Home » Newcomers » Newcomers » palette not available
palette not available [message #90130] Thu, 28 July 2005 12:36 Go to next message
Originally posted by: mike.vanderveer.slimsoft.com
I just installed eclipse to support the IDE for openLaszlo. The palette
says "palette not available"
in the error log I have
!ENTRY org.eclipse.ui 4 4 2005-07-28 12:10:10.937
!MESSAGE Exception in
org.eclipse.ui.internal.FolderLayout.addView(String):
org.eclipse.ui.PartInitException: View descriptor not found:
com.ibm.rct.editor.attributeEditor
and
!ENTRY org.eclipse.jface 4 2 2005-07-28 11:54:10.718
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
com.ibm.rct.asdt.internal.ui.javaeditor.EditorUtility.reveal InEditor(EditorUtility.java:184)
com.ibm.rct.asdt.internal.ui.actions.OpenActionUtil.open(Ope nActionUtil.java:51)
at com.ibm.rct.asdt.ui.actions.OpenAction.run(OpenAction.java:1 64)
any ideas?
Ignore Re: palette not available [message #90145 is a reply to message #90130] Thu, 28 July 2005 13:27 Go to previous message
I initially installed 3.1, which was warned wouldn't work.
I uninstalled and tried 3.0.2 and it works perfectly
Previous Topic:why my program so slowly?
Next Topic:Help with creating a .jar file
Current Time: Sun Jun 22 06:48:00 EDT 2025
Powered by FUDForum. Page generated in 0.08606 seconds
