Home » Language IDEs » C / C++ IDE (CDT) » 3.0M6 Debug - Variables view
3.0M6 Debug - Variables view [message #91150] Thu, 08 January 2004 12:27 Go to next message
Has anyone noted that the variables values seem backwards when debugging
C++ programs? An unsigned long with a binary value of 1 shows up as
0x1000000
Re: 3.0M6 Debug - Variables view [message #91183 is a reply to message #91150] Thu, 08 January 2004 17:08 Go to previous messageGo to next message
Originally posted by: mikhailk.qnx.com
Seems to work fine. Is it an unsigned long or a typedef?
"David Truckenmiller" <dtrucken@stellent.com> wrote in message
news:btk3u8$360$1@eclipse.org...
> 0x1000000
Re: 3.0M6 Debug - Variables view [message #91198 is a reply to message #91183] Thu, 08 January 2004 17:41 Go to previous messageGo to next message
Well, it is a complicated thing, but when I press cast to the value that
pops up is long unsigned int
> > 0x1000000
Re: 3.0M6 Debug - Variables view [message #91212 is a reply to message #91198] Thu, 08 January 2004 17:47 Go to previous messageGo to next message
What is your working environment?
Does it happen with this particular variable or you see the same problem
with all unsigned long types?
news:btkmb3$qa3$1@eclipse.org...
debugging
> > > 0x1000000
Re: 3.0M6 Debug - Variables view [message #91319 is a reply to message #91212] Fri, 09 January 2004 16:32 Go to previous message
I think it had to do with an old Structure packing bug in gcc 2.95.3. I
turned off packing, and left the compiler just do its thing, and it looks
better now. I still can't properly "watch" variables, but that is
probably a different problem.
> debugging
> > > > 0x1000000
Previous Topic:Expression window
Next Topic:Managed make problem
Current Time: Mon Jul 14 09:15:50 EDT 2025
Powered by FUDForum. Page generated in 0.27525 seconds
