Home » Language IDEs » Java Development Tools (JDT) » Can't convince Eclipse to build with non-default JRE
Can't convince Eclipse to build with non-default JRE [message #90170] Thu, 28 August 2003 09:56 Go to next message
Originally posted by: plynch.supergenius.org
A story of two systems:
System 1
Laptop. Has two JREs installed -- 1.4.2 and 1.3.1_08.
Eclipse is configured with both JREs and 1.3.1_08 is marked default.
Project is on a shared drive and is rebuilt.
Project can be run with 1.3.1_08 JVM.
System 2
Desktop. Has two JREs installed -- 1.4.1_03 and 1.3.1_08.
Same project from shared drive is loaded and rebuilt.
Project CANNOT be run with 1.3.1_08 JVM because class files have
incorrect major/minor numbers (meaning Project was really
built using 1.4.1_03 JRE).
How can I convince Eclipse on the Desktop system to build
the project with 1.3.1_08 JRE so that the class files will
be able to run in a 1.3.1_08 JVM?
Re: Can't convince Eclipse to build with non-default JRE [message #90229 is a reply to message #90170] Thu, 28 August 2003 10:58 Go to previous messageGo to next message
Shouldn't the subject be can't convince Eclipse to build with the default
JRE?
In your description you state that 1.3.1_08 is always the default and is the
JRE you wish to build against?
Try:
Context menu on the project, Properties>Java Build Path>Libraries
Ensure the JRE_LIB is what you want. If not set the correct library on the
build path
HTH
Darins
"Pat Lynch" <plynch@supergenius.org> wrote in message
news:bil1mv$8cr$1@eclipse.org...
> System 1
> System 2
Re: Can't convince Eclipse to build with default JRE [message #90275 is a reply to message #90229] Thu, 28 August 2003 11:10 Go to previous messageGo to next message
Doh! You're correct! Subject should be default vs non-default.
The settings in the project are correct (i.e. the 1.3.1 JRE). I would
expect this because both systems load the project from the same (shared)
folders and this setting is stored internally within the project.
What stumps me is that one system is working the way it should, the
other isn't and I can't find anything configured differently between
the two (other than 1.4.2 vs. 1.4.1_03).
> JRE?
> Try:
> build path
> HTH
> Darins
> > System 1
> > System 2
Re: Can't convince Eclipse to build with default JRE [message #90379 is a reply to message #90275] Thu, 28 August 2003 12:26 Go to previous messageGo to next message
Libraries used to compile against and compliance mode are 2 different
things.
Check Window->Preferences->Compiler->Compliance and Classfiles. I suspect
that it is set to a 1.4 compliance level.
Jerome
news:bil608$dld$1@eclipse.org...
default
> > JRE?
the
> > Try:
the
> > build path
> > HTH
> > Darins
> > > System 1
> > > System 2
Re: Can't convince Eclipse to build with default JRE [message #92152 is a reply to message #90379] Thu, 04 September 2003 08:31 Go to previous message
Strangely enough it was set to 1.3 compliance but was still
producing 1.4 class files. I used the "restore defaults"
options to reset it to 1.3 and it is now producing 1.3
compliant class files.
Thanks a bunch Jerome!
> things.
> Jerome
> default
>>>JRE?
> the
>>>Try:
> the
>>>build path
>>>HTH
>>>Darins
>>>>System 1
>>>>System 2
Previous Topic:Application works inside Eclipse but NOT outside
Next Topic:Two programmers sharing the same project?
Current Time: Sat Nov 08 09:13:59 EST 2025
Powered by FUDForum. Page generated in 0.04612 seconds
