Home » Eclipse Projects » Remote Application Platform (RAP) » Using RAP with EJB3 on JBoss 4.2 (Version 2)
Using RAP with EJB3 on JBoss 4.2 (Version 2) [message #91462] Tue, 03 June 2008 09:01 Go to next message
now from scratch...
1. HelloWorld EJB is Running on Jboss 4.2
2. I implemented a Simple EJB Client on the Rap Side using the Example
From the RAP FAQ ->
http://wiki.eclipse.org/RapFaq#How_do_I_make_remote_calls_to _EJB.27s_deployed_on_Jboss_4.x_AS
3. I included the following jars to my RAP application classpath:
- jboss-remoting.jar
- jboss-serialization.jar
- jbosssx.jar
- jboss-transaction.jar
- jboss.jar
- jbossall-client.jar
- jboss-ejb3-client
- jnp-client.jar
4. Here is my Ejb Clientcode:
package hello;
import java.util.Hashtable;
import java.util.Properties;
import javax.naming.Context;
import javax.naming.InitialContext;
import javax.naming.NamingException;
public class HelloWorldClient {
public String sayHello() {
Hashtable<String, String> props = new Hashtable<String, String>();
//Properties props = new Properties();
props.put("java.naming.factory.initial",
"org.jnp.interfaces.NamingContextFactory");
props.put("java.naming.provider.url", "jnp://localhost:1099");
props.put(Context.URL_PKG_PREFIXES,
"org.jboss.naming:org.jnp.interfaces");
InitialContext context;
try{
context = new InitialContext(props);
}catch (NamingException e){
throw new RuntimeException("fail to get initial context",e);
try{
//HelloWorld hello =
(HelloWorld)context.lookup("HelloWorld/HelloWorldImpl/remote ");
HelloWorld hello =
(HelloWorld)context.lookup("RapEjbServer/HelloWorldImpl/remote ");
//System.out.println(hello.hello("World"));
return "Hello RAP EJB !!!";
throw new RuntimeException("fail while ejb lookup",e);
5. Here ist the Exception i get:
-> Caused by: javax.naming.CommunicationException [Root exception is
java.lang.ClassNotFoundException: hello.HelloWorld (no security manager: RMI
class loader disabled)]
6. the complete stack trace:
osgi> 03.06.2008 15:00:16 org.mortbay.http.HttpServer doStart
INFO: Version Jetty/5.1.x
03.06.2008 15:00:16 org.mortbay.util.Container start
INFO: Started
org.eclipse.equinox.http.jetty.internal.Servlet25Handler@2c35e
INFO: Started HttpContext[/,/]
03.06.2008 15:00:17 org.mortbay.http.SocketListener start
INFO: Started SocketListener on 0.0.0.0:1727
03.06.2008 15:00:17 org.mortbay.util.Container start
INFO: Started org.mortbay.http.HttpServer@141b571
java.lang.RuntimeException: fail while ejb lookup
at hello.HelloWorldClient.sayHello(HelloWorldClient.java:33)
rapclient2.ApplicationWorkbenchWindowAdvisor.preWindowOpen(A pplicationWorkbenchWindowAdvisor.java:33)
org.eclipse.ui.internal.WorkbenchWindow.fireWindowOpening(Wo rkbenchWindow.java:1158)
org.eclipse.ui.internal.WorkbenchWindow.<init>(WorkbenchWindow.java:355)
org.eclipse.ui.internal.tweaklets.Workbench3xImplementation. createWorkbenchWindow(Workbench3xImplementation.java:29)
org.eclipse.ui.internal.Workbench.newWorkbenchWindow(Workben ch.java:1670)
at org.eclipse.ui.internal.Workbench.access$11(Workbench.java:1 668)
org.eclipse.ui.internal.Workbench$16.runWithException(Workbe nch.java:954)
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:32)
org.eclipse.rwt.internal.lifecycle.UICallBackManager.addSync (UICallBackManager.java:134)
at org.eclipse.swt.widgets.Display$2.run(Display.java:645)
org.eclipse.rwt.internal.lifecycle.UICallBackServiceHandler. runNonUIThreadWithFakeContext(UICallBackServiceHandler.java: 423)
org.eclipse.rwt.lifecycle.UICallBack.runNonUIThreadWithFakeC ontext(UICallBack.java:44)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:643)
org.eclipse.ui.internal.StartupThreading.runWithWorkbenchExc eptions(StartupThreading.java:55)
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:952)
org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Work bench.java:1793)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1729)
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:188)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:790)
org.eclipse.ui.internal.Workbench$25.runWithException(Workbe nch.java:1335)
