Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [TENEO] No annotated model element present
| [TENEO] No annotated model element present [message #90777] |
Thu, 19 July 2007 08:24  |
Originally posted by: doux.guil.gmail.com
I'm always experiencing problems to add models corresponding to my
meta-model in Teneo.
If I create in a new class a new HbDataStore,
load my meta-model from ecore files with my injectors,
then register the package of my meta-model with setEPackage(mypackages),
I can add my models to the HbDataStore with no problems, it works fine.
But when I retrieve a previously loaded meta-model from Teneo, and then
register his packages to the HbDataStore, I can't persist any model...
I obtain this exception :
found
org.eclipse.gmt.am3.core.storage.RepositoryException:
java.lang.IllegalArgumentException: No annotated model element present
for: Deb for type EClass has its epackage been registered with Teneo?
at test.teneoRep.addModel(teneoRep.java:803)
at test.testrepository.main(testrepository.java:103)
Caused by: java.lang.IllegalArgumentException: No annotated model
element present for: Deb for type EClass has its epackage been
org.eclipse.emf.teneo.annotations.pamodel.impl.PAnnotatedMod elImpl.checkAnnotatedPresent(PAnnotatedModelImpl.java:341)
org.eclipse.emf.teneo.annotations.pamodel.impl.PAnnotatedMod elImpl.getPAnnotated(PAnnotatedModelImpl.java:276)
org.eclipse.emf.teneo.mapping.strategy.impl.EntityResolvingN ameStrategy.toEntityName(EntityResolvingNameStrategy.java:84 )
org.eclipse.emf.teneo.hibernate.EMFInterceptor.getEntityName (EMFInterceptor.java:55)
at org.hibernate.impl.SessionImpl.guessEntityName(SessionImpl.j ava:1765)
at org.hibernate.impl.SessionImpl.getEntityPersister(SessionImp l.java:1338)
org.hibernate.event.def.AbstractSaveEventListener.saveWithGe neratedId(AbstractSaveEventListener.java:96)
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.sav eWithGeneratedOrRequestedId(DefaultSaveOrUpdateEventListener .java:186)
org.hibernate.event.def.DefaultSaveEventListener.saveWithGen eratedOrRequestedId(DefaultSaveEventListener.java:33)
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.ent ityIsTransient(DefaultSaveOrUpdateEventListener.java:175)
org.hibernate.event.def.DefaultSaveEventListener.performSave OrUpdate(DefaultSaveEventListener.java:27)
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.onS aveOrUpdate(DefaultSaveOrUpdateEventListener.java:70)
at org.hibernate.impl.SessionImpl.fireSave(SessionImpl.java:535 )
at org.hibernate.impl.SessionImpl.save(SessionImpl.java:523)
at org.hibernate.impl.SessionImpl.save(SessionImpl.java:519)
at test.teneoRep.addMo(teneoRep.java:296)
at test.teneoRep.addM(teneoRep.java:327)
at test.teneoRep.addModel(teneoRep.java:801)
I have tried many ways, but I obtain always the same exception.
Can you help me ?
guillaume doux
| Re: [TENEO] No annotated model element present [message #90808 is a reply to message #90777] |
Thu, 19 July 2007 08:45   |
What do you mean with this step:
What I understand is that you retrieve the epackage from Teneo (so load it from the db) and register
this epackage with another datastore?
gr. Martin
doux guillaume wrote:
> found
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Can you help me ?
> guillaume doux
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: [TENEO] No annotated model element present [message #90859 is a reply to message #90808] |
Thu, 19 July 2007 09:20   |
In fact, I have to implement a model and meta-model repository with
teneo. My model and meta-models are represented by a structure which
contains a resource, with package inside for the meta-models and objects
corresponding to a meta-model for the model.
I store meta-data on separate table on the database to know that a model
go with a metamodel.
So, when I have to store a model in the repository, I retrieve the
corresponding meta-model from the repository and then I get his epackage
to register it from an HbDataStore and then save my model in this
datastore. I have try to do this with only one datastore by
reinitializing it, and also with a new datastore but I obtain always the
same exception.
