Home » Archived » M2M (model-to-model transformation) » Using a Generic MetaClass Name ?!
Using a Generic MetaClass Name ?! [message #90566] Fri, 26 September 2008 05:51 Go to next message
I would like to write a generic rule that calls a helper that computer the
type of the metaclass that will be generated, i wrote this code (that
doesn't work):
helper context UML2!Class def : GenericComponentName () :
AAXL!ComponentClassifier =
if self.isStereotypeApplied('MemoryPartition') then
AAXL!MemoryType
else if self.isStereotypeApplied('SwSchedulableResource') then
AAXL!ProcessType
else
endif
endif ;
rule ClassGeneric {
from a: UML2!Class (a.isAbstract())
--ERROR HERE-- to p: oclType(a.GenericComponentName())(name <- a.name)}
It seems that this is impossible to do this way because of the way ATL
computes the atl transformation file, does anybody have an idea of how to
do this?
[ATL] Re: Using a Generic MetaClass Name ?! [message #90834 is a reply to message #90566] Wed, 01 October 2008 05:35 Go to previous message
The "to" part of the rule can't be parametrized, you need to do that in
another way. For instance :
rule Class2MemoryType {
a.isAbstract() and a.isStereotypeApplied('MemoryPartition'))
to p: AAXL!MemoryType ()
rule ClassGeneric {
etc...
William
Skander a écrit :
> the type of the metaclass that will be generated, i wrote this code
> (that doesn't work):
> AAXL!MemoryType
> AAXL!ProcessType
> else
> endif
> endif ;
> rule ClassGeneric {
> to do this?
Previous Topic:MARTE in km3
Next Topic:[QVTO] Input model parameter '...' is read-only!
Current Time: Sat Jul 26 18:07:51 EDT 2025
Powered by FUDForum. Page generated in 0.05875 seconds