org.eclipse.ui.internal.StartupThreading.runWithoutException s(StartupThreading.java:110)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1330)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2314)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:22 05)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:425)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:408)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:157)
at rapclient2.Application.createUI(Application.java:17)
org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:92)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:230)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:116)
at java.lang.Thread.run(Unknown Source)
RMI class loader disabled)]
at org.jnp.interfaces.NamingContext.lookup(NamingContext.java:7 86)
at org.jnp.interfaces.NamingContext.lookup(NamingContext.java:6 27)
at javax.naming.InitialContext.lookup(Unknown Source)
at hello.HelloWorldClient.sayHello(HelloWorldClient.java:29)
... 39 more
Caused by: java.lang.ClassNotFoundException: hello.HelloWorld (no security
manager: RMI class loader disabled)
at sun.rmi.server.LoaderHandler.loadProxyClass(Unknown Source)
at java.rmi.server.RMIClassLoader$2.loadProxyClass(Unknown Source)
at java.rmi.server.RMIClassLoader.loadProxyClass(Unknown Source)
at sun.rmi.server.MarshalInputStream.resolveProxyClass(Unknown Source)
at java.io.ObjectInputStream.readProxyDesc(Unknown Source)
at java.io.ObjectInputStream.readClassDesc(Unknown Source)
at java.io.ObjectInputStream.readOrdinaryObject(Unknown Source)
at java.io.ObjectInputStream.readObject0(Unknown Source)
at java.io.ObjectInputStream.readObject(Unknown Source)
at java.rmi.MarshalledObject.get(Unknown Source)
at org.jnp.interfaces.MarshalledValuePair.get(MarshalledValuePa ir.java:72)
at org.jnp.interfaces.NamingContext.lookup(NamingContext.java:7 10)
... 42 more
!SESSION 2008-06-03 15:00:15.157
eclipse.buildId=unknown
java.version=1.6.0_05
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -dev
file:C:/JBOSS/rap_workspace/.metadata/.plugins/org.eclipse.p de.core/RapClient2/dev.properties
-os win32 -ws win32 -arch x86 -console -consolelog
!ENTRY org.eclipse.rap.ui 4 0 2008-06-03 15:00:22.939
!MESSAGE Unhandled event loop exception
!STACK 0
... 39 more
... 42 more
Re: Using RAP with EJB3 on JBoss 4.2 (Version 2) [message #91728 is a reply to message #91462] Wed, 04 June 2008 05:46 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
do you have any java.security.policy settings in place?
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Tobias Bergtholdt [mailto:tobias.bergtholdt@gmail.com]
Bereitgestellt: Dienstag, 3. Juni 2008 15:02
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Using RAP with EJB3 on JBoss 4.2 (Version 2)
Betreff: Using RAP with EJB3 on JBoss 4.2 (Version 2)
now from scratch...
1. HelloWorld EJB is Running on Jboss 4.2 2. I implemented a Simple EJB
Client on the Rap Side using the Example From the RAP FAQ ->
- jbosssx.jar
- jboss.jar
- jboss-ejb3-client
- jnp-client.jar
package hello;
String>();
try{
context",e);
try{
HelloWorld hello =
INFO: Started
w.java:1158)
ading.java:32)
anager.java:134)
adWithFakeContext(UICallBackServiceHandler.java:423)
lBack.java:44)
:952)
793)
9)
..java:790)
5)
ading.java:32)
anager.java:134)
lBack.java:44)
eading.java:110)
288)
08)
Manager.java:92)
va:230)
at java.lang.Thread.run(Unknown Source) Caused by:
... 39 more
security
Source)
Source)
... 42 more
!ENTRY org.eclipse.rap.ui 4 0 2008-06-03 15:00:22.939 !MESSAGE Unhandled
event loop exception !STACK 0
w.java:1158)
ading.java:32)
anager.java:134)
lBack.java:44)
:952)
793)
9)
..java:790)
5)
ading.java:32)
anager.java:134)
lBack.java:44)
eading.java:110)
288)
08)
Manager.java:92)
va:230)
... 39 more
security
Source)
Source)
... 42 more
Re: Using RAP with EJB3 on JBoss 4.2 (Version 2) [message #91785 is a reply to message #91728] Wed, 04 June 2008 07:07 Go to previous messageGo to next message
Originally posted by: e.komissarov.telecom-m.com
Use
context = context.lookup("HelloWorld");
context = context.lookup("HelloWorldImpl);
HelloWorld hello = (HelloWorld) context.lookup("remote");
or add to project jndi.properties file
Frank Appel пишет:
> Ciao
> Frank
> now from scratch...
