Home » Eclipse Projects » Equinox » Service activation - best practice for service availability?
Service activation - best practice for service availability? [message #90785] Tue, 19 June 2007 10:15 Go to next message
Hey there.
My use case is that I have multiple services that implement a given
interface, and I'd like those services to be available when my plugin is
activated. It's unlikely, but possible that additional services my be
loaded once my plugin is active. My question is how should these
services be started? Note that my plugin, the client, does not know
where these services are coming from, but only that they implement a
particular interface.
<more_background>
Upon plugin startup I setup a ServiceTracker to monitor the known
service interface. Once a service is found/registered, the tracker
stores the service in a registry and exposes the registry as a service.
The plugin will use the registry service to obtain handles on
services. The plugin first implicitly displays service options to the
user. Once a service is selected, the plugin will work with this
service to expose functionality. My goal is that this architecture
allows for ease of service additions and robust selection of services -
each workflow might select a different service.
</more_background>
<what_i_looked_into>
This use case is more of a discovery/lookup scenario where the client
doesn't explicit know about available services - just the interface for
which they implement; therefore Lazy-Start doesn't apply. I've also
read about org.eclipse.ui.startup. (Note that my service bundles will
contribute extension points to the client plugin.) I've experimented
with Declarative Services, but bundleContext.getService(reference)
always returns null (related to the fact that 3.2.2 doesn't fully
support DS?).
</what_i_looked_into>
How do you suggest I start my service bundles? Suggestions?
Thanks in advance.
-Chris
Re: Service activation - best practice for service availability? [message #90800 is a reply to message #90785] Tue, 19 June 2007 13:31 Go to previous messageGo to next message
Follow up...
1.) org.eclipse.ui.startup
This approach isn't recommend nor is it natural to start your bundle
during Eclipse. Within the IStartup implementation you cannot access
the BundleContext to manually start the bundle. I came across a post
suggestion one, albeit not preferred, way to initiate the bundle:
http://mea-bloga.blogspot.com/2006_03_05_archive.html
2.) Declarative Services
DS is promising not yet fruitful. I can run my client plugin in an OSGi
Framework Run As... and all services are created and available. I
assume this explicit launches all selected bundles. But, if I run the
plugin as an Eclipse Application, the services are not initiated because
the services have not been accessed. I tried, without success, to set
immediate="true" when defining the DS service component. My
understanding is that this would "activate [the service] as soon as its
dependencies are satisfied". In both the OSGi Framework and Eclipse
Application org.eclipse.equinox.ds is included in the launch.
3.) Manually in config.ini
Not flexible for service bundle additions.
4.) Manually in plugin activator using Platform.getBundle()
Again, this is tightly coupling the service bundles to the client. The
client should not know the names of the services and the bundles which
the reside.
What is the recommend way to start my service bundles despite not being
explicitly called? Again, I'm trying to gather services that implement
a specific interface. The plugin need not know the particulars of the
interface.
Any suggestions?
Chris wrote:
> Hey there.
> <more_background>
> </more_background>
> support DS?).
> Thanks in advance.
> -Chris
Declarative Services and 112.5.3 "Immediate Component" [message #91352 is a reply to message #90800] Fri, 29 June 2007 01:23 Go to previous messageGo to next message
Does anyone have any thoughts on this topic?
Basically I'm interested in defining a service via Declarative Services
(DS) that is activated per 112.5.3 "Immediate Component" in the R4 OSGi
Compendium.
I'm finding that when I launch my plugin from my workbench with my DS
service bundles that the services have null ServiceReferences which, if
I understand correctly, means that the services have not been activated.
immediate=true has no affect. How can can I tell the Service
Component Runtime to activate my services?
I'm launching w/ org.eclipse.equinox.ds_1.0.0.v20060601a and Eclipse 3.2.2.
-Chris
Chris Wall wrote:
> Follow up...
> the reside.
> interface.
> Any suggestions?
> Chris wrote:
>> Hey there.
>> is activated. It's unlikely, but possible that additional services my
>> be loaded once my plugin is active. My question is how should these
>> <more_background>
>> service. The plugin will use the registry service to obtain handles
>> on services. The plugin first implicitly displays service options to
>> the user. Once a service is selected, the plugin will work with this
>> - each workflow might select a different service.
>> </more_background>
>> for which they implement; therefore Lazy-Start doesn't apply. I've
>> also read about org.eclipse.ui.startup. (Note that my service bundles
>> will contribute extension points to the client plugin.) I've
>> experimented with Declarative Services, but
>> bundleContext.getService(reference) always returns null (related to
>> the fact that 3.2.2 doesn't fully support DS?).
>> Thanks in advance.
>> -Chris
Re: Service activation - best practice for service availability? [message #91471 is a reply to message #90785] Mon, 02 July 2007 10:34 Go to previous message
Hi Chris
In the activator of your service mediator, you could do something similar than Eclipse:
- Enumerate all bundles in a certain directory
- If its a new bundle: Install and start it
- If its an existing bundle: Start it
See also http://www.aqute.biz/Code/FileInstall
Stephan
Previous Topic:Deploying bundles remotely
Next Topic:Jini bundle ?
Current Time: Mon Jul 21 20:08:36 EDT 2025
Powered by FUDForum. Page generated in 0.04335 seconds
