Home » Newcomers » Newcomers » VE Installation
| VE Installation [message #90917] |
Sun, 31 July 2005 06:30  |
Originally posted by: HGSandhagen.web.de
I tried to install VE 1.1 on Eclipse 3.1. I downloaded the
VE-runtime-1.1.zip and extract it into the eclipse directory. After next
start of eclipse nothing has changed. In an other newsgroup I find the
hint to cleanup the directory "configuration" (delete all except
config.ini). With the next start I could create a "visual class" and in
the editor a tab named "Visual Editor" is displayed, but empty.
Please help.
Hans-Gerd
| Re: VE Installation / UML Installation [message #91066 is a reply to message #91036] |
Sun, 31 July 2005 18:25   |
Originally posted by: weconsul.ptd.net
Holger Löttgen wrote:
> So if you are lucky with your solution, perhaps you can give me a hint
> so solve my prob.
> I installed 3.1 SDK and it works fine.
> Now I want to install the UML environment to play around with...
> I downloaded the UML2 SDK and extracted all the file over my current
> eclipse folder.
> Now I can see the UML files in separate directories in the plugin folder...
> But I do not see the plugin when I look at "Help -> Software Updates ->
> Manage Configuration".
> I also cannot use any UML function. I tried to use right mouse click on
> a package to select the wizard...
> but I cannot find any UML-entry ....
> Please can anybody help me with this.
> Probably I have a general understanding problem with plugins and
> installing new functions.
> Please help
> Holger
> -------- Original-Nachricht --------
>> IchBin schrieb:
>>> Hans-Gerd Sandhagen wrote:
>>>> Hi,
>>>> next start of eclipse nothing has changed. In an other newsgroup I
>>>> find the hint to cleanup the directory "configuration" (delete all
>>>> except config.ini). With the next start I could create a "visual
>>>> class" and in the editor a tab named "Visual Editor" is displayed,
>>>> but empty.
>>>> Please help.
>>>> Hans-Gerd
>>> Hopefully you also installed the other required plugins that VE
>>> requires.. They are mentioned on the download page and in numerous
>>> references in the eclipse.tools.ve newsgroup.
>> Thank you for fast response.
>> It works now.
>> Yes, I also installed the required plugins, but it works first time
>> after deleting and new install all. (all plugins installed by hand,
>> without update manager).
>> Hans-Gerd
You also need the EMF runtime for UML2.
After all are install, start Eclipse with -clean option.
Sorry I have not played with UML2. There is a
"Getting Started with UML2" article at
http://dev.eclipse.org/viewcvs/indextools.cgi/%7Echeckout%7E /uml2-home/docs/articles/Getting_Started_with_UML2/article.h tml
You may want to watch the eclipse.tools.uml2 newsgroup.
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA http://weconsultants.servebeer.com
____________________________________________________________ ______________
' If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
| Re: VE Installation / UML Installation [message #91100 is a reply to message #91066] |
Sun, 31 July 2005 19:27   |
>> so solve my prob.
>> eclipse folder.
>> folder...
>> -> Manage Configuration".
>> on a package to select the wizard...
>> Please help
>> Holger
>>>>> Hi,
>>>>> but empty.
>>>>> Please help.
>>>>> Hans-Gerd
>>> It works now.
>>> Hans-Gerd
You may also want to download the UML2 examples.
| Re: VE Installation / UML Installation [message #91146 is a reply to message #91132] |
Mon, 01 August 2005 03:57   |
>>>> hint so solve my prob.
>>>> eclipse folder.
>>>> folder...
>>>> Please help
>>>> Holger
>>>>>>> Hi,
>>>>>>> After next start of eclipse nothing has changed. In an other
>>>>>>> newsgroup I find the hint to cleanup the directory
>>>>>>> "configuration" (delete all except config.ini). With the next
>>>>>>> start I could create a "visual class" and in the editor a tab
>>>>>>> Please help.
>>>>>>> Hans-Gerd
>>>>> It works now.
>>>>> Hans-Gerd
> Thanks a lot...
> I started eclipse with the -clean option an now all my installed plugins
> show up...
> Is there any list of all eclipse starting options available ?
> Holger
Sure, just do a search in the IDE help menu.
( Help menu \ Help Contents ) or ( Help menu \ Search )
Then do a search for "Eclipse runtime options".
Three items will be returned that will be of interest.
| Re: VE Installation / UML Installation [message #91176 is a reply to message #91146] |
Mon, 01 August 2005 04:29  |
>>>>> current eclipse folder.
>>>>> folder...
>>>>> Updates -> Manage Configuration".
>>>>> click on a package to select the wizard...
>>>>> Please help
>>>>> Holger
>>>>>>>> Hi,
>>>>>>>> Please help.
>>>>>>>> Hans-Gerd
>>>>>>> numerous references in the eclipse.tools.ve newsgroup.
>>>>>> It works now.
>>>>>> time after deleting and new install all. (all plugins installed by
>>>>>> hand, without update manager).
>>>>>> Hans-Gerd
>> Thanks a lot...
>> plugins show up...
>> Holger
Again thanks a lot...
Your answer is exactly what I needed...
Holger
Current Time: Sun Nov 16 02:35:01 EST 2025
Powered by FUDForum. Page generated in 0.30819 seconds
