Home » Archived » Higgins » Problem with RPPS-AXIS data base
Problem with RPPS-AXIS data base [message #8246] Wed, 18 February 2009 10:05 Go to next message
I follow the instruction but still have error :
ERROR [TP-Processor1] (CardContext.java:117) -
com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Table
'icard.useraccount' doesn't exist
ERROR [TP-Processor1] (RppsService.java:665) -
org.eclipse.higgins.icard.CardException:
ERROR [TP-Processor1] (RppsService.java:648) -
org.eclipse.higgins.rpps.core.RppsException:
ERROR [TP-Processor1] (RppsService.java:685) -
http://wiki.eclipse.org/Deploying_the_I-Card_Service
following this table I made schema icard corresponding to
First_Schema_Name, and import table from sql file.
What's wrong ?
Re: Problem with RPPS-AXIS data base [message #8279 is a reply to message #8246] Thu, 19 February 2009 04:19 Go to previous message
Seems I miss something.
IS there only two MySQL schema ?
One to set up from sql file from Higgins server, the other is
automatically set up by rpps-axis. I have both schema, maybe the one from
Higgins is not uptodate (but I think it is). Or maybe I have to set up an
other table but I didn't read about it.
PS :
There is some errors with eclipse componment. It's needed to had in
rpps-axis/WEB-INF/lib/ the following files :
org.eclipse.runtime.IExtensionRegistry
org.eclipse.core.runtime
org.eclipse.equinox.common
org.eclipse.osgi
Don't know if needed to work.
Re: Problem with RPPS-AXIS data base [message #562957 is a reply to message #8246] Thu, 19 February 2009 04:19 Go to previous message
PS :
org.eclipse.osgi
Previous Topic:Problem with RPPS-AXIS data base
Next Topic:Firefox extension not working and account problem
Current Time: Mon Sep 01 01:05:18 EDT 2025
Powered by FUDForum. Page generated in 0.02964 seconds
