Home » Modeling » GMF (Graphical Modeling Framework) » Hide elements via setVisible doesn't work correctly
Hide elements via setVisible doesn't work correctly [message #90510] Mon, 08 January 2007 10:59 Go to next message
Originally posted by: daniel-p.gmx.de
Hey there,
I have following problem, but I don't know if it is my fault or maybe a =
bug on gmf side.
I have a diagram, which is closed. Now I search for certain nodes and =
edges in this diagram and hide them via:
TransactionalEditingDomain te =3D =
TransactionalEditingDomain.Registry.INSTANCE.getEditingDomai n( "xxx");
te.getCommandStack().execute(SetCommand.create(te, view, =
NotationPackage.eINSTANCE.getView_Visible() , new Boolean(b)));
When I now open the diagram, everything worked fine. But when I do the =
same with a diagram, which is already open and then hide some elements, =
not all edges are invisible, some still remain. Now after closing and =
reopening the diagram everything looks fine again.
Dan
Re: Hide elements via setVisible doesn't work correctly [message #90877 is a reply to message #90510] Tue, 09 January 2007 07:54 Go to previous messageGo to next message
Ok, I found out a little bit more. When the diagram is opened and I set =
connections to invisible and reset them to visible, they are drawen from=
the upper left corner of the diagram in the right down direction. After =
closing and reopening the diagram everything is ok. Does anybody know a =
workaround for this problem?
Dan
On Mon, 08 Jan 2007 16:59:44 +0100, Daniel Pech <daniel-p@gmx.de> wrote:=
> Hey there,
> I have following problem, but I don't know if it is my fault or maybe =
a =
> bug on gmf side.
> When I now open the diagram, everything worked fine. But when I do the=
> same with a diagram, which is already open and then hide some elements=
> Cheers,
> Dan
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: Hide elements via setVisible doesn't work correctly [message #119219 is a reply to message #90877] Fri, 13 April 2007 10:26 Go to previous messageGo to next message
hi,
i'm dealing with this problem at the moment.
it seams that changing the visibility of semantic elements (e.g.
ShapeNodeEditPart) doesn't affect the
CannonicalEditPolicy/CanonicalConnectionEditPolicy which are responsible
for refreshing the connection edit parts.
i've read some other threads, but they are all about removing semantic
elements from diagram.
here is my scenario:
1. making elements invisible
node A is linked with node B via connection a->b.
hidding node A or B doesn't remove the connection a->b.
hidding noda A and B does remove the connection too.
2. making elements visible
make node A and B visible, also makes the connection visible. but like
daniel said, the connection is drawn from upper left corner to right
down direction. hide and show node A a second time (only node A!), or
reopening the diagram, resets the connection to the right location again.
any ideas?
andy
> Dan
>> Hey there,
>> a bug on gmf side.
>> elements, not all edges are invisible, some still remain. Now after
>> closing and reopening the diagram everything looks fine again.
>> Cheers,
>> Dan
> --Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: Hide elements via setVisible doesn't work correctly [message #162299 is a reply to message #119219] Fri, 23 November 2007 07:36 Go to previous message
Hey,
is it still relevant to you? I detected the causing problem. The order
of setting the elements is important. First you have to set the nodes
visbile, then the edges. And when you're hiding the nodes and edges you
have to do it the other way aroung.
Dan
Andreas Schuster schrieb:
> hi,
> any ideas?
> andy
>> set connections to invisible and reset them to visible, they are
>> drawen from the upper left corner of the diagram in the right down
>> direction. After closing and reopening the diagram everything is ok.
>> Does anybody know a workaround for this problem?
>> Dan
>>> Hey there,
>>> a bug on gmf side.
>>> the same with a diagram, which is already open and then hide some
>>> Cheers,
>>> Dan
Previous Topic:Super newbie question
Next Topic:GMF and XML
Current Time: Wed Nov 05 03:18:22 EST 2025
Powered by FUDForum. Page generated in 0.03716 seconds
