Home » Archived » M2M (model-to-model transformation) » [QVTO] Input model parameter '...' is read-only!
[QVTO] Input model parameter '...' is read-only! [message #90911] |
Wed, 01 October 2008 10:46  |
Originally posted by: mahdider.students.uni-mainz.de
Hello everyone,
this is my first shot on QVTO and I am just trying to get a very basic
transformation working. The code is as follows and takes in an ecore
file with a single package, containing a single class and should write a
second ecore file, basically a copy of it but with changed names.
First here is the code:
-- The metametamodel is ecore.
modeltype ECORE uses "http://www.eclipse.org/emf/2002/Ecore";
-- Transform nice animals to wild animals.
transformation NewTransformation(in nice : ECORE, out ECORE);
main() {
nice.rootObjects()[ECORE::EPackage]->map package2Package();
Setup the package so that the postfix is wild.
Also add the nsPrefix and nsURI accordingly.
mapping ECORE::EPackage::package2Package() : ECORE::EPackage {
name := self.name.substringBefore('nice') + 'wild';
nsPrefix := self.name.substringBefore('nice') + 'wild';
nsURI := self.nsURI;
-- Is it legal to perform the next two lines like this?
eSubpackages := self.eSubpackages;
eClassifiers := self.eClassifiers;
The main issue arrises in the following line:
Eclipse compains:
org.eclipse.m2m.internal.qvt.oml.evaluator.QvtRuntimeExcepti on: Input
model parameter 'nice : NewTransformation::ECORE' is read-only!
at EPackage.package2Package(NewTransformation.qvto:21)
at NewTransformation.main(NewTransformation.qvto:8)
at NewTransformation.<init>(NewTransformation.qvto:7)
Is my assignment of a collection / OrderedSet like this not a valid
transformation?
Kind Regards,
Mahdi
Re: [QVTO] Input model parameter '...' is read-only! [message #90970 is a reply to message #90928] |
Wed, 01 October 2008 12:22   |
Hi Mahdi,
In your original QVT code you tried to assign objects having its contain=
er =
object in the [in] model
which is by definition read-only.
Actually, by this step you have attempted to modify the input model,
as you would change the container of the child objects by the assignment=
to containment reference.
Finally, you would also modify the parent, by cutting off his children.
Anyway, I can see I got the point.
To avoid copying manually by creating mappings that assign property by =
property,
you can use deepClone() on you model elements and provide only mappings =
that
would do your custom changes.
See example bellow, base on you code sinppet:
main() {
init {
result :=3D self.deepclone().oclAsType(EPackage);
name :=3D self.name/*.substringBefore('nice')*/ + 'wild';
nsPrefix :=3D self.name/*.substringBefore('nice')*/ + 'wild';
nsURI :=3D self.nsURI;
/Radek
On Wed, 01 Oct 2008 16:56:30 +0200, Mahdi D-Manesh =
<mahdider@students.uni-mainz.de> wrote:
> PS:
> I changed some of the code and the EClass gets copied now using an =
> explicit mapping rule.
> My code looks like follows:
> name :=3D self.name.substringBefore('nice') + 'wild';
> nsPrefix :=3D self.name.substringBefore('nice') + 'wild';
> -- eSubpackages :=3D self.eSubpackages;
> eClassifiers :=3D self.eClassifiers[ECORE::EClass]->map =
> class2Class()->asOrderedSet();
> mapping ECORE::EClass::class2Class() : ECORE::EClass {
> name :=3D 'Wild' + self.name.substringAfter('Nice');
> -- TODO copy all data here. Can this be done generic?
> Maybe someone can comment on this and give some hints if there is a =
> better / cleaner way of doing it?
> An explanation why my first attempt did not work is appreciated.
> (eClassifiers :=3D self.eClassifiers;)
> Kind Regards,
> Mahdi
> Mahdi D-Manesh schrieb:
>> Hello everyone,
>> this is my first shot on QVTO and I am just trying to get a very bas=
ic =
>> transformation working. The code is as follows and takes in an ecore =
>> file with a single package, containing a single class and should writ=
e =
>> a second ecore file, basically a copy of it but with changed names.
>> main() {
>> Eclipse compains:
>> org.eclipse.m2m.internal.qvt.oml.evaluator.QvtRuntimeExcepti on: Inpu=
t =
>> Is my assignment of a collection / OrderedSet like this not a valid =
>> transformation?
>> Kind Regards,
>> Mahdi
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: [QVTO] Input model parameter '...' is read-only! [message #91074 is a reply to message #90970] |
Thu, 02 October 2008 06:46  |
Hi Radek,
now this was a fast answer thank you a lot!
Of course since I am assigning references, it would make the source
model indirectly "modifyable". I did not think about this at all, too
much concentrating on the syntax I guess... :)
copy() and deepCopy() look like what I need. I found them after I posted
here (in the QVT Specs) but did not try them at that point.
I did now and they work as expected. Very nice.
Kind Regards,
Mahdi
Radek Dvorak schrieb:
> Hi Mahdi,
> container object in the [in] model
> property,
> that
> main() {
> init {
> result := self.deepclone().oclAsType(EPackage);
> name := self.name/*.substringBefore('nice')*/ + 'wild';
> nsPrefix := self.name/*.substringBefore('nice')*/ + 'wild';
> /Radek
>> PS:
>> -- eSubpackages := self.eSubpackages;
>> eClassifiers := self.eClassifiers[ECORE::EClass]->map
>> name := 'Wild' + self.name.substringAfter('Nice');
>> (eClassifiers := self.eClassifiers;)
>> Kind Regards,
>> Mahdi
>>> Hello everyone,
>>> basic transformation working. The code is as follows and takes in an
>>> ecore file with a single package, containing a single class and
>>> should write a second ecore file, basically a copy of it but with
>>> changed names.
>>> main() {
>>> Eclipse compains:
>>> Input model parameter 'nice : NewTransformation::ECORE' is read-only!
>>> transformation?
>>> Kind Regards,
>>> Mahdi
Current Time: Sat Jul 26 03:08:08 EDT 2025
Powered by FUDForum. Page generated in 0.25642 seconds
