| Builder error popup [message #90442] |
Thu, 15 January 2009 06:06 |
Hi. I use PDT 2.0.0 all-in-one on Windows and somehow suddenly managed to
get a builder error popup each time I save a file in my project. Project
"Clean..." and rebuild did not help, it gave the same popup at the end.
Off course I can turn off "Build automatically" but I just wonder why this
error occurs and how I can suppress it.
Here is the log generated when the error occurs:
!ENTRY org.eclipse.core.resources 4 2 2009-01-15 11:40:55.421
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.resources".
!STACK 1
org.eclipse.dltk.core.ModelException: <default> [in
\\SPUYMORE\opt\symfony13\lib] does not exist
org.eclipse.dltk.internal.core.ModelElement.newNotPresentExc eption(ModelElement.java:243)
org.eclipse.dltk.internal.core.ModelElement.openWhenClosed(M odelElement.java:181)
org.eclipse.dltk.internal.core.ModelElement.getElementInfo(M odelElement.java:156)
org.eclipse.dltk.internal.core.ModelElement.getChildren(Mode lElement.java:337)
org.eclipse.dltk.internal.core.ModelElement.getChildren(Mode lElement.java:332)
org.eclipse.dltk.internal.core.ModelElement.accept(ModelElem ent.java:681)
org.eclipse.dltk.internal.core.ModelElement.accept(ModelElem ent.java:683)
org.eclipse.dltk.internal.core.builder.ScriptBuilder.getExte rnalElementsFrom(ScriptBuilder.java:588)
org.eclipse.dltk.internal.core.builder.ScriptBuilder.increme ntalBuild(ScriptBuilder.java:631)
org.eclipse.dltk.internal.core.builder.ScriptBuilder.build(S criptBuilder.java:256)
org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:633)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:170)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:201)
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:253)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:256)
org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:309)
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:341)
org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:140)
org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:238)
!SUBENTRY 1 org.eclipse.dltk.core 4 969 2009-01-15 11:40:55.421
!MESSAGE <default> [in \\SPUYMORE\opt\symfony13\lib] does not exist
!ENTRY org.eclipse.core.resources 4 75 2009-01-15 11:40:55.425
!MESSAGE Errors during build.
!SUBENTRY 1 org.eclipse.dltk.core 2 75 2009-01-15 11:40:55.425
!MESSAGE Errors running builder 'Script Builder' on project
'SportsKickoff'.
!SUBENTRY 1 org.eclipse.dltk.core 4 969 2009-01-15 11:40:55.426
FUDForum. Page generated in 0.03098 seconds
