Home » Eclipse Projects » Remote Application Platform (RAP) » how do I register my custom service handlers?
how do I register my custom service handlers? [message #90806] Thu, 29 May 2008 08:53 Go to next message
Originally posted by: dpryadkin.rocketsoftware.com
Dear All,
I've read the following at the eclipse help base:
"Writing an XML file which assigns the service handler to a request
parameter value. In order to be found, the XML file must be located at
the root of the classpath and named servicehandler.xml."
Tried placing the said file to several places, but no luck. If I go to
http://localhost:9090/rap?custom_service_handler=myServiceHa ndler then I
see the RAP startup page. MyServiceHandler was not executed either.
Re: how do I register my custom service handlers? [message #90821 is a reply to message #90806] Thu, 29 May 2008 09:17 Go to previous messageGo to next message
Originally posted by: rsternberg.innoopract.com
Hi Dmitry,
You might want to have a look at bug 205716:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=205716
It seems that you can only add a service handler programmatically by
now. Without ever having tried it myself, i think you should use
RWT#getServiceManager().registerServiceHandler( ... ).
HTH, Ralf
Re: how do I register my custom service handlers? [message #90836 is a reply to message #90821] Thu, 29 May 2008 09:39 Go to previous message
Thanks Ralf, it works
Previous Topic:Deployment problem using new RAP build
Next Topic:Themes from AIE
Current Time: Tue Jul 22 23:56:51 EDT 2025
Powered by FUDForum. Page generated in 0.05278 seconds
