Home » Language IDEs » ServerTools (WTP) » null pointer exception in web service wizard
null pointer exception in web service wizard [message #91172] Fri, 08 April 2005 19:35 Go to next message
Originally posted by: lompafb.lompa.it
hallo,
i'm trying to run the web service example in the "bottom up web service
tutorial". Fnally i configured the server correctly, but when i try to
deploy the service i get this error: "IWAB0019E Error in getting method
from Java bean."
the top of stack trace is:
"java.lang.NullPointerException at
org.eclipse.jst.ws.internal.axis.creation.ui.command.JavaToW SDLMethodCommand.execute(JavaToWSDLMethodCommand.java:95) "
Am i using a nightly build of axis or eclipse itself?
thanx in advance
Re: null pointer exception in web service wizard [message #93498 is a reply to message #91172] Wed, 20 April 2005 15:00 Go to previous message
Michele,
the error means the Web service wizard could not find and "reflect" the class of your service bean (yup - the error
message itself could be more useful), which most often results when Eclipse has failed to compile the .java file. Could
you double-check a few things inside your dynamic Web project?
1. Make sure Converter.java is in the right folder: <your-project>/JavaSource/wtp/.
2. Make sure there are no compilation errors in the problems view.
3. Make sure Converter.class exists in <your-project>//WebContent/WEB-INF/classes/wtp/.
Cheers - CB.
Michele Lombardi wrote:
> hallo,
> from Java bean."
> thanx in advance
Previous Topic:WTP plugin - creating/testingweb service
Next Topic:authenticating tokens and all that jazz
Current Time: Fri Nov 07 05:26:35 EST 2025
Powered by FUDForum. Page generated in 0.02963 seconds
