Eclipse in a multiuser enviroment [message #91580] |
Fri, 11 July 2003 02:42  |
Hi!
We're are about to install Eclipse in a multiuser enviroment (Linux).
Over time I've seen quite a few posts about Eclipse unawareness of this.
Anyone with experience of this that would like to share it?
What problems are there? What should we think of? etc
Jimisola
Re: Eclipse in a multiuser enviroment [message #91979 is a reply to message #91580] |
Fri, 11 July 2003 13:20  |
Originally posted by: muelleimer.usenet.katzien.de
Hallo!
In the other post you aready got the a nice startscript, which sould
be used to start eclipse. If you want to get one which forwards more
option, have a look at the debian packages...
What I encountered with the debian packages was basicly this:
* you can't get a plugin dir in $HOME (ok, there is a depricated
option '-plugins', but, when you look in the source code, that is a
*really* big hack now).
* The updatemanager has to be told, that the root site is not
updateable (I think in the end of the wizard it will fail because
the dir is not writeable by the user, but anyway...)
* It hasn't got any possibility (out of the box: with a script
everything is possible) to configure, for example, the workspace
location. Without that menu entries are a pain.
I have patches for the first two, the third can be adressed by the
startscript.
On the other hand I haven't seen it running in a 'more than one user'
system or even a 'more than one user a time' system...
Jan
FUDForum. Page generated in 0.07381 seconds