> - jbosssx.jar
> - jboss.jar
> - jboss-ejb3-client
> - jnp-client.jar
> package hello;
> String>();
> try{
> context",e);
> try{
> HelloWorld hello =
> INFO: Started
> at
> at
> w.java:1158)
> at
> at
> at
> at
> at
> at
> ading.java:32)
> at
> anager.java:134)
> at
> at
> lBack.java:44)
> at
> at
> :952)
> at
> 793)
> at
> 9)
> at
> at
> .java:790)
> at
> 5)
> at
> ading.java:32)
> at
> anager.java:134)
> at
> at
> lBack.java:44)
> at
> eading.java:110)
> at
> at
> 288)
> at
> 08)
> at
> at
> Manager.java:92)
> at
> va:230)
> at
> at
> at
> ... 39 more
> security
> Source)
> Source)
> at
> at
> ... 42 more
> at
> at
> w.java:1158)
> at
> at
> at
> at
> at
> at
> ading.java:32)
> at
> anager.java:134)
> at
> at
> lBack.java:44)
> at
> at
> :952)
> at
> 793)
> at
> 9)
> at
> at
> .java:790)
> at
> 5)
> at
> ading.java:32)
> at
> anager.java:134)
> at
> at
> lBack.java:44)
> at
> eading.java:110)
> at
> at
> 288)
> at
> 08)
> at
> at
> Manager.java:92)
> at
> va:230)
> at
> at
> at
> ... 39 more
> security
> Source)
> Source)
> at
> at
> ... 42 more
Re: Using RAP with EJB3 on JBoss 4.2 (Version 2) [message #91853 is a reply to message #91728] Wed, 04 June 2008 10:27 Go to previous messageGo to next message
I use JBoss in default configuration as it is. -> no security.
But what is with the Jetty security settings? Pherhaps the Problem is that
the Jetty Server requires a security authorization?
I tested the EJB with a Simple Java EJB Client with the same settings as
the RAP Ejb Client. The Java Ejb Client is fine.
Here the Code from the JAva Ejb Client...
package hello;
public static void main(String[] args) throws Exception {
InitialContext context = new InitialContext(props);
HelloWorld hello =
System.out.println(hello.hello("JavaClient"));
@Eugene Komissarov your suggestion is not working
-> context = context.lookup("HelloWorld"); because itŽs not possible to
convert the Object to an Initial Context !
Re: Using RAP with EJB3 on JBoss 4.2 (Version 2) [message #91899 is a reply to message #91853] Thu, 05 June 2008 01:12 Go to previous messageGo to next message
hm -it's been since I've worked with EJBs. Did you read
loyed_on_Jboss_4.x_AS?
Seems to me that the Context.URL_PKG_PREFIXES parameter is not set in
your example - don't know if that makes any differences.
Ciao
Frank
Bereitgestellt: Mittwoch, 4. Juni 2008 16:27
Betreff: Re: Using RAP with EJB3 on JBoss 4.2 (Version 2)
that the Jetty Server requires a security authorization?
package hello;
HelloWorld hello =
Re: Using RAP with EJB3 on JBoss 4.2 (Version 2) [message #91958 is a reply to message #91899] Thu, 05 June 2008 11:24 Go to previous message
yes I read the FAQ. And I think that iŽm doing exactly the same. except
that IŽm using EJB 3 and not EJB 2.
I have added the props.put(Context.URL_PKG_PREFIXES,
"org.jboss.naming:org.jnp.interfaces"); statement
but I have the same resault as before...
So have anyvody any idea how to fix that problem ????
Previous Topic:Right-menu in Text
Next Topic:Use TableViewer with Virtual and DeferredContentProvider problem
Current Time: Fri Nov 14 14:51:37 EST 2025
Powered by FUDForum. Page generated in 0.04346 seconds
