWVtG0k95bxIpwWklCgHJHUn1BH4Gq08N7dJPaPdWwDRYYiA5w2R/z0 9j1GP1qt4uhm
n8M3McEckkheIhY4y7cSKThR1wATUt2VzSlFTnGL6tHKap4oLLIV8Q+WBfbV WMxgCMS8EEDJ
G0c84I65BNdD4b1r7fqd7aNqaXeyOOSIHYGxlgxwoGR936ZHrXLXWnX+oapD JZae8aIF3C7t
zbLu85PmDEYJJ+bHUDIGcAHstC0u/s72+ur4Wym4WNVS3csBt35Jyo/vfpXL CM1UWrsdmJjT
hGy/S5HqOt/ZNcnSW4+zabpWnnUNQfZuLq29YwOCSoEUzMAA2RHgkFhWHc+P /wCyNZ1E61ZX
en26W9mtraXUtqjPLI1yWYSeb5YBWH+Nx9wgDLAN0Gp6AuoapJMyxyWd/ZPp +pQMzKZYvmMZ
UjkFS8q4G3ImJJyig0/+ELV7yS/n17VZ9SPleTeOLcPb+WJQNqrEEOVuJQdy t97jBAI7Dzyn
pHiuTxL4qthppu20hLJJ2aDyDH5jPcRsszElmAaDCmHIJySWUqasaL8QtG1y 6htLYSfaJbgQ
bFmgmCbopZFZnhkdMEQSDGdwIGQAQToJ4VsSl+l3Nd3o1CyWxu/tEuTKgaVi cjBUkzvwuABt
Ch
| Re: VE crashes when loading Table [message #607809 is a reply to message #91763] |
hello,
But when I use:
thx
flik
TableItem tabitem;
// END of TabDecks
// END of TabCards
F1.setText("1");
F2.setText("2");
F4.setText("4");
F5.setText("5");
display.dispose ();
name="ve.JPG"
filename="ve.JPG"
Ch
Current Time: Tue Nov 11 06:28:18 EST 2025
Powered by FUDForum. Page generated in 0.04273 seconds