I have seen by looking at the generated mapping some difference between
the mapping generated after loading a meta-model from file or from teneo
but it's not seem to be that.
The most curious thing is that when I export a meta-model from Teneo to
an ecore file, and then load it to register his packages and then
persist my model with Teneo, it works fine.
So I don't understand why it doesn't work.
Thanks for the help,
guillaume
Martin Taal wrote:
> it from the db) and register this epackage with another datastore?
> gr. Martin
>> found
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Can you help me ?
>> Thanks,
>> guillaume doux
| Re: [TENEO] No annotated model element present [message #90906 is a reply to message #90859] |
Thu, 19 July 2007 09:56   |
I think I have solved my problem, I haven't correctly initialize my new
hbdatastore.
It seems to be working.
thanks
guillaume
> same exception.
> guillaume
> Martin Taal wrote:
>> load it from the db) and register this epackage with another datastore?
>> gr. Martin
>>> Hi,
>>> found
>>> present for: Deb for type EClass has its epackage been registered
>>> with Teneo?
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Can you help me ?
>>> Thanks,
>>> guillaume doux
| Re: [TENEO] No annotated model element present [message #90920 is a reply to message #90906] |
Thu, 19 July 2007 10:18   |
Hi Guillaume,
That's good, thanks for the update. One thing you should also do is register the epackage, you read
from the db, in the global epackage.registry.
gr. Martin
> hbdatastore.
> thanks
> guillaume
>> objects corresponding to a meta-model for the model.
>> epackage to register it from an HbDataStore and then save my model in
>> this datastore. I have try to do this with only one datastore by
>> the same exception.
>> between the mapping generated after loading a meta-model from file or
>> from teneo
>> to an ecore file, and then load it to register his packages and then
>> guillaume
>> Martin Taal wrote:
>>> Hi,
>>> gr. Martin
>>>> Hi,
>>>> found
>>>> with Teneo?
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Can you help me ?
>>>> Thanks,
>>>> guillaume doux
The Netherlands
| Re: [TENEO] No annotated model element present [message #90935 is a reply to message #90906] |
Thu, 19 July 2007 10:23   |
Hi again,
In fact it's only seems to work, I have always my ecxeption ...
guillaume
> hbdatastore.
> thanks
> guillaume
>> the same exception.
>> from teneo
>> guillaume
>> Martin Taal wrote:
>>> Hi,
>>> gr. Martin
>>>> Hi,
>>>> found
>>>> with Teneo?
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Can you help me ?
>>>> Thanks,
>>>> guillaume doux
| Re: [TENEO] No annotated model element present [message #90949 is a reply to message #90920] |
Thu, 19 July 2007 11:39   |
I have tried to register my packages, who come from the deb in the
epackage.registry.eINSTANCE but it doesn't work more...
have you another idea ?
thanks,
guillaume
Martin Taal wrote:
> Hi Guillaume,
> register the epackage, you read from the db, in the global
> epackage.registry.
> gr. Martin
>> new hbdatastore.
>> thanks
>> guillaume
>>> Hi,
>>> the same exception.
>>> from teneo
>>> guillaume
>>> Martin Taal wrote:
>>>> Hi,
>>>> gr. Martin
>>>>> Hi,
>>>>> fine.
>>>>> then
>>>>> found
>>>>> with Teneo?
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Can you help me ?
>>>>> Thanks,
>>>>> guillaume doux
| Re: [TENEO] No annotated model element present [message #90964 is a reply to message #90949] |
Thu, 19 July 2007 11:54  |
Hi Guillaume,
Not much more than debug through the code. You can set a break point in the map method of the
AnnotationGenerator. This method receives an annotatedModel. The annotatedModel is a representation
of your epackages with additional jpa annotations.
The exception is thrown because the eclass Deb is not present in the annotatedmodel.
You can check if your epackages are actually present in the annotatedModel (look for the
AnnotatedElement member). Also check if they are the same instances, maybe your epackages are
present in memory multiple times.
