Home » Archived » Visual Editor (VE) » install ve
install ve [message #8176] Thu, 04 December 2003 09:56 Go to next message
Originally posted by: Rico.Saupe.freenet.de
Hello
i downloaded and unzipped the required packages for ve into my
eclipse-folder. but where can i find the plugin, if it is correctly
loaded? How can i use ve?
thanx and bye
Re: install ve [message #8241 is a reply to message #8176] Thu, 04 December 2003 12:06 Go to previous messageGo to next message
Originally posted by: jmordax.terra.es
Open the wizards dialog. You should have under Java two new categories:
AWT and Swing. Right?
Hope this helps,
Chemi.
exquisitus wrote:
> Hello
> thanx and bye
Re: install ve [message #8374 is a reply to message #8241] Fri, 05 December 2003 08:05 Go to previous messageGo to next message
no i don't have any of these categories.
In menu "Product Configuration" there is an error in "java emf model
0.5.0" and in "Visual Editor 0.5.0". I dont know why.
> Hope this helps,
> Chemi.
> exquisitus wrote:
>> Hello
>> thanx and bye
Re: install ve [message #8436 is a reply to message #8241] Fri, 05 December 2003 08:07 Go to previous messageGo to next message
there are some errors in the properties-dialog for visual editor 0.5
No plug-in: "org.eclipse.ve.java.core" included at runtime.
No plug-in: "org.eclipse.ve.jfc" included at runtime.
Included feature "Java EMF Model" version "0.5.0" contains problems.
> Hope this helps,
> Chemi.
> exquisitus wrote:
>> Hello
>> thanx and bye
Re: install ve [message #8547 is a reply to message #8436] Fri, 05 December 2003 10:27 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Did you see the requirements for VE:
1) Eclipse 2.1.2
2) GEF 2.1.2
3) EMF 1.1.1
and did you unzip the GEF/EMF/VE zip files into the eclipse subdirectory?
Thanks, Rich Kulp
Re: install ve [message #8828 is a reply to message #8547] Fri, 05 December 2003 16:04 Go to previous messageGo to next message
> 1) Eclipse 2.1.2
> 2) GEF 2.1.2
> 3) EMF 1.1.1
I dont have 2.1.2, thats the reason, i think.
can anyone tell me the reason why eclipse3M5 is not supported by VE?
Re: install ve [message #8842 is a reply to message #8828] Fri, 05 December 2003 16:09 Go to previous message
Because 3.0M5 has broken API's drastically and VE has not yet caught up
to it.
Thanks, Rich Kulp
Re: install ve [message #572045 is a reply to message #8176] Thu, 04 December 2003 12:06 Go to previous message
Hope this helps,
Chemi.
exquisitus wrote:
> Hello
> thanx and bye
Re: install ve [message #572216 is a reply to message #8241] Fri, 05 December 2003 08:05 Go to previous message
> Hope this helps,
> Chemi.
> exquisitus wrote:
>> Hello
>> thanx and bye
Re: install ve [message #572278 is a reply to message #8241] Fri, 05 December 2003 08:07 Go to previous message
> Hope this helps,
> Chemi.
> exquisitus wrote:
>> Hello
>> thanx and bye
Re: install ve [message #572467 is a reply to message #8436] Fri, 05 December 2003 10:27 Go to previous message
1) Eclipse 2.1.2
2) GEF 2.1.2
3) EMF 1.1.1
Thanks, Rich Kulp
Re: install ve [message #572564 is a reply to message #8547] Fri, 05 December 2003 16:04 Go to previous message
> 1) Eclipse 2.1.2
> 2) GEF 2.1.2
> 3) EMF 1.1.1
Re: install ve [message #572621 is a reply to message #8828] Fri, 05 December 2003 16:09 Go to previous message
to it.
Thanks, Rich Kulp
Previous Topic:install ve
Next Topic:What's the cvs repository path?
Current Time: Mon Oct 27 21:33:57 EDT 2025
Powered by FUDForum. Page generated in 0.05949 seconds
