Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Latest build Teneo, backward compatibility
| Latest build Teneo, backward compatibility [message #90595] |
Wed, 18 July 2007 17:30  |
This new build of Teneo solves a number of issues (see the release notes).
One change is important for backward compatability: the way Teneo truncates long sql names has been
improved. This change means that sql (table and column) generated by Teneo can differ from previous
versions. This difference only applies in case the maximum sql name length option was set and table
or column names are too long. In this case please check out this bugzilla for hints on how to retain
https://bugs.eclipse.org/bugs/show_bug.cgi?id=196951
Related to this a new default naming strategy is now used, see here:
http://www.elver.org/hibernate/extensions.html#TeneoSQLNameS trategy+%28default%29
Other changes:
- Handling of composite ids has been improved.
- A new option has been added which allows you to specify the complete path to a hbm file including
its filename.
- comments in the model are now reflected in the hbm file
The last two changes are based on contributions by Jason Henriksen.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: Latest build Teneo, backward compatibility [message #90690 is a reply to message #90677] |
Thu, 19 July 2007 06:55   |
Hi Benjamin,
Yes your bugzilla is valid. I agree that not-removing the first vowel makes it more readable (I
found that approach also on the internet at oracle).
With the other remark, do you mean that instead of this loop:
for (String vowel : vowels) {
while (not yet finished) {
remove one occurence of vowel
if (finished) goaway
it should do this:
If you mean this then I think that either approach is valid. Just let me know what are the arguments
for the other approach.
There should be some literature on the internet which says what gives most readable results (I only
found removing vowels in general but no discussion on other strategies, like first remove u then o
etc.).
Btw, it is easy to plugin your own naming strategy, so you can try different approaches yourselve.
You just need to do this before you initialize the datastore:
dataStore.getExtensionManager().registerExtension(SQLNameStr ategy.class.getName(),
MyGreatNamingStrategy.class.getName()));
(were MyGreatNamingStrategy extends the TeneoSQLNameStrategy and overrides the trunc method)
gr. Martin
Benjamin CABE wrote:
> Hi Martin,
> TeneoSQLNameStrategy looks just great ; my columns now have very
> understandable names !..
> However, I just opened the bug #197110, tell me if you think it's worth
> trying to make this enhancement ....
> It could also be interesting to change the way the loop through "aeiou"
> is done to not remove all A's then all E's etc. but, instead, every
> vowel one after another ...
> Benjamin.
>> notes).
>> truncates long sql names has been improved. This change means that sql
>> length option was set and table or column names are too long. In this
The Netherlands
| Re: Latest build Teneo, backward compatibility [message #90793 is a reply to message #90690] |
Thu, 19 July 2007 08:44   |
> makes it more readable (I found that approach also on the internet at
> oracle).
OK, I'll post the (trivial ;) ) fix, then.
> it should do this:
> know what are the arguments for the other approach.
Yes it is what I meant. In fact, there's no particular argument; all the
more I didn't noticed you've used a specific order for the vowels
("uoaei") according to their importance I presume. It might be enough
for the "generic" TeneoSQLNameStrategy.
> different approaches yourselve. You just need to do this before you
Yes I noticed that already. Simply great :)
Just a last point : don't you think MAXIMUM_SQL_NAME_LENGTH should have
a lower limit (1 would be the bare minimum, even if it's pretty hard to
imagine someone setting MAXIMUM_SQL_NAME_LENGTH to 0 or 1 ;-) )
Benjamin.
| Re: Latest build Teneo, backward compatibility [message #91080 is a reply to message #90793] |
Fri, 20 July 2007 05:45  |
I have added a check on max sql name length, if it is zero an exception is thrown as the mapping
file will get empty column/table names.
If it is lower than 4 a warning is logged.
gr. Martin
>> oracle).
>> it should do this:
>> me know what are the arguments for the other approach.
> Benjamin.
The Netherlands
| Re: Latest build Teneo, backward compatibility [message #608805 is a reply to message #90595] |
Thu, 19 July 2007 06:38  |
Hi Martin,
Benjamin.
> (table and column) generated by Teneo can differ from previous versions.
> was set and table or column names are too long. In this case please
> check out this bugzilla for hints on how to retain backward compatability:
| Re: Latest build Teneo, backward compatibility [message #608806 is a reply to message #90677] |
Hi Benjamin,
it should do this:
etc.).
gr. Martin
> Hi Martin,
> Benjamin.
>> notes).
The Netherlands
| Re: Latest build Teneo, backward compatibility [message #608813 is a reply to message #90690] |
> oracle).
> it should do this:
Benjamin.
| Re: Latest build Teneo, backward compatibility [message #608832 is a reply to message #90793] |
gr. Martin
>> oracle).
>> it should do this:
> Benjamin.
The Netherlands
Current Time: Thu Nov 13 21:35:14 EST 2025
Powered by FUDForum. Page generated in 0.05502 seconds
