Home » Modeling » GMF (Graphical Modeling Framework) » compartment problem
compartment problem [message #91024] Tue, 09 January 2007 16:20 Go to next message
Originally posted by: klaus.grebe.platin.com
I have a model with 2 classes
class x
float a, b, c, d;
class y
x x1;
x x2;
I implemented 'class x' as a compartement (ok 2 of them) ans this works
more or less...
The problem is, that I cannot see 'x1' and 'x2' when I generate a figure
of 'class y' in the editor.
All I get is the name, but not the fields for a, b, c, d
Instead I have to stars in box that appear on top of the figure of 'y'
when the mouse pause a little
time over the figure (like a tooltip). Then I can click (only once on
each) on the stars and I get the
missing fields of 'x'.
How can I get these fields just in time with the generation of the
figure of y ??
I use GMF Version: 1.0.2.v2006
And yes, I am absolutely new to it...
Kind regards
Klaus
Re: compartment problem [message #93455 is a reply to message #91024] Tue, 16 January 2007 16:50 Go to previous message
I upgraded to Version 2.0M4. But as expected, nothing changed...
Klaus Grebe schrieb:
> Hello,
> class x
> float a, b, c, d;
> class y
> x x1;
> x x2;
> more or less...
> figure of y ??
> Kind regards
> Klaus
Previous Topic:Templates in org.eclipse.gmf.graphdef.codegen (2.0 M4)
Next Topic:Dynamically adding SpecializationTypes
Current Time: Sat Nov 08 08:20:33 EST 2025
Powered by FUDForum. Page generated in 0.03137 seconds
