| pointing a class to a project [message #90989] |
Fri, 29 August 2003 20:54  |
Originally posted by: callendor13.yahoo.com
I have just completed a program for my CS class and I have a seperate
class that is being used by the program. When it compiles to says I have
errors refering to the class file. I looked at the Workspace doc and
cannot find anything on how to point, or add a .class file to the project
so that when it compiles and runs it works fine. I can compile and run it
fine under the terminal.
My system, if it makes a deference, is OS X.
Thanks for any help.
| Re: pointing a class to a project [message #94076 is a reply to message #91193] |
Wed, 10 September 2003 12:53  |
Originally posted by: daniel.megert.gmx.net
Randy Faust wrote:
>An easy way to consider is to make a .jar file of the .class files and add
>it to the Java Build Path of your project. Select the project then
>File->properties. Choose "Java Build Path", libraries tab, then add external
>jar.
Even easier is to put the file into a class file folder and add that
folder to the build path.
HTH
Dani
>Randy
>"DJ Adams" <callendor13@yahoo.com> wrote in message
>news:biosk6$tq8$1@eclipse.org...
FUDForum. Page generated in 0.02728 seconds
