Home » Language IDEs » C / C++ IDE (CDT) » 2.0M6 install problem
2.0M6 install problem [message #91105] Thu, 08 January 2004 05:34 Go to next message
Originally posted by: kannenbe.informatik.uni-kl.de
Hi There!
I have a problem installing the latest 2.0M6 Version of CDT:
After installing Eclipse 3.0M6, I followed the instructions on the CDT
Homepage to install 2.0M6 (using Help->Software Updates->Find and Install).
I did this as root (I'm using the linux/gtk version of eclipse and cdt),
because it failed when doing as a normal user (could not write some files
due to permission problems). It seemed to install without any problems.
But when I restartet eclipse as a user, the CDT plugin did not appear. It
looked like I never installed anything.
I remembered a similar problem with 2.0M5, but the incorrect version number
in the fragment.xml file, which caused the problem with 2.0M5, is correct.
Any ideas how to fix this?
tia..
Ciao, Branko.
Re: 2.0M6 install problem [message #91120 is a reply to message #91105] Thu, 08 January 2004 11:10 Go to previous messageGo to next message
Originally posted by: dschaefe.ca.ibm.com
Cool, I haven't even announced the availability yet.
I generally install Eclipse and the CDT with my user account. That's
usually because as a developer, I do this quite often. Installing as root
could be problematic as there might be some files in the install that get
updated by the user on startup (e.g. the .config file?). Try it in an
eclipse install in your home directory and see if you get the same thing.
BTW, linux/gtk is my main environment as well and I did a quick sanity run
before releasing the build. But that's been proven faulty before...
Doug.
On Thu, 08 Jan 2004 11:34:00 +0100, Branko Kannenberg wrote:
> Hi There!
> tia..
> Ciao, Branko.
Re: 2.0M6 install problem [message #92766 is a reply to message #91120] Mon, 26 January 2004 23:14 Go to previous message
Originally posted by: werbung.k_news_uhnle.net
Hi!
Is there no way to install as root so multiple users can share the
installation?
Jochen
> Doug.
>> Hi There!
>> Install). I did this as root (I'm using the linux/gtk version of eclipse
>> and cdt), because it failed when doing as a normal user (could not write
>> some files due to permission problems). It seemed to install without any
>> problems.
>> number in the fragment.xml file, which caused the problem with 2.0M5, is
>> correct.
>> tia..
>> Ciao, Branko.
Remove the "_news_" in the address to reply.
Previous Topic:walk through installation of CDT WinXP
Next Topic:C/C++ plug-in
Current Time: Wed Nov 05 21:55:48 EST 2025
Powered by FUDForum. Page generated in 0.04183 seconds
