Home » Archived » Test and Performance Tools Platform (TPTP) » TIme-out occurred while attempting to launch the process
TIme-out occurred while attempting to launch the process [message #90282] Thu, 14 December 2006 09:11 Go to next message
Originally posted by: sdiz.spspam.spam.sdiz.spam.net
I got a "time-out occurred while attempting to launch the process" error
when trying to profile a java application using JVM TI on java6.
The config\service.log shows (with some xml):
CONSOLE LAUNCHED COMMAND for connection(5005)
I see no java process (except eclipse) is running from the task manager.
I have also tried to delete the config file and run setconfig.bat again,
but this doesn't help.
The "Test Connection" button in eclipse shows success.
Are there any other log / config files I should look at?
This machine is running
Eclipse 3.2.1
Windows XP
Java 6
TPTP 4.3
JVM TI
Re: TIme-out occurred while attempting to launch the process [message #90313 is a reply to message #90282] Thu, 14 December 2006 09:24 Go to previous message
Some more infomation:
"Profile" button on the toolbar -> "Monitor" tab -> "Java Profiling with
Instrumentation" -> "Test Availablity" say,
The JVMTI agent org.eclipse.tptp.jvmti is not available.
Make sure the agent's libraries are available and that it is
configured properly.
There is a java.exe process spawned by TPTPProcessController.exe
the java process takes no cpu and does not end.
> Eclipse 3.2.1
> Windows XP
> Java 6
> TPTP 4.3
> JVM TI
This space was intended to be left blank.
Previous Topic:Profile launch fails: can't resolve data collectors
Next Topic:tptp.automated.gui workaround, any luck?
Current Time: Sat Oct 11 16:27:56 EDT 2025
Powered by FUDForum. Page generated in 0.05622 seconds