If you can package it all in a eclipse project with a testcase then I can also try to reproduce it.
gr. Martin
> thanks,
> guillaume
> Martin Taal wrote:
>> Hi Guillaume,
>> epackage.registry.
>> gr. Martin
>>> Hi,
>>> new hbdatastore.
>>> thanks
>>> guillaume
>>>> Hi,
>>>> model
>>>> in this datastore. I have try to do this with only one datastore by
>>>> the same exception.
>>>> or from teneo
>>>> guillaume
>>>> Martin Taal wrote:
>>>>> Hi,
>>>>> then
>>>>> datastore?
>>>>> gr. Martin
>>>>>> Hi,
>>>>>> fine.
>>>>>> then
>>>>>> model...
>>>>>> found
>>>>>> with Teneo?
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Can you help me ?
>>>>>> Thanks,
>>>>>> guillaume doux
The Netherlands
| Re: [TENEO] No annotated model element present [message #608814 is a reply to message #90777] |
gr. Martin
> found
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Can you help me ?
> guillaume doux
The Netherlands
| Re: [TENEO] No annotated model element present [message #608817 is a reply to message #90808] |
same exception.
guillaume
Martin Taal wrote:
> gr. Martin
>> found
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Can you help me ?
>> Thanks,
>> guillaume doux
| Re: [TENEO] No annotated model element present [message #608820 is a reply to message #90859] |
hbdatastore.
thanks
guillaume
> same exception.
> guillaume
> Martin Taal wrote:
>> gr. Martin
>>> Hi,
>>> found
>>> with Teneo?
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Can you help me ?
>>> Thanks,
>>> guillaume doux
| Re: [TENEO] No annotated model element present [message #608821 is a reply to message #90906] |
Hi Guillaume,
gr. Martin
> hbdatastore.
> thanks
> guillaume
>> the same exception.
>> from teneo
>> guillaume
>> Martin Taal wrote:
>>> Hi,
>>> gr. Martin
>>>> Hi,
>>>> found
>>>> with Teneo?
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Can you help me ?
>>>> Thanks,
>>>> guillaume doux
The Netherlands
| Re: [TENEO] No annotated model element present [message #608822 is a reply to message #90906] |
Hi again,
guillaume
> hbdatastore.
> thanks
> guillaume
>> the same exception.
>> from teneo
>> guillaume
>> Martin Taal wrote:
>>> Hi,
>>> gr. Martin
>>>> Hi,
>>>> found
>>>> with Teneo?
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Can you help me ?
>>>> Thanks,
>>>> guillaume doux
| Re: [TENEO] No annotated model element present [message #608823 is a reply to message #90920] |
thanks,
guillaume
Martin Taal wrote:
> Hi Guillaume,
> epackage.registry.
> gr. Martin
>> new hbdatastore.
>> thanks
>> guillaume
>>> Hi,
>>> the same exception.
>>> from teneo
>>> guillaume
>>> Martin Taal wrote:
>>>> Hi,
>>>> gr. Martin
>>>>> Hi,
>>>>> fine.
>>>>> then
>>>>> found
>>>>> with Teneo?
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Can you help me ?
>>>>> Thanks,
>>>>> guillaume doux
| Re: [TENEO] No annotated model element present [message #608824 is a reply to message #90949] |
Hi Guillaume,
gr. Martin
> thanks,
> guillaume
> Martin Taal wrote:
>> Hi Guillaume,
>> epackage.registry.
>> gr. Martin
>>> Hi,
>>> new hbdatastore.
>>> thanks
>>> guillaume
>>>> Hi,
>>>> model
>>>> the same exception.
>>>> or from teneo
>>>> guillaume
>>>> Martin Taal wrote:
>>>>> Hi,
>>>>> then
>>>>> datastore?
>>>>> gr. Martin
>>>>>> Hi,
>>>>>> fine.
>>>>>> then
>>>>>> model...
>>>>>> found
>>>>>> with Teneo?
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Can you help me ?
>>>>>> Thanks,
>>>>>> guillaume doux
The Netherlands
Current Time: Sun Nov 09 13:07:48 EST 2025
Powered by FUDForum. Page generated in 0.04605 seconds
