Home » Language IDEs » C / C++ IDE (CDT) » Linkerproblem with STLPort
Linkerproblem with STLPort [message #90199] Thu, 18 December 2003 17:20 Go to next message
Originally posted by: toomy.bluewin.ch
I have successfuly installed CDT, have compiled and linked a small
application.
I have WinXp and Eclipse 3.0M5 and CDT 2.0M5 installed.
I need to use the libary STLport and boost. I have successuly compiled and
linked the libraries. I have compiled and linked successfuly with the
stlport library by invoking g++ from the cmd line.
I am not able link the STLport lib with CDT. I have setup the
ProjectSettings C/C++ Build both Release and Debug Settings.
The linker path is like the following:
C:\cygwin\usr\local\lib\libstlport_cygwin.a
The output is as follow:
/usr/lib/gcc-lib/i686-pc-cygwin/3.3.1/../../../../i686-pc-cy gwin/bin/ld
cannot find -lC:\cygwin\usr\local\lib\libstlport_cygwin.a
Does anybody know what is wrong?
Thanks Markus
Re: Linkerproblem with STLPort [message #90228 is a reply to message #90199] Thu, 18 December 2003 19:14 Go to previous messageGo to next message
Markus wrote:
> Hi
> application.
You don't add libraries with -l when using full path! When using full
path, add this in your Makefile to the linker flags like:
LDFLAGS += C:\cygwin\usr\local\lib\libstlport_cygwin.a
When you use Managed Build, in the project settings add the full path in
the Linker page under Miscelleanous in the bottom field. Not on the
second by "-l"!
Or you use -L and -l like this way:
-L"C:\cygwin\usr\local\lib" -lstlport_cygwin
> Thanks Markus
Re: Linkerproblem with STLPort [message #90258 is a reply to message #90228] Fri, 19 December 2003 02:58 Go to previous messageGo to next message
Thanks now it works, I added the full pathe in misc/oterObjects.
Why does it not work if I add the path "C:\cygwin\usr\local\lib" to the
library search path and the lib "libstlport_cygwin.a" to the libs?
Do I have in general add the libs I want to use in the misc/otherObjects?
kesselhaus wrote:
> Markus wrote:
> > Hi
> > application.
> > C:cygwinusrlocalliblibstlport_cygwin.a
> > cannot find -lC:cygwinusrlocalliblibstlport_cygwin.a
> LDFLAGS += C:cygwinusrlocalliblibstlport_cygwin.a
> second by "-l"!
> -L"C:cygwinusrlocallib" -lstlport_cygwin
> > Thanks Markus
Re: Linkerproblem with STLPort [message #90273 is a reply to message #90258] Fri, 19 December 2003 04:04 Go to previous message
I gave you the second version with path and lib divided below.
When using -L and -l, the linker will you the paths given with -L as
additional search paths to the system library search path. When
providing libs with -l to the linker, ld (the linker) will add the
prefix 'lib' infront of the given lib and the proper extension ('.a') at
the end.
Examples:
-lstdc++ -> libstdc++.a
-lm -> libm.a
-lxml2 -> libxml2.a
This makes it more simple to find out, what is a lib and what not, and
how is the name of the lib. You strip the 'lib'-prefix and the extension
and you get the name of the library.
This is for GCC Toolchain only, Microsoft or Borland don't do this.
When using these to compilers, you have to give them the full library
name like libstdc++.lib. They usually also don't use the 'lib'-prefix.
No, it depends on your libs you use. When they follow the naming
convention above, you can add them like described above. But for
Microsoft or Borland compilers, you'll have to add them under
misc/otherObjs.
> Thanks
> kesselhaus wrote:
>>Markus wrote:
>>>Hi
>>>application.
>>second by "-l"!
>>>Thanks Markus
Previous Topic:[ANN] eclipseCon Reminder
Next Topic:Shared Objects
Current Time: Tue Nov 11 16:59:53 EST 2025
Powered by FUDForum. Page generated in 0.04610 seconds
