| PHP inside of Javascript in a .php file [message #90689] | Thu, 15 January 2009 21:14  |  |
| Eclipse User  |  |  |  |  | Originally posted by: micahjg26.netscape.net
 I have Javascript code that I output inside of a PHP file, but put
 variables inside the javascript block.  I am getting a weird error:
 <?php
 function SomeFunction()
 <script type="text/javascript">
 parentValue = <?=$parentValue?>;
 </script>
 I get an error over the '<?' of the '<?=' expresssion in the javascript
 block saying: Syntax error on tokens, PostfixExpression expected instead
 Anyone know why this is?
 Micah
| Re: PHP inside of Javascript in a .php file [message #90752 is a reply to message #90737] | Fri, 16 January 2009 04:21   |  |
 Nick Boldt wrote:
 > Couple thoughts...
 > 1. Try using fully-formed PHP, not the lazy <?= ?> format.
 That didn't make a difference.
 > 2. Try wrapping your javascript variable assignment (unless it's an
 > integer!) with quotes.
 They are integers, but it doesn't matter since I'm just passing them to
 a PHP script with AJAX.  This actually worked, but I have a new problem:
 if (parentValue)
 <?php echo $function;?>
 gives me these errors:
 Multiple annotations found at this line:
 - Syntax error on token "<", invalid Expression
 - Syntax error on token "?", invalid Expression
 - Syntax error on token ">", FullPostfixExpression expected after this
 token
 - Syntax error on token "echo", : expected
 - syntax error, unexpected 'EOF'
 It seems like the Javascript parser has trouble with the PHP inside the
 javascript, even though the javascript is in a PHP file.
 > Thus:
 >  <?php
 >          parentValue = '<?php print $parentValue; ?>';
 >          </script>
 > Or, better:
 >  <?php
 >    print<<<EOHTML
 >   parentValue = '${parentValue}';
 > </script>
 > EOHTML; // must be flushed to left margin
 I might have to try this instead.
 >> <?php
 >>         </script>
 >> Thanks,
 >> Micah
| Re: PHP inside of Javascript in a .php file [message #90843 is a reply to message #90782] | Fri, 16 January 2009 13:02  |  |
 Nick Boldt wrote:
 > Micah wrote:
 >> if (parentValue)
 > What is the value of $function?
 The name of a xajax function.  This is while editing, not running that I
 get the error.
 >> this
 >>      token
 > You might want to open a bug against PDT (or maybe this is a DLTK
 > issue?) explaining what you've tried and what workarounds (if any) work
 > to clear the reported errors.
 I'll have to do that.  I just wanted to make sure that I wasn't missing
 a config setting before filing a bug.
 > Sounds like there are parser usecases not yet implemented.
 > Have you tried doing your javascript in a separate file so that it can
 > be parsed w/ a JS editor, rather than a PHP editor?
 I have pure Javascript functions in a separate file, but it happens to
 be that 65% of this function is generated from PHP variables, so I am
 outputting it inline.
 Micah
FUDForum. Page generated in 0.03171 seconds
