smart cursoring through java names doesn't work on prev-word [message #90558] |
Fri, 29 August 2003 00:27  |
Originally posted by: leeb.linkline.com
Using 3.0 M3. The new "smart cursoring through java CamelCase names" only
seems to work in the forward direction (Ctrl-RightArrow), but does not work
in the backward direction (Ctrl-LeftArrow). Is this as-designed?
Re: smart cursoring through java names doesn't work on prev-word [message #90753 is a reply to message #90695] |
Fri, 29 August 2003 09:16  |
Ah, indeed I was running into bug 42199. I tried it some more and see that
it does work correctly for most identifiers.
Lee
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:bin8cv$c29$1@eclipse.org...
> Konstantin Scheglov wrote:
only
work
> No. It should work in both directions. In some cases it does not work
> correctly (see bug 42199
> <https://bugs.eclipse.org/bugs/show_bug.cgi?id=42199>) and Martin is
> right, you can disable the feature,
> HTH
> Dani
> > Hm... Works in build 200308261317.
> > However I hate this feature. This is not usually for me to change name
of
> >variable, so I don't need to skip part of it. But often I need to skip it
> >wholly, but now this is impossible. :-(
> > Is it possible to add option in preference?
> No, because then we have it twice since it is already there ;-) See
> Window > Preferences > Java > Editor > Typing
> HTH
> Dani
FUDForum. Page generated in 0.04185 seconds
