| Re: Tutorial contribution [message #90805 is a reply to message #90470] |
Thu, 07 April 2005 14:41   |
Sorry, I should have been clearer. I know and understand the process. What I
am really looking for is the format of the document (HTML with style sheets,
XML, xdocs). I want it to be easy for the contributor to put it on the
website with minimal modifications and no copy and paste issues. I was
hoping if the exsiting tutorials are in the CVS respository I could use them
as a template.
"David Williams" <david_williams@us.ibm.com> wrote in message
news:opsotgmbo8ac05ss@news.eclipse.org...
> On Wed, 6 Apr 2005 06:48:02 +0000 (UTC), Lawrence Mandel
<lmandel@ca.ibm.com> wrote:
> > You can open the bug against the Web Tools project's website component.
> > Alternatively, if you're looking to write a high quality, fairly
detailed
> > tutorial you can propose it to Eclipse corner. The proposal process is
the
> > same except you open the defect against the Community project's Articles
> > component. The WTP project will still link to your tutorial but your
> > tutorial will be published in a larger forum.
> > I look forward to seeing your idea and/or your tutorial.
> > Lawrence
> To re-iterate Lawrence's advice, we'd greatly appreciate tutorials that
also
> serve as "use cases" to test various high priority paths in the tooling.
> But, if you're going for that "larger forum" :) here's a link with
> some pointers http://www.eclipse.org/articles
| Re: Tutorial contribution [message #90924 is a reply to message #90805] |
Thu, 07 April 2005 23:19  |
On Thu, 7 Apr 2005 14:41:01 -0400, Christopher M. Judd <eclipse@juddsolutions.com> wrote:
> [...] What I
> as a template.
Ah, our website content is kept in
dev.eclipse.org:/home/cvs/org.eclipse
in the www/webtools directory
Though the templates in http://www.eclipse.org/articles
would also be suitable.
FUDForum. Page generated in 0.03717 seconds
